EPICS Base
7.0.7.0
A hash table. Do not use for new code. More...
Classes | |
| struct | ITEM |
| Internal: bucket item structure. More... | |
| struct | BUCKET |
| Internal: Hash table structure. More... | |
Macros | |
Status values returned by some bucketLib functions | |
| #define | BUCKET_SUCCESS S_bucket_success |
| A synonym for S_bucket_success. | |
| #define | S_bucket_success 0 |
| Success, must be 0. | |
| #define | S_bucket_noMemory (M_bucket | 1) /*Memory allocation failed*/ |
| Memory allocation failed. | |
| #define | S_bucket_idInUse (M_bucket | 2) /*Identifier already in use*/ |
| Identifier already in use. | |
| #define | S_bucket_uknId (M_bucket | 3) /*Unknown identifier*/ |
| Unknown identifier. | |
Typedefs | |
| typedef unsigned | BUCKETID |
| Internal: bucket identifier. | |
Enumerations | |
| enum | buckTypeOfId { bidtUnsigned, bidtPointer, bidtString } |
| Internal: bucket key type. | |
Functions | |
| LIBCOM_API BUCKET *epicsStdCall | bucketCreate (unsigned nHashTableEntries) |
| Creates a new hash table. More... | |
| LIBCOM_API int epicsStdCall | bucketFree (BUCKET *prb) |
| Release memory used by a hash table. More... | |
| LIBCOM_API int epicsStdCall | bucketShow (BUCKET *prb) |
| Display information about a hash table. More... | |
| LIBCOM_API int epicsStdCall | bucketAddItemUnsignedId (BUCKET *prb, const unsigned *pId, const void *pApp) |
| Add an item identified by an unsigned int to the table. More... | |
| LIBCOM_API int epicsStdCall | bucketAddItemPointerId (BUCKET *prb, void *const *pId, const void *pApp) |
| Add an item identified by a pointer to the table. More... | |
| LIBCOM_API int epicsStdCall | bucketAddItemStringId (BUCKET *prb, const char *pId, const void *pApp) |
| Add an item identified by a string to the table. More... | |
| LIBCOM_API int epicsStdCall | bucketRemoveItemUnsignedId (BUCKET *prb, const unsigned *pId) |
| Remove an item identified by a string from the table. More... | |
| LIBCOM_API int epicsStdCall | bucketRemoveItemPointerId (BUCKET *prb, void *const *pId) |
| Remove an item identified by a pointer from the table. More... | |
| LIBCOM_API int epicsStdCall | bucketRemoveItemStringId (BUCKET *prb, const char *pId) |
| LIBCOM_API void *epicsStdCall | bucketLookupItemUnsignedId (BUCKET *prb, const unsigned *pId) |
| Find an item identified by an unsigned int in the table. More... | |
| LIBCOM_API void *epicsStdCall | bucketLookupItemPointerId (BUCKET *prb, void *const *pId) |
| Find an item identified by a pointer in the table. More... | |
| LIBCOM_API void *epicsStdCall | bucketLookupItemStringId (BUCKET *prb, const char *pId) |
| Find an item identified by a string in the table. More... | |
| LIBCOM_API void *epicsStdCall | bucketLookupAndRemoveItemUnsignedId (BUCKET *prb, const unsigned *pId) |
| Find and delete an item identified by an unsigned int from the table. More... | |
| LIBCOM_API void *epicsStdCall | bucketLookupAndRemoveItemPointerId (BUCKET *prb, void *const *pId) |
| Find and delete an item identified by a pointer from the table. More... | |
| LIBCOM_API void *epicsStdCall | bucketLookupAndRemoveItemStringId (BUCKET *prb, const char *pId) |
| Find and delete an item identified by a string from the table. More... | |
A hash table for which keys may be unsigned integers, pointers, or strings. This API is used by the IOC's Channel Access Server, but it should not be used by other code.
Definition in file bucketLib.h.
| LIBCOM_API BUCKET* epicsStdCall bucketCreate | ( | unsigned | nHashTableEntries | ) |
| nHashTableEntries | Table size |
| LIBCOM_API int epicsStdCall bucketFree | ( | BUCKET * | prb | ) |
| *prb | Pointer to the hash table |
| LIBCOM_API int epicsStdCall bucketShow | ( | BUCKET * | prb | ) |
| LIBCOM_API int epicsStdCall bucketAddItemUnsignedId | ( | BUCKET * | prb, |
| const unsigned * | pId, | ||
| const void * | pApp | ||
| *pId | Pointer to the identifier |
| *pApp | Pointer to the payload |
| LIBCOM_API int epicsStdCall bucketAddItemPointerId | ( | BUCKET * | prb, |
| void *const * | pId, | ||
| LIBCOM_API int epicsStdCall bucketAddItemStringId | ( | BUCKET * | prb, |
| const char * | pId, | ||
| LIBCOM_API int epicsStdCall bucketRemoveItemUnsignedId | ( | BUCKET * | prb, |
| const unsigned * | pId | ||
| LIBCOM_API int epicsStdCall bucketRemoveItemPointerId | ( | BUCKET * | prb, |
| void *const * | pId | ||
| LIBCOM_API int epicsStdCall bucketRemoveItemStringId | ( | BUCKET * | prb, |
| const char * | pId | ||
| LIBCOM_API void* epicsStdCall bucketLookupItemUnsignedId | ( | BUCKET * | prb, |
| LIBCOM_API void* epicsStdCall bucketLookupItemPointerId | ( | BUCKET * | prb, |
| LIBCOM_API void* epicsStdCall bucketLookupItemStringId | ( | BUCKET * | prb, |
| LIBCOM_API void* epicsStdCall bucketLookupAndRemoveItemUnsignedId | ( | BUCKET * | prb, |
| LIBCOM_API void* epicsStdCall bucketLookupAndRemoveItemPointerId | ( | BUCKET * | prb, |
| LIBCOM_API void* epicsStdCall bucketLookupAndRemoveItemStringId | ( | BUCKET * | prb, |
1.8.5
