EPICS Base
7.0.7.0
APIs for the epicsEvent binary semaphore. More...
#include "libComAPI.h"#include "osdEvent.h"
Classes | |
| class | epicsEvent |
| A binary semaphore. More... | |
Macros | |
| #define | epicsEventWaitStatus epicsEventStatus |
| Old name provided for backwards compatibility. | |
| #define | epicsEventWaitOK epicsEventOK |
| #define | epicsEventWaitError epicsEventError |
| #define | epicsEventSignal(ID) epicsEventMustTrigger(ID) |
| A synonym for epicsEventTrigger(). More... | |
Typedefs | |
| typedef struct epicsEventOSD * | epicsEventId |
| An identifier for an epicsEvent for use with the C API. | |
Enumerations | |
| enum | epicsEventStatus { epicsEventOK = 0, epicsEventWaitTimeout, epicsEventError } |
| Return status from several C API routines. | |
| enum | epicsEventInitialState { epicsEventEmpty, epicsEventFull } |
| Possible initial states of a new epicsEvent. | |
Functions | |
| LIBCOM_API epicsEventId | epicsEventCreate (epicsEventInitialState initialState) |
| Create an epicsEvent for use from C code, or return NULL. More... | |
| LIBCOM_API epicsEventId | epicsEventMustCreate (epicsEventInitialState initialState) |
| Create an epicsEvent for use from C code. More... | |
| LIBCOM_API void | epicsEventDestroy (epicsEventId id) |
| Destroy an epicsEvent and any resources it holds. More... | |
| LIBCOM_API epicsEventStatus | epicsEventTrigger (epicsEventId id) |
| Trigger an event i.e. ensures the next or current call to wait completes. More... | |
| LIBCOM_API void | epicsEventMustTrigger (epicsEventId id) |
| Trigger an event. More... | |
| LIBCOM_API epicsEventStatus | epicsEventWait (epicsEventId id) |
| Wait for an event. More... | |
| LIBCOM_API void | epicsEventMustWait (epicsEventId id) |
| Wait for an event (see epicsEventWait()). More... | |
| LIBCOM_API epicsEventStatus | epicsEventWaitWithTimeout (epicsEventId id, double timeout) |
| Wait an the event or until the specified timeout period is over. More... | |
| LIBCOM_API epicsEventStatus | epicsEventTryWait (epicsEventId id) |
Similar to wait() except that if the event is currently empty the call will return immediately with status epicsEventWaitTimeout. More... | |
| LIBCOM_API void | epicsEventShow (epicsEventId id, unsigned int level) |
| Display information about the semaphore. More... | |
Defines the C++ and C API's for a simple binary semaphore. If multiple threads are waiting on the same event, only one of them will be woken when the event is signaled.
The primary use of an event semaphore is for thread synchronization. An example of using an event semaphore is a consumer thread that processes requests from one or more producer threads. For example:
When creating the consumer thread also create an epicsEvent.
The consumer thread has code containing:
Producers create requests and issue the statement:
Definition in file epicsEvent.h.
| #define epicsEventSignal | ( | ID | ) | epicsEventMustTrigger(ID) |
| ID | The event identifier. |
Definition at line 175 of file epicsEvent.h.
| LIBCOM_API epicsEventId epicsEventCreate | ( | epicsEventInitialState | initialState | ) |
| initialState | Starting state, epicsEventEmpty or epicsEventFull. |
| LIBCOM_API epicsEventId epicsEventMustCreate | ( | epicsEventInitialState | initialState | ) |
This routine does not return if the object could not be created.
| LIBCOM_API void epicsEventDestroy | ( | epicsEventId | id | ) |
No calls to any epicsEventWait routines can be active when this call is made.
| id | The event identifier. |
| LIBCOM_API epicsEventStatus epicsEventTrigger | ( | epicsEventId | id | ) |
| LIBCOM_API void epicsEventMustTrigger | ( | epicsEventId | id | ) |
This routine does not return if the identifier is invalid.
| LIBCOM_API epicsEventStatus epicsEventWait | ( | epicsEventId | id | ) |
| LIBCOM_API void epicsEventMustWait | ( | epicsEventId | id | ) |
| LIBCOM_API epicsEventStatus epicsEventWaitWithTimeout | ( | epicsEventId | id, |
| double | timeout | ||
| timeout | The timeout delay in seconds. A timeout of zero is equivalent to calling epicsEventTryWait(); NaN or any value too large to be represented to the target OS is equivalent to no timeout. |
| LIBCOM_API epicsEventStatus epicsEventTryWait | ( | epicsEventId | id | ) |
epicsEventWaitTimeout when the event is empty. | LIBCOM_API void epicsEventShow | ( | epicsEventId | id, |
| unsigned int | level | ||
| level | An unsigned int for the level of information to be displayed. |
1.8.5
