EPICS Base
7.0.7.0
Client on the IOC that forwards log messages to the log server. More...
Typedefs | |
| typedef void * | logClientId |
| Abstract type that represents handle to the log client. | |
Functions | |
| LIBCOM_API logClientId epicsStdCall | logClientCreate (struct in_addr server_addr, unsigned short server_port) |
| Creates a new log client. More... | |
| LIBCOM_API void epicsStdCall | logClientSend (logClientId id, const char *message) |
| Log message. More... | |
| LIBCOM_API void epicsStdCall | logClientShow (logClientId id, unsigned level) |
| Prints debug information about the log client state. More... | |
| LIBCOM_API void epicsStdCall | logClientFlush (logClientId id) |
| Flushes all outstanding messages. More... | |
| LIBCOM_API void epicsStdCall | iocLogPrefix (const char *prefix) |
| Set prefix to be sent infront of every log message. More... | |
| LIBCOM_API logClientId epicsStdCall | logClientInit (void) |
| DEPRECATED. More... | |
Together with the program iocLogServer, a log client provides generic support for logging text messages from an IOC or other program to the log server host machine.
Definition in file logClient.h.
| LIBCOM_API logClientId epicsStdCall logClientCreate | ( | struct in_addr | server_addr, |
| unsigned short | server_port | ||
Starts a background thread to connect to server and returns immediately. If a connection cannot be established, an error message is printed on the console, but the log client will keep trying to connect in the background. This thread will also periodically (every 5 seconds) flush pending messages out to the server.
| server_addr | log server IP address |
| server_port | log server port |
| LIBCOM_API void epicsStdCall logClientSend | ( | logClientId | id, |
| const char * | message | ||
Logs message to log server. Messages are not immediately sent to the log server. Instead they are sent periodically (every 5 seconds), when the cache overflows, or when logClientFlush() is called. If messages can't sent, an error message will be printed to stderr
| id | log client handle |
| message | log message |
| LIBCOM_API void epicsStdCall logClientShow | ( | logClientId | id, |
| unsigned | level | ||
Print information about the log client's internal state such as, connection status and cache state, to stdout
| level | verbosity level. Level range is from 0 to 2 |
| LIBCOM_API void epicsStdCall logClientFlush | ( | logClientId | id | ) |
Immediately sends all outstanding messages to the server
| LIBCOM_API void epicsStdCall iocLogPrefix | ( | const char * | prefix | ) |
Sets a prefix to prepend every log message. Can only be set once. If already set, this function call will be ignored
| prefix | the prefix |
| LIBCOM_API logClientId epicsStdCall logClientInit | ( | void | ) |
1.8.5
