EPICS Base
7.0.7.0
#include "libComAPI.h"
Macros | |
| #define | EPICS_STACKTRACE_ADDRESSES (1<<0) |
| #define | EPICS_STACKTRACE_DYN_SYMBOLS (1<<1) |
| #define | EPICS_STACKTRACE_GBL_SYMBOLS (1<<2) |
| #define | EPICS_STACKTRACE_LCL_SYMBOLS (1<<3) |
Functions | |
| LIBCOM_API void | epicsStackTrace (void) |
| Dump a stack trace. More... | |
| LIBCOM_API int | epicsStackTraceGetFeatures (void) |
| Get supported stacktrace features. More... | |
Functions for printing the stack trace
Definition in file epicsStackTrace.h.
| #define EPICS_STACKTRACE_ADDRESSES (1<<0) |
Bit mask to check if stack trace provides numerical addresses.
Definition at line 34 of file epicsStackTrace.h.
| #define EPICS_STACKTRACE_DYN_SYMBOLS (1<<1) |
Bit mask to check if stack trace is able to lookup dynamic symbols.
Definition at line 37 of file epicsStackTrace.h.
| #define EPICS_STACKTRACE_GBL_SYMBOLS (1<<2) |
Bit mask to check if stack trace is able to lookup global symbols
Definition at line 40 of file epicsStackTrace.h.
| #define EPICS_STACKTRACE_LCL_SYMBOLS (1<<3) |
Bit mask to check if stack trace is able to lookup local symbols
Definition at line 43 of file epicsStackTrace.h.
| LIBCOM_API void epicsStackTrace | ( | void | ) |
Dump a stack trace to the errlog.
| LIBCOM_API int epicsStackTraceGetFeatures | ( | void | ) |
Returns an ORed bitset of supported features. Use the EPICS_STACKTRACE_ masks to check if a feature is supported.
1.8.5
