EPICS Base  7.0.7.0
epicsRingBytes.h
1 /*************************************************************************\
2 * Copyright (c) 2002 The University of Chicago, as Operator of Argonne
3 * National Laboratory.
4 * Copyright (c) 2002 The Regents of the University of California, as
5 * Operator of Los Alamos National Laboratory.
6 * Copyright (c) 2012 ITER Organization.
7 * SPDX-License-Identifier: EPICS
8 * EPICS BASE is distributed subject to a Software License Agreement found
9 * in file LICENSE that is included with this distribution.
10 \*************************************************************************/
28 #ifndef INCepicsRingBytesh
29 #define INCepicsRingBytesh
30
31 #ifdef __cplusplus
32 extern "C" {
33 #endif
34
35 #include "libComAPI.h"
36
38 typedef void *epicsRingBytesId;
39 typedef void const *epicsRingBytesIdConst;
40
46 LIBCOM_API epicsRingBytesId epicsStdCall epicsRingBytesCreate(int nbytes);
52 LIBCOM_API epicsRingBytesId epicsStdCall epicsRingBytesLockedCreate(int nbytes);
57 LIBCOM_API void epicsStdCall epicsRingBytesDelete(epicsRingBytesId id);
65 LIBCOM_API int epicsStdCall epicsRingBytesGet(
66  epicsRingBytesId id, char *value,int nbytes);
74 LIBCOM_API int epicsStdCall epicsRingBytesPut(
75  epicsRingBytesId id, char *value,int nbytes);
81 LIBCOM_API void epicsStdCall epicsRingBytesFlush(epicsRingBytesId id);
87 LIBCOM_API int epicsStdCall epicsRingBytesFreeBytes(epicsRingBytesId id);
93 LIBCOM_API int epicsStdCall epicsRingBytesUsedBytes(epicsRingBytesId id);
100 LIBCOM_API int epicsStdCall epicsRingBytesSize(epicsRingBytesId id);
106 LIBCOM_API int epicsStdCall epicsRingBytesIsEmpty(epicsRingBytesId id);
112 LIBCOM_API int epicsStdCall epicsRingBytesIsFull(epicsRingBytesId id);
122 LIBCOM_API int epicsStdCall epicsRingBytesHighWaterMark(epicsRingBytesIdConst id);
129 LIBCOM_API void epicsStdCall epicsRingBytesResetHighWaterMark(epicsRingBytesId id);
130
131 #ifdef __cplusplus
132 }
133 #endif
134
135
136 #endif /* INCepicsRingBytesh */
LIBCOM_API int epicsStdCall epicsRingBytesGet(epicsRingBytesId id, char *value, int nbytes)
Read data out of the ring buffer.
Definition: link.h:175
Make the ring buffer empty.
Test if the ring buffer is currently full.
LIBCOM_API int epicsStdCall epicsRingBytesPut(epicsRingBytesId id, char *value, int nbytes)
Write data into the ring buffer.
Delete the ring buffer and free any associated memory.
Create a new ring buffer, secured by a spinlock.
Return the number of bytes currently stored in the ring buffer.
Create a new ring buffer.
Return the size of the ring buffer.
Return the number of free bytes in the ring buffer.
Reset the Highwater mark of the ring buffer.
See how full a ring buffer has been since it was last checked.
void * epicsRingBytesId
An identifier for a ring buffer.
Test if the ring buffer is currently empty.
