| LIBCOM_API void epicsStdCall | iocshRegister (const iocshFuncDef *piocshFuncDef, iocshCallFunc func) |
| | This function is used to register a command with the IOC shell. More...
| LIBCOM_API void epicsStdCall | iocshRegisterVariable (const iocshVarDef *piocshVarDef) |
LIBCOM_API const iocshCmdDef
*epicsStdCall | iocshFindCommand (const char *name) EPICS_DEPRECATED |
| | Returns a struct of type iocshCmdDef whose element values are determined by the name parameter. This function calls the function registryFind, defined in Registry.h. More...
LIBCOM_API const iocshVarDef
*epicsStdCall | iocshFindVariable (const char *name) |
| | Returns a struct of type iocshVarDef whose element values are determined by the name parameter. This function calls the function registryFind, defined in Registry.h. More...
| LIBCOM_API void epicsStdCall | iocshFree (void) |
| | Frees all memory allocated to registered commands and variables. More...
| LIBCOM_API int epicsStdCall | iocsh (const char *pathname) |
| | This function is used to execute IOC shell commands from a file. More...
| LIBCOM_API int epicsStdCall | iocshCmd (const char *cmd) |
| | This function is used to exectute a single IOC shell command. More...
| LIBCOM_API int epicsStdCall | iocshLoad (const char *pathname, const char *macros) |
| | Read and evaluate IOC shell commands from the given file. A list of macros can be supplied as a parameter. These macros are treated as environment variables during exectution of the file's commands. More...
| LIBCOM_API int epicsStdCall | iocshRun (const char *cmd, const char *macros) |
| | Evaluate a single IOC shell command. A list of macros can be supplied as a parameter. These macros are treated as environment variables during exectution of the command. More...
| LIBCOM_API int | iocshSetError (int err) |
| | Signal error from an IOC shell function. More...
| LIBCOM_API void epicsStdCall | iocshEnvClear (const char *name) |
| | Unsets macro values. More...
The iocsh API provides an interface for running commands in the shell of the IOC, as well as registering commands and variables for use in the shell. It consists of 4 functions for the former and 2 functions for the latter.
- Command functions:
- int iocsh (const char *pathname)
int iocshLoad (const char *pathname, const char *macros)
int iocshCmd (const char *cmd)
int iocshRun (const char *cmd, const char *macros)
- Registration functions:
- void iocshRegister (const iocshFuncDef * piocshFuncDef, iocshCallFunc func)
void epicsStdCall iocshRegisterVariable (const iocshVarDef *piocshVarDef)
Definition in file iocsh.h.
