EPICS Base  7.0.6.1
Classes | Macros
macLib.h File Reference
Text macro substitution routines. More...
#include "ellLib.h"
#include "libComAPI.h"
Include dependency graph for macLib.h:
Classes
struct  MAC_HANDLE
 Macro substitution context, for use by macLib routines only. More...
Macros
#define MAC_SIZE   256
 Maximum size of a macro name or value.
Functions
Core Library
The core library provides a minimal set of basic operations.
LIBCOM_API long epicsStdCall macCreateHandle (MAC_HANDLE **handle, const char *pairs[])
 Creates a new macro substitution context. More...
LIBCOM_API void epicsStdCall macSuppressWarning (MAC_HANDLE *handle, int falseTrue)
 Disable or enable warning messages. More...
LIBCOM_API long epicsStdCall macExpandString (MAC_HANDLE *handle, const char *src, char *dest, long capacity)
 Expand a string which may contain macro references. More...
LIBCOM_API long epicsStdCall macPutValue (MAC_HANDLE *handle, const char *name, const char *value)
 Sets the value of a specific macro. More...
LIBCOM_API long epicsStdCall macGetValue (MAC_HANDLE *handle, const char *name, char *value, long capacity)
 Returns the value of a macro. More...
LIBCOM_API long epicsStdCall macDeleteHandle (MAC_HANDLE *handle)
 Marks a handle invalid, and frees all storage associated with it. More...
LIBCOM_API long epicsStdCall macPushScope (MAC_HANDLE *handle)
 Marks the start of a new scoping level. More...
LIBCOM_API long epicsStdCall macPopScope (MAC_HANDLE *handle)
 Retrieve the last pushed scope (like stack operations) More...
LIBCOM_API long epicsStdCall macReportMacros (MAC_HANDLE *handle)
 Reports details of current definitions. More...
Utility Library
These convenience functions are intended for applications to use and provide a more convenient interface for some purposes.
LIBCOM_API long epicsStdCall macParseDefns (MAC_HANDLE *handle, const char *defns, char **pairs[])
 Parse macro definitions into an array of {name, value} pairs. More...
LIBCOM_API long epicsStdCall macInstallMacros (MAC_HANDLE *handle, char *pairs[])
 Install set of {name, value} pairs as definitions. More...
LIBCOM_API char *epicsStdCall macEnvExpand (const char *str)
 Expand environment variables in a string. More...
LIBCOM_API char *epicsStdCall macDefExpand (const char *str, MAC_HANDLE *macros)
 Expands macros and environment variables in a string. More...
Detailed Description
Author
William Lupton, W. M. Keck Observatory
This general purpose macro substitution library is used for all macro substitutions in EPICS Base.
Most routines return 0 (OK) on success, -1 (ERROR) on failure, or small positive values for extra info. The macGetValue() and macExpandString() routines depart from this and return information both on success / failure and on value length. Errors and warnings are reported using errlogPrintf().
Definition in file macLib.h.
Function Documentation
LIBCOM_API long epicsStdCall macCreateHandle ( MAC_HANDLE **  handle,
const char *  pairs[]
Returns
0 = OK; <0 = ERROR
Parameters
handlepointer to variable to receive pointer to new macro substitution context
pairspointer to NULL-terminated array of {name,value} pair strings. A NULL value implies undefined; a NULL pairs argument implies no macros.
LIBCOM_API void epicsStdCall macSuppressWarning ( MAC_HANDLE *  handle,
int  falseTrue
The macExpandString() routine prints warnings when it cant expand a macro. This routine can be used to silence those warnings. A non zero value will suppress the warning messages from subsequent library routines given the same handle.
Parameters
handleopaque handle
falseTrue0 means issue, 1 means suppress
LIBCOM_API long epicsStdCall macExpandString ( MAC_HANDLE *  handle,
const char *  src,
char *  dest,
long  capacity
Returns
Returns the length of the expanded string, <0 if any macro are undefined
This routine parses the src string looking for macro references and passes any it finds to macGetValue() for translation.
Note
The return value is similar to that of macGetValue(). Its absolute value is the number of characters copied to dest. If the return value is negative, at least one undefined macro was left unexpanded.
Parameters
handleopaque handle
srcsource string
destdestination string
capacitycapacity of destination buffer (dest)
LIBCOM_API long epicsStdCall macPutValue ( MAC_HANDLE *  handle,
const char *  name,
const char *  value
Returns
Returns the length of the value string.
Note
If value is NULL, all instances of name are undefined at all scoping levels (the named macro doesn't have to exist in this case). Macros referenced in value need not be defined at this point.
Parameters
handleopaque handle
namemacro name
valuemacro value
LIBCOM_API long epicsStdCall macGetValue ( MAC_HANDLE *  handle,
const char *  name,
char *  value,
long  capacity
Returns
Returns the length of the value string, <0 if undefined
value will be zero-terminated if the length of the value is less than capacity. The return value is the number of characters copied to value (see below for behavior if the macro is undefined). If capacity is zero, no characters will be copied to value (which may be NULL) and the call can be used to check whether the macro is defined.
Note
Truncation of the value is not reported, applications should assume that truncation has occurred if the return value is equal to capacity.
If the macro is undefined, the macro reference will be returned in the value string (if permitted by maxlen) and the function value will be minus the number of characters copied. Note that treatment of capacity is intended to be consistent with the strncpy() routine.
If the value contains macro references, these references will be expanded recursively. This expansion will detect a direct or indirect self reference.
Macro references begin with a "$" immediately followed by either a "(" or a "{" character. The macro name comes next, and may optionally be succeeded by an "=" and a default value, which will be returned if the named macro is undefined at the moment of expansion. A reference is terminated by the matching ")" or "}" character.
Parameters
handleopaque handle
namemacro name or reference
valuestring to receive macro value or name argument if macro is undefined
capacitycapacity of destination buffer (value)
LIBCOM_API long epicsStdCall macDeleteHandle ( MAC_HANDLE *  handle)
Returns
0 = OK; <0 = ERROR
Note
Note that this does not free any strings into which macro values have been returned. Macro values are always returned into strings which were pre-allocated by the caller.
Parameters
handleopaque handle
LIBCOM_API long epicsStdCall macPushScope ( MAC_HANDLE *  handle)
Returns
0 = OK; <0 = ERROR
Marks all macro definitions added after this call as belonging to another scope. These macros will be lost on a macPopScope() call and those at the current scope will be re-instated.
Parameters
handleopaque handle
LIBCOM_API long epicsStdCall macPopScope ( MAC_HANDLE *  handle)
Returns
0 = OK; <0 = ERROR
See macPushScope()
Parameters
handleopaque handle
LIBCOM_API long epicsStdCall macReportMacros ( MAC_HANDLE *  handle)
Returns
0 = OK; <0 = ERROR This sends details of current definitions to standard output, and is intended purely for debugging purposes.
Parameters
handleopaque handle
LIBCOM_API long epicsStdCall macParseDefns ( MAC_HANDLE *  handle,
const char *  defns,
char **  pairs[]
Returns
Number of macros found; <0 = ERROR
This takes a set of macro definitions in "a=xxx,b=yyy" format and converts them into an array of pointers to character strings which are, in order, "first name", "first value", "second name", "second value" etc. The array is terminated with two NULL pointers and all storage is allocated contiguously so that it can be freed with a single call to free().
This routine is independent of any handle and provides a generally useful service which may be used elsewhere. Any macro references in values are not expanded at this point since the referenced macros may be defined or redefined before the macro actually has to be translated.
Shell-style escapes and quotes are supported, as are things like "A=B,B=$(C$(A)),CA=CA,CB=CB" (sets B to "CB"). White space is significant within values but ignored elsewhere (i.e. surrounding "=" and "," characters).
The function returns the number of definitions encountered, or -1 if the supplied string is invalid.
Parameters
handleopaque handle; may be NULL if debug messages are not required.
defnsmacro definitions in "a=xxx,b=yyy" format
pairsaddress of variable to receive pointer to NULL-terminated array of {name, value} pair strings; all storage is allocated contiguously
LIBCOM_API long epicsStdCall macInstallMacros ( MAC_HANDLE *  handle,
char *  pairs[]
Returns
Number of macros defined; <0 = ERROR
This takes an array of pairs as defined above and installs them as definitions by calling macPutValue(). The pairs array is terminated by a NULL pointer.
Parameters
handleopaque handle
pairspointer to NULL-terminated array of {name,value} pair strings; a NULL value implies undefined; a NULL argument implies no macros
LIBCOM_API char* epicsStdCall macEnvExpand ( const char *  str)
Returns
Expanded string; NULL if any undefined macros were used.
This routine expands a string which may contain macros that are environment variables. It parses the string looking for such references and passes them to macGetValue() for translation. It uses malloc() to allocate space for the expanded string and returns a pointer to this null-terminated string. It returns NULL if the source string contains any undefined references.
Parameters
strstring to be expanded
LIBCOM_API char* epicsStdCall macDefExpand ( const char *  str,
MAC_HANDLE *  macros
Returns
This routine is similar to macEnvExpand() but allows an optional handle to be passed in that may contain additional macro definitions. These macros are appended to the set of macros from environment variables when expanding the string.
Parameters
macrosopaque handle; may be NULL if only environment variables are to be used
