EPICS Base
7.0.6.1
Files | |
| file | epicsMMIODef.h |
| Memory Mapped I/O. | |
| #define | rbarr() do{}while(0) |
| Explicit read memory barrier Prevents reordering of reads around it. | |
| #define | wbarr() do{}while(0) |
| Explicit write memory barrier Prevents reordering of writes around it. | |
| #define | rwbarr() do{}while(0) |
| Explicit read/write memory barrier Prevents reordering of reads or writes around it. | |
Safe operations on I/O memory.
This files defines a set of macros for access to Memory Mapped I/O
They are named T_ioread# and T_iowrite# where # can be 8, 16, or 32. 'T' can either be 'le', 'be', or 'nat' (except ioread8 and iowrite8).
The macros defined use OS specific extensions (when available) to ensure the following.
PCI access should use either 'le_' or 'be_' as determined by the device byte order.
VME access should always use 'nat_'. If the device byte order is little endian then an explicit swap is required.
PCI
VME
PCI
VME
This difference arises because VME bridges implement hardware byte swapping on little endian systems, while PCI bridges do not. Software accessing PCI devices must know if byte swapping is required. This conditional swap is implemented by the 'be_' and 'le_' macros.
This is a fundamental difference between PCI and VME.
Software accessing PCI must do conditional swapping.
Software accessing VME must not do conditional swapping.
1.8.5
