EPICS Base
7.0.7.0
OS-independent routines for ignoring Posix signals. More...
#include "libComAPI.h"
Functions | |
| LIBCOM_API void epicsStdCall | epicsSignalInstallSigHupIgnore (void) |
| LIBCOM_API void epicsStdCall | epicsSignalInstallSigPipeIgnore (void) |
| LIBCOM_API void epicsStdCall | epicsSignalInstallSigAlarmIgnore (void) |
| LIBCOM_API void epicsStdCall | epicsSignalRaiseSigAlarm (struct epicsThreadOSD *) |
The requests in this interface are typically ignored on OS that do not implement POSIX signals.
Definition in file epicsSignal.h.
| LIBCOM_API void epicsStdCall epicsSignalInstallSigHupIgnore | ( | void | ) |
Ignore the SIGHUP signal. Required to avoid problems with soft IOCs getting SIGHUPs when a Channel Access client disconnects
| LIBCOM_API void epicsStdCall epicsSignalInstallSigPipeIgnore | ( | void | ) |
Ignore the SIGPIPE signal. Required to avoid terminating a process which is blocking in a socket send() call when the SIGPIPE signal is generated by the OS.
| LIBCOM_API void epicsStdCall epicsSignalInstallSigAlarmIgnore | ( | void | ) |
Ignore the SIGALRM signal. Required only if shutdown() and close() do not interrupt a thread blocking in a socket system call
| LIBCOM_API void epicsStdCall epicsSignalRaiseSigAlarm | ( | struct epicsThreadOSD * | ) |
Raise a SIGALRM signal to a specific epicsThread
1.8.5
