EPICS Base
7.0.6.1
Common routines and macros used by other YAJL APIs. More...
#include <stddef.h>#include <libComAPI.h>#include <epicsVersion.h>
Classes | |
| struct | yajl_alloc_funcs |
Macros | |
| #define | EPICS_YAJL_VERSION VERSION_INT(2,2,0,0) |
| #define | HAS_JSON5 |
| #define | YAJL_MAX_DEPTH 128 |
| #define | YAJL_API LIBCOM_API |
Typedefs | |
| typedef void *(* | yajl_malloc_func )(void *ctx, size_t sz) |
| typedef void(* | yajl_free_func )(void *ctx, void *ptr) |
| typedef void *(* | yajl_realloc_func )(void *ctx, void *ptr, size_t sz) |
Definition in file yajl_common.h.
| #define EPICS_YAJL_VERSION VERSION_INT(2,2,0,0) |
YAJL API history in brief
This macro was not defined in the YAJL 1.0.12 version that was bundled with EPICS Base 3.15.0.1
***YAJL 2.1.0***
int to long long unsigned to size_t ***YAJL 2.2.0*** This version adds support for JSON5 parsing and generation. The upstream YAJL repository is no longer being maintained and the original author no longer responds to messages, so while this code has been offered for merging into the upstream it is unlikely that will ever happen. The version number here is thus an EPICS-specific construct.
Definition at line 55 of file yajl_common.h.
| #define HAS_JSON5 |
A macro to make it easy to conditionally compile code that supports older releases.
Definition at line 60 of file yajl_common.h.
| #define YAJL_MAX_DEPTH 128 |
A limit used by the generator API, YAJL_MAX_DEPTH is the maximum depth to which arrays and maps may be nested.
Definition at line 65 of file yajl_common.h.
| #define YAJL_API LIBCOM_API |
Marks a yajl routine for export from the DLL/shared library.
Definition at line 68 of file yajl_common.h.
| typedef void*(* yajl_malloc_func)(void *ctx, size_t sz) |
Pointer to a malloc() function, supporting client overriding memory allocation routines
Definition at line 72 of file yajl_common.h.
| typedef void(* yajl_free_func)(void *ctx, void *ptr) |
Pointer to a free() function, supporting client overriding memory allocation routines
Definition at line 76 of file yajl_common.h.
| typedef void*(* yajl_realloc_func)(void *ctx, void *ptr, size_t sz) |
Pointer to a realloc() function which can resize an allocation.
Definition at line 79 of file yajl_common.h.
1.8.5
