EPICS Base
7.0.7.0
Declaration of compress record type.
#include <compressRecord.h>
Public Attributes | |
| char | name [61] |
| Record Name. | |
| char | desc [41] |
| Descriptor. | |
| char | asg [29] |
| Access Security Group. | |
| epicsEnum16 | scan |
| Scan Mechanism. | |
| epicsEnum16 | pini |
| Process at iocInit. | |
| epicsInt16 | phas |
| Scan Phase. | |
| char | evnt [40] |
| Event Name. | |
| epicsInt16 | tse |
| Time Stamp Event. | |
| DBLINK | tsel |
| Time Stamp Link. | |
| epicsEnum16 | dtyp |
| Device Type. | |
| epicsInt16 | disv |
| Disable Value. | |
| epicsInt16 | disa |
| Disable. | |
| DBLINK | sdis |
| Scanning Disable. | |
| epicsMutexId | mlok |
| Monitor lock. | |
| ELLLIST | mlis |
| Monitor List. | |
| ELLLIST | bklnk |
| epicsUInt8 | disp |
| Disable putField. | |
| epicsUInt8 | proc |
| Force Processing. | |
| epicsEnum16 | stat |
| Alarm Status. | |
| epicsEnum16 | sevr |
| Alarm Severity. | |
| char | amsg [40] |
| Alarm Message. | |
| epicsEnum16 | nsta |
| New Alarm Status. | |
| epicsEnum16 | nsev |
| New Alarm Severity. | |
| char | namsg [40] |
| New Alarm Message. | |
| epicsEnum16 | acks |
| Alarm Ack Severity. | |
| epicsEnum16 | ackt |
| Alarm Ack Transient. | |
| epicsEnum16 | diss |
| Disable Alarm Sevrty. | |
| epicsUInt8 | lcnt |
| Lock Count. | |
| epicsUInt8 | pact |
| Record active. | |
| epicsUInt8 | putf |
| dbPutField process | |
| epicsUInt8 | rpro |
| Reprocess. | |
| struct asgMember * | asp |
| Access Security Pvt. | |
| pprocessNotify | |
| pprocessNotifyRecord | |
| Scan Private. | |
| Address of RSET. | |
| unambiguous_dset * | dset |
| DSET address. | |
| void * | dpvt |
| Device Private. | |
| Lock Set. | |
| epicsEnum16 | prio |
| Scheduling Priority. | |
| epicsUInt8 | tpro |
| Trace Processing. | |
| epicsUInt8 | bkpt |
| Break Point. | |
| epicsUInt8 | udf |
| Undefined. | |
| epicsEnum16 | udfs |
| Undefined Alarm Sevrty. | |
| epicsTimeStamp | time |
| Time. | |
| epicsUInt64 | utag |
| Time Tag. | |
| DBLINK | flnk |
| Forward Process Link. | |
| void * | val |
| Value. | |
| DBLINK | inp |
| Input Specification. | |
| epicsInt16 | res |
| Reset. | |
| epicsEnum16 | alg |
| Compression Algorithm. | |
| epicsEnum16 | balg |
| Buffering Algorithm. | |
| epicsUInt32 | nsam |
| Number of Values. | |
| epicsUInt32 | n |
| N to 1 Compression. | |
| epicsFloat64 | ihil |
| Init High Interest Lim. | |
| epicsFloat64 | ilil |
| Init Low Interest Lim. | |
| epicsFloat64 | hopr |
| High Operating Range. | |
| epicsFloat64 | lopr |
| Low Operating Range. | |
| epicsInt16 | prec |
| Display Precision. | |
| char | egu [16] |
| Engineering Units. | |
| epicsUInt32 | off |
| Offset. | |
| epicsUInt32 | nuse |
| Number Used. | |
| epicsUInt32 | ouse |
| Old Number Used. | |
| double * | bptr |
| Buffer Pointer. | |
| double * | sptr |
| Summing Buffer Ptr. | |
| double * | wptr |
| Working Buffer Ptr. | |
| epicsInt32 | inpn |
| Number of elements in Working Buffer. | |
| epicsFloat64 | cvb |
| Compress Value Buffer. | |
| epicsUInt32 | inx |
| Current number of readings. | |
Definition at line 42 of file compressRecord.h.
1.8.5
