EPICS Base
7.0.6.1
The API for the EPICS Calculation Engine. More...
#include "libComAPI.h"
Macros | |
| #define | CALCPERFORM_NARGS 12 |
| Number of input arguments to a calc expression (A-L) | |
| #define | CALCPERFORM_STACK 80 |
| Size of the internal partial result stack. | |
Postfix and Infix Buffer Sizes | |
| #define | INFIX_TO_POSTFIX_SIZE(n) ((n)*21/6) |
| Calculate required size of postfix buffer from infix. More... | |
| #define | MAX_INFIX_SIZE 100 |
| Size of a "standard" infix string. More... | |
| #define | MAX_POSTFIX_SIZE INFIX_TO_POSTFIX_SIZE(MAX_INFIX_SIZE) |
| Size of a "standard" postfix buffer. More... | |
Calc Engine Error Codes | |
| #define | CALC_ERR_NONE 0 |
| No error. | |
| #define | CALC_ERR_TOOMANY 1 |
| Too many results returned. | |
| #define | CALC_ERR_BAD_LITERAL 2 |
| Bad numeric literal. | |
| #define | CALC_ERR_BAD_ASSIGNMENT 3 |
| Bad assignment target. | |
| #define | CALC_ERR_BAD_SEPERATOR 4 |
| Comma without parentheses. | |
| #define | CALC_ERR_PAREN_NOT_OPEN 5 |
| Close parenthesis without open. | |
| #define | CALC_ERR_PAREN_OPEN 6 |
| Open parenthesis at end of expression. | |
| #define | CALC_ERR_CONDITIONAL 7 |
| Unbalanced conditional ?: operators. | |
| #define | CALC_ERR_INCOMPLETE 8 |
| Incomplete expression, operand missing. | |
| #define | CALC_ERR_UNDERFLOW 9 |
| Runtime stack would underflow. | |
| #define | CALC_ERR_OVERFLOW 10 |
| Runtime stack would overflow. | |
| #define | CALC_ERR_SYNTAX 11 |
| Syntax error. | |
| #define | CALC_ERR_NULL_ARG 12 |
| NULL or empty input argument. | |
| #define | CALC_ERR_INTERNAL 13 |
| Internal error, bad element type. | |
Functions | |
| LIBCOM_API long | postfix (const char *pinfix, char *ppostfix, short *perror) |
| Compile an infix expression into postfix byte-code. More... | |
| LIBCOM_API long | calcPerform (double *parg, double *presult, const char *ppostfix) |
| Run the calculation engine. More... | |
| LIBCOM_API long | calcArgUsage (const char *ppostfix, unsigned long *pinputs, unsigned long *pstores) |
| Find the inputs and outputs of an expression. More... | |
| LIBCOM_API const char * | calcErrorStr (short error) |
| Convert an error code to a string. More... | |
| LIBCOM_API void | calcExprDump (const char *pinst) |
| Disassemble a postfix expression. More... | |
Defines macros and the routines provided by the calculation engine for subsystems that need to evaluate mathematical expressions.
Definition in file postfix.h.
| #define INFIX_TO_POSTFIX_SIZE | ( | n | ) | ((n)*21/6) |
This macro calculates the maximum size of postfix buffer needed for an infix expression buffer of a given size. The argument n must count the trailing nil byte in the input expression string. The actual size needed is never larger than this value, although it is actually a few bytes smaller for some sizes.
The maximum expansion from infix to postfix is for the sub-expression
which is 6 characters long and results in 21 bytes of postfix:
For other short expressions the factor 21/6 always gives a big enough postfix buffer (proven by hand, look at '1+' and '.1+' as well).
| #define MAX_INFIX_SIZE 100 |
| #define MAX_POSTFIX_SIZE INFIX_TO_POSTFIX_SIZE(MAX_INFIX_SIZE) |
| LIBCOM_API long postfix | ( | const char * | pinfix, |
| char * | ppostfix, | ||
| short * | perror | ||
Converts an expression from an infix string to postfix byte-code
| pinfix | Pointer to the infix string |
| ppostfix | Pointer to the postfix buffer |
| perror | Place to return an error code |
It is the caller's responsibility to ensure that ppostfix points to sufficient storage to hold the postfix expression. The macro INFIX_TO_POSTFIX_SIZE(n) can be used to calculate an appropriate postfix buffer size from the length of the infix buffer.
***Arithmetic Operators*** The usual binary arithmetic operators are provided: + - * and / with their usual relative precedence and left-to-right associativity, and - may also be used as a unary negate operator where it has a higher precedence and associates from right to left. There is no unary plus operator, so numeric literals cannot begin with a + sign.
Three other binary operators are also provided: % is the integer modulo operator, while the synonymous operators ** and ^ raise their left operand to the power of the right operand. % has the same precedence and associativity as * and /, while the power operators associate left-to-right and have a precedence in between * and unary minus.
| LIBCOM_API long calcPerform | ( | double * | parg, |
| double * | presult, | ||
| const char * | ppostfix | ||
Evaluates the postfix expression against a set ot input values.
| parg | Pointer to an array of double values for the arguments A-L that can appear in the expression. Note that the argument values may be modified if the expression uses the assignment operator. |
| presult | Where to put the calculated result, which may be a NaN or Infinity. |
| ppostfix | The postfix expression created by postfix(). |
| LIBCOM_API long calcArgUsage | ( | const char * | ppostfix, |
| unsigned long * | pinputs, | ||
| unsigned long * | pstores | ||
Software using the calc subsystem may need to know what expression arguments are used and/or modified by a particular expression. It can discover this from the postfix string by calling calcArgUsage(), which takes two pointers pinputs and pstores to a pair of unsigned long bitmaps which return that information to the caller. Passing a NULL value for either of these pointers is legal if only the other is needed.
The least significant bit (bit 0) of the bitmap at *pinputs will be set if the expression depends on the argument A, and so on through bit 11 for the argument L. An argument that is not used until after a value has been assigned to it will not be set in the pinputs bitmap, thus the bits can be used to determine whether a value needs to be supplied for their associated argument or not for the purposes of evaluating the expression.
Bit 0 of the bitmap at *pstores will be set if the expression assigns a value to the argument A, bit 1 for argument B etc.
| ppostfix | A postfix expression created by postfix(). |
| pinputs | Bitmap pointer. |
| pstores | Bitmap pointer. |
| LIBCOM_API const char* calcErrorStr | ( | short | error | ) |
Gives out a printable version of an individual error code. The error codes are macros defined here with names starting CALC_ERR_
| error | Error code |
| LIBCOM_API void calcExprDump | ( | const char * | pinst | ) |
Convert the byte-code stream to text and print to stdout.
| pinst | postfix instructions |
1.8.5
