EPICS Base
7.0.6.1
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times. More...
#include <time.h>#include "libComAPI.h"#include "epicsTypes.h"#include "osdTime.h"#include "errMdef.h"#include <stdexcept>#include <ostream>
Classes | |
| struct | epicsTimeStamp |
| EPICS time stamp, for use from C code. More... | |
| struct | local_tm_nano_sec |
C++ only ANSI C struct tm with nanoseconds, local timezone. More... | |
| struct | gm_tm_nano_sec |
C++ only ANSI C sruct tm with nanoseconds, UTC. More... | |
| struct | time_t_wrapper |
| C++ only ANSI C time_t. More... | |
| class | epicsTimeEvent |
| C++ Event number wrapper class. More... | |
| class | epicsTime |
| C++ time stamp object. More... | |
Macros | |
| #define | POSIX_TIME_AT_EPICS_EPOCH 631152000u |
| The EPICS Epoch is 00:00:00 Jan 1, 1990 UTC. | |
| #define | TS_STAMP epicsTimeStamp |
| Old time-stamp data type, deprecated. More... | |
Return status values | |
epicsTime routines return | |
| #define | epicsTimeOK 0 |
| Success. | |
| #define | S_time_noProvider (M_time| 1) /*No time provider*/ |
| No time provider. | |
| #define | S_time_badEvent (M_time| 2) /*Bad event number*/ |
| Bad event number. | |
| #define | S_time_badArgs (M_time| 3) /*Invalid arguments*/ |
| Invalid arguments. | |
| #define | S_time_noMemory (M_time| 4) /*Out of memory*/ |
| Out of memory. | |
| #define | S_time_unsynchronized (M_time| 5) /*Provider not synchronized*/ |
| Provider not synchronized. | |
| #define | S_time_timezone (M_time| 6) /*Invalid timezone*/ |
| Invalid timezone. | |
| #define | S_time_conversion (M_time| 7) /*Time conversion error*/ |
| Time conversion error. | |
epicsTimeEvent numbers | |
Some special values for eventNumber: | |
| #define | epicsTimeEventCurrentTime 0 |
| #define | epicsTimeEventBestTime -1 |
| #define | epicsTimeEventDeviceTime -2 |
Typedefs | |
| typedef epicsUInt64 | epicsUTag |
| Type of UTAG field (dbCommon::utag) | |
Functions | |
| LIBCOM_API size_t epicsStdCall | epicsTimeToStrftime (char *pBuff, size_t bufLength, const char *pFormat, const epicsTimeStamp *pTS) |
| Convert epicsTimeStamp to string. See epicsTime::strftime() | |
| LIBCOM_API void epicsStdCall | epicsTimeShow (const epicsTimeStamp *, unsigned interestLevel) |
| Dump current state to stdout. | |
| LIBCOM_API std::ostream & | operator<< (std::ostream &strm, const epicsTime &ts) |
generalTime functions | |
These are implemented in the "generalTime" framework: | |
| LIBCOM_API int epicsStdCall | epicsTimeGetCurrent (epicsTimeStamp *pDest) |
Get current time into *pDest. | |
| LIBCOM_API int epicsStdCall | epicsTimeGetEvent (epicsTimeStamp *pDest, int eventNumber) |
Get time of event eventNumber into *pDest. | |
| LIBCOM_API int | epicsTimeGetMonotonic (epicsTimeStamp *pDest) |
Get monotonic time into *pDest. | |
ISR-callable | |
These routines may be called from an Interrupt Service Routine, and will return a value from the last current time or event time provider that sucessfully returned a result from the equivalent non-ISR routine. | |
| LIBCOM_API int | epicsTimeGetCurrentInt (epicsTimeStamp *pDest) |
Get current time into *pDest (ISR-safe) | |
| LIBCOM_API int | epicsTimeGetEventInt (epicsTimeStamp *pDest, int eventNumber) |
Get time of event eventNumber into *pDest (ISR-safe) | |
ANSI C time_t conversions | |
Convert to and from ANSI C | |
| LIBCOM_API int epicsStdCall | epicsTimeToTime_t (time_t *pDest, const epicsTimeStamp *pSrc) |
Convert epicsTimeStamp to ANSI C time_t. | |
| LIBCOM_API int epicsStdCall | epicsTimeFromTime_t (epicsTimeStamp *pDest, time_t src) |
Convert ANSI C time_t to epicsTimeStamp. | |
ANSI C struct tm conversions | |
Convert to and from ANSI C's | |
| LIBCOM_API int epicsStdCall | epicsTimeToTM (struct tm *pDest, unsigned long *pNSecDest, const epicsTimeStamp *pSrc) |
Convert epicsTimeStamp to struct tm in local time zone. | |
| LIBCOM_API int epicsStdCall | epicsTimeToGMTM (struct tm *pDest, unsigned long *pNSecDest, const epicsTimeStamp *pSrc) |
Convert epicsTimeStamp to struct tm in UTC/GMT. | |
| LIBCOM_API int epicsStdCall | epicsTimeFromTM (epicsTimeStamp *pDest, const struct tm *pSrc, unsigned long nSecSrc) |
Set epicsTimeStamp from struct tm in local time zone. | |
| LIBCOM_API int epicsStdCall | epicsTimeFromGMTM (epicsTimeStamp *pDest, const struct tm *pSrc, unsigned long nSecSrc) |
Set epicsTimeStamp from struct tm in UTC/GMT. | |
POSIX RT struct timespec conversions | |
Convert to and from the POSIX RealTime | |
| LIBCOM_API int epicsStdCall | epicsTimeToTimespec (struct timespec *pDest, const epicsTimeStamp *pSrc) |
Convert epicsTimeStamp to struct timespec | |
| LIBCOM_API int epicsStdCall | epicsTimeFromTimespec (epicsTimeStamp *pDest, const struct timespec *pSrc) |
Set epicsTimeStamp from struct timespec | |
BSD's struct timeval conversions | |
Convert to and from the BSD | |
| LIBCOM_API int epicsStdCall | epicsTimeToTimeval (struct timeval *pDest, const epicsTimeStamp *pSrc) |
Convert epicsTimeStamp to struct timeval | |
| LIBCOM_API int epicsStdCall | epicsTimeFromTimeval (epicsTimeStamp *pDest, const struct timeval *pSrc) |
Set epicsTimeStamp from struct timeval | |
Arithmetic operations | |
Arithmetic operations on epicsTimeStamp objects and time differences which are normally expressed as a | |
| LIBCOM_API double epicsStdCall | epicsTimeDiffInSeconds (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
Time difference between left and right in seconds. | |
| LIBCOM_API void epicsStdCall | epicsTimeAddSeconds (epicsTimeStamp *pDest, double secondsToAdd) |
Add some number of seconds to dest. | |
| LIBCOM_API epicsInt64 epicsStdCall | epicsTimeDiffInNS (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
Time difference between left and right, as a signed integer number of nanoseconds. More... | |
Comparison operators | |
Comparisons between epicsTimeStamp objects, returning 0=false, 1=true. | |
| LIBCOM_API int epicsStdCall | epicsTimeEqual (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
left equals right | |
| LIBCOM_API int epicsStdCall | epicsTimeNotEqual (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
left not equal to right | |
| LIBCOM_API int epicsStdCall | epicsTimeLessThan (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
left was before right | |
| LIBCOM_API int epicsStdCall | epicsTimeLessThanEqual (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
right was no later than left | |
| LIBCOM_API int epicsStdCall | epicsTimeGreaterThan (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
left was after right | |
| LIBCOM_API int epicsStdCall | epicsTimeGreaterThanEqual (const epicsTimeStamp *pLeft, const epicsTimeStamp *pRight) |
right was not before left | |
Re-entrant time_t to struct tm conversions | |
OS-specific reentrant versions of the ANSI C interface because the vxWorks | |
| LIBCOM_API int epicsStdCall | epicsTime_localtime (const time_t *clock, struct tm *result) |
Break down a time_t into a struct tm in the local timezone. | |
| LIBCOM_API int epicsStdCall | epicsTime_gmtime (const time_t *clock, struct tm *result) |
Break down a time_t into a struct tm in the UTC timezone. | |
Monotonic time routines | |
| LIBCOM_API epicsUInt64 | epicsMonotonicResolution (void) |
| Monotonic time resolution, may not be accurate. Returns the minimum non-zero time difference between two calls to epicsMonotonicGet() in units of nanoseconds. | |
| LIBCOM_API epicsUInt64 | epicsMonotonicGet (void) |
| Fetch monotonic counter, returns the number of nanoseconds since some unspecified time. | |
Definition in file epicsTime.h.
| #define TS_STAMP epicsTimeStamp |
Definition at line 55 of file epicsTime.h.
| LIBCOM_API epicsInt64 epicsStdCall epicsTimeDiffInNS | ( | const epicsTimeStamp * | pLeft, |
| const epicsTimeStamp * | pRight | ||
1.8.5
