EPICS Base
7.0.7.0
The dbChannel API gives access to record fields. More...
#include "dbDefs.h"#include "dbAddr.h"#include "ellLib.h"#include "epicsTypes.h"#include "errMdef.h"#include "db_field_log.h"#include "dbEvent.h"#include "dbCoreAPI.h"
Classes | |
| struct | evSubscrip |
| struct | dbChannel |
| A Database Channel object. More... | |
| struct | chFilterIf |
| Channel Filter Interface. More... | |
| struct | chFilterPlugin |
| Filter plugin data. More... | |
| struct | chFilter |
| Filter instance data. More... | |
Macros | |
dbChannel Inspection Macros | |
| #define | dbChannelName(pChan) ((pChan)->name) |
| Name that defined the channel. More... | |
| #define | dbChannelRecord(pChan) ((pChan)->addr.precord) |
| Record the channel connects to. More... | |
| #define | dbChannelFldDes(pChan) ((pChan)->addr.pfldDes) |
| Field descriptor for the field pointed to. More... | |
| #define | dbChannelElements(pChan) ((pChan)->addr.no_elements) |
| Number of array elements in the field. More... | |
| #define | dbChannelFieldType(pChan) ((pChan)->addr.field_type) |
| Data type (DBF type) of the field. More... | |
| #define | dbChannelExportType(pChan) ((pChan)->addr.dbr_field_type) |
| Request type (DBR type) of the field. More... | |
| #define | dbChannelExportCAType(pChan) (dbDBRnewToDBRold[dbChannelExportType(pChan)]) |
| CA data type of the field. More... | |
| #define | dbChannelFieldSize(pChan) ((pChan)->addr.field_size) |
| Field (element if array) size in bytes. More... | |
| #define | dbChannelFinalElements(pChan) ((pChan)->final_no_elements) |
| Array length after filtering. More... | |
| #define | dbChannelFinalFieldType(pChan) ((pChan)->final_type) |
| Data type after filtering. More... | |
| #define | dbChannelFinalCAType(pChan) (dbDBRnewToDBRold[(pChan)->final_type]) |
| Channel CA data type after filtering. More... | |
| #define | dbChannelFinalFieldSize(pChan) ((pChan)->final_field_size) |
| Field/element size after filtering, in bytes. More... | |
| #define | dbChannelSpecial(pChan) ((pChan)->addr.special) |
| Field special attribute. More... | |
| #define | dbChannelField(pChan) ((pChan)->addr.pfield) |
| Pointer to the record field. More... | |
Typedefs | |
| typedef db_field_log *( | chPostEventFunc )(void *pvt, dbChannel *chan, db_field_log *pLog) |
| Event filter function type. More... | |
Enumerations | |
| enum | parse_result { parse_stop, parse_continue } |
| Result returned by chFilterIf parse routines. More... | |
Functions | |
| DBCORE_API void | dbChannelInit (void) |
| Initialize the dbChannel subsystem. | |
| DBCORE_API void | dbChannelExit (void) |
| Cleanup the dbChannel subsystem. | |
| DBCORE_API long | dbChannelTest (const char *name) |
| Test the given PV name for existance. More... | |
| DBCORE_API dbChannel * | dbChannelCreate (const char *name) |
| Create a dbChannel object for the given PV name. More... | |
| DBCORE_API long | dbChannelOpen (dbChannel *chan) |
| Open a dbChannel for doing I/O. More... | |
dbChannel Operation Functions | |
| DBCORE_API long | dbChannelGet (dbChannel *chan, short type, void *pbuffer, long *options, long *nRequest, void *pfl) |
| dbGet() through a dbChannel. More... | |
| DBCORE_API long | dbChannelGetField (dbChannel *chan, short type, void *pbuffer, long *options, long *nRequest, void *pfl) |
| dbGetField() through a dbChannel. More... | |
| DBCORE_API long | dbChannelPut (dbChannel *chan, short type, const void *pbuffer, long nRequest) |
| dbPut() through a dbChannel. More... | |
| DBCORE_API long | dbChannelPutField (dbChannel *chan, short type, const void *pbuffer, long nRequest) |
| dbPutField() through a dbChannel. More... | |
| DBCORE_API void | dbChannelShow (dbChannel *chan, int level, const unsigned short indent) |
| Print report on a channel. More... | |
| DBCORE_API void | dbChannelFilterShow (dbChannel *chan, int level, const unsigned short indent) |
| Print report on a channel's filters. More... | |
| DBCORE_API void | dbChannelDelete (dbChannel *chan) |
| Delete a channel. More... | |
Other routines | |
| DBCORE_API void | dbRegisterFilter (const char *key, const chFilterIf *fif, void *puser) |
| DBCORE_API db_field_log * | dbChannelRunPreChain (dbChannel *chan, db_field_log *pLogIn) |
| DBCORE_API db_field_log * | dbChannelRunPostChain (dbChannel *chan, db_field_log *pLogIn) |
| DBCORE_API const chFilterPlugin * | dbFindFilter (const char *key, size_t len) |
| DBCORE_API void | dbChannelGetArrayInfo (dbChannel *chan, void **pfield, long *no_elements, long *offset) |
Variables | |
| DBCORE_API unsigned short | dbDBRnewToDBRold [] |
| Request (DBR) type conversion array. More... | |
The dbChannel API is used internally by the IOC and by link types, device support and IOC servers (RSRV and QSRV) to access record fields, either directly or through one or more server-side filters as specified in the channel name used when creating the channel.
Definition in file dbChannel.h.
| #define dbChannelName | ( | pChan | ) | ((pChan)->name) |
| pChan | Pointer to the dbChannel object. |
Definition at line 374 of file dbChannel.h.
| #define dbChannelRecord | ( | pChan | ) | ((pChan)->addr.precord) |
Definition at line 381 of file dbChannel.h.
| #define dbChannelFldDes | ( | pChan | ) | ((pChan)->addr.pfldDes) |
Definition at line 388 of file dbChannel.h.
| #define dbChannelElements | ( | pChan | ) | ((pChan)->addr.no_elements) |
Definition at line 395 of file dbChannel.h.
| #define dbChannelFieldType | ( | pChan | ) | ((pChan)->addr.field_type) |
Definition at line 402 of file dbChannel.h.
| #define dbChannelExportType | ( | pChan | ) | ((pChan)->addr.dbr_field_type) |
Definition at line 409 of file dbChannel.h.
| #define dbChannelExportCAType | ( | pChan | ) | (dbDBRnewToDBRold[dbChannelExportType(pChan)]) |
Definition at line 416 of file dbChannel.h.
| #define dbChannelFieldSize | ( | pChan | ) | ((pChan)->addr.field_size) |
Definition at line 423 of file dbChannel.h.
| #define dbChannelFinalElements | ( | pChan | ) | ((pChan)->final_no_elements) |
Definition at line 430 of file dbChannel.h.
| #define dbChannelFinalFieldType | ( | pChan | ) | ((pChan)->final_type) |
Definition at line 437 of file dbChannel.h.
| #define dbChannelFinalCAType | ( | pChan | ) | (dbDBRnewToDBRold[(pChan)->final_type]) |
Definition at line 444 of file dbChannel.h.
| #define dbChannelFinalFieldSize | ( | pChan | ) | ((pChan)->final_field_size) |
Definition at line 450 of file dbChannel.h.
| #define dbChannelSpecial | ( | pChan | ) | ((pChan)->addr.special) |
Definition at line 457 of file dbChannel.h.
| #define dbChannelField | ( | pChan | ) | ((pChan)->addr.pfield) |
Channel filters do not get to interpose here since there are many places where the field pointer is compared with the address of a specific record field, so they can't modify the pointer value.
Definition at line 467 of file dbChannel.h.
| typedef db_field_log*( chPostEventFunc)(void *pvt, dbChannel *chan, db_field_log *pLog) |
Prototype for channel event filter functions.
When these functions are called the scan lock for the record associated with chan may already be locked, but they must use dbfl_has_copy() to determine whether the data in pLog belongs to the record. If that returns 0 the function must call dbScanLock() before accessing the data.
A filter function owns the field log pLog when called. To discard an update it should free the field log using db_delete_field_log() and return NULL.
Definition at line 93 of file dbChannel.h.
| enum parse_result |
The parsing functions from a chFilterIf must return either parse_stop (in event of an error) or parse_continue.
Definition at line 100 of file dbChannel.h.
| DBCORE_API long dbChannelTest | ( | const char * | name | ) |
This routine looks up the given record and field name, but does not check whether any field modifiers given after the field name are correct. This is sufficient for the correct server to quickly direct searches to the IOC that owns that PV name. Field modifiers will be checked when dbChannelCreate() is later called with the same name.
| name | Channel name. |
| DBCORE_API dbChannel* dbChannelCreate | ( | const char * | name | ) |
| DBCORE_API long dbChannelOpen | ( | dbChannel * | chan | ) |
| chan | Pointer to the dbChannel object. |
| DBCORE_API long dbChannelGet | ( | dbChannel * | chan, |
| short | type, | ||
| void * | pbuffer, | ||
| long * | options, | ||
| long * | nRequest, | ||
| void * | pfl | ||
Calls dbGet() for the field that chan refers to. Only call this routine if the record is already locked.
| [in] | chan | Pointer to the dbChannel object. |
| [in] | type | Request type from dbFldTypes.h. |
| [out] | pbuffer | Pointer to data buffer. |
| [in,out] | options | Request options from dbAccessDefs.h. |
| [in,out] | nRequest | Pointer to the element count. |
| [in] | pfl | Pointer to a db_field_log or NULL. |
| DBCORE_API long dbChannelGetField | ( | dbChannel * | chan, |
| short | type, | ||
| void * | pfl | ||
Get values from a PV through a channel. This routine locks the record, calls dbChannelGet(), then unlocks the record again.
| DBCORE_API long dbChannelPut | ( | dbChannel * | chan, |
| short | type, | ||
| const void * | pbuffer, | ||
| long | nRequest | ||
Put values to a PV through a channel. Only call this routine if the record is already locked. Calls dbPut() for the field that chan refers to.
| chan[in] | Pointer to the dbChannel object. |
| type[in] | Request type from dbFldTypes.h. |
| pbuffer[in] | Pointer to data buffer. |
| nRequest[in] | Number of elements in pbuffer. |
| DBCORE_API long dbChannelPutField | ( | dbChannel * | chan, |
| short | type, | ||
Put values to a PV through a channel. This routine calls dbPutField() for the field that chan refers to.
| DBCORE_API void dbChannelShow | ( | dbChannel * | chan, |
| int | level, | ||
| const unsigned short | indent | ||
Print information about the channel to stdout.
| level | Higher levels may provide more detail. |
| indent | Indent all lines by this many spaces. |
| DBCORE_API void dbChannelFilterShow | ( | dbChannel * | chan, |
| int | level, | ||
Print information about the channel's filters to stdout.
| DBCORE_API void dbChannelDelete | ( | dbChannel * | chan | ) |
Releases resources owned by this channel and its filters.
| DBCORE_API unsigned short dbDBRnewToDBRold[] |
This converter array is declared in db_convert.h but redeclared here as it is needed by the dbChannel...CAType macros defined here.
1.8.5
