EPICS Base
7.0.7.0
A circular buffer to store pointers. More...
Classes | |
| class | epicsRingPointer< T > |
| A C++ template class providing methods for creating and using a ring buffer (a first in, first out circular buffer) that stores pointers to objects of the template type. More... | |
Macros | |
| #define | epicsRingPointerSize epicsRingPointerGetSize |
Typedefs | |
| typedef void * | epicsRingPointerId |
| An identifier for the C API to a ring buffer storing pointers. | |
| typedef void const * | epicsRingPointerIdConst |
Functions | |
| LIBCOM_API epicsRingPointerId epicsStdCall | epicsRingPointerCreate (int size) |
| Create a new ring buffer. More... | |
| LIBCOM_API epicsRingPointerId epicsStdCall | epicsRingPointerLockedCreate (int size) |
| Create a new ring buffer, secured by a spinlock. More... | |
| LIBCOM_API void epicsStdCall | epicsRingPointerDelete (epicsRingPointerId id) |
| Delete the ring buffer and free any associated memory. More... | |
| LIBCOM_API int epicsStdCall | epicsRingPointerPush (epicsRingPointerId id, void *p) |
| Push pointer into the ring buffer. More... | |
| LIBCOM_API void *epicsStdCall | epicsRingPointerPop (epicsRingPointerId id) |
| Take an element off the ring. More... | |
| LIBCOM_API void epicsStdCall | epicsRingPointerFlush (epicsRingPointerId id) |
| Remove all elements from the ring. More... | |
| LIBCOM_API int epicsStdCall | epicsRingPointerGetFree (epicsRingPointerId id) |
| Return the amount of empty space in the ring buffer. More... | |
| LIBCOM_API int epicsStdCall | epicsRingPointerGetUsed (epicsRingPointerId id) |
| Return the number of elements stored in the ring buffer. More... | |
| LIBCOM_API int epicsStdCall | epicsRingPointerGetSize (epicsRingPointerId id) |
| Return the size of the ring. More... | |
| LIBCOM_API int epicsStdCall | epicsRingPointerIsEmpty (epicsRingPointerId id) |
| Check if the ring buffer is currently empty. More... | |
| LIBCOM_API int epicsStdCall | epicsRingPointerIsFull (epicsRingPointerId id) |
| Check if the ring buffer is currently full. More... | |
| LIBCOM_API int epicsStdCall | epicsRingPointerGetHighWaterMark (epicsRingPointerIdConst id) |
| Get the Highwater mark of the ring buffer. More... | |
| LIBCOM_API void epicsStdCall | epicsRingPointerResetHighWaterMark (epicsRingPointerId id) |
| Reset the Highwater mark of the ring buffer. More... | |
epicsRingPointer.h provides both C and C++ APIs for creating and using ring buffers (first in first out circular buffers) that store pointers. The unlocked kind is designed so that one writer thread and one reader thread can access the ring simultaneously without requiring mutual exclusion. The locked variant uses an epicsSpinLock, and works with any numbers of writer and reader threads.
Definition in file epicsRingPointer.h.
| LIBCOM_API epicsRingPointerId epicsStdCall epicsRingPointerCreate | ( | int | size | ) |
| size | Size of ring buffer to create |
| LIBCOM_API epicsRingPointerId epicsStdCall epicsRingPointerLockedCreate | ( | int | size | ) |
| LIBCOM_API void epicsStdCall epicsRingPointerDelete | ( | epicsRingPointerId | id | ) |
| id | Ring buffer identifier |
| LIBCOM_API int epicsStdCall epicsRingPointerPush | ( | epicsRingPointerId | id, |
| void * | p | ||
| p | Pointer to be pushed to the ring |
| LIBCOM_API void* epicsStdCall epicsRingPointerPop | ( | epicsRingPointerId | id | ) |
| LIBCOM_API void epicsStdCall epicsRingPointerFlush | ( | epicsRingPointerId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingPointerGetFree | ( | epicsRingPointerId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingPointerGetUsed | ( | epicsRingPointerId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingPointerGetSize | ( | epicsRingPointerId | id | ) |
size given when the ring was created. | LIBCOM_API int epicsStdCall epicsRingPointerIsEmpty | ( | epicsRingPointerId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingPointerIsFull | ( | epicsRingPointerId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingPointerGetHighWaterMark | ( | epicsRingPointerIdConst | id | ) |
Returns the largest number of elements the ring buffer has held since the water mark was last reset. A new ring buffer starts with a water mark of 0.
| LIBCOM_API void epicsStdCall epicsRingPointerResetHighWaterMark | ( | epicsRingPointerId | id | ) |
The Highwater mark will be set to the current usage
1.8.5
