EPICS Base  7.0.7.0
yajl_gen.h
1 /*
2  * Copyright (c) 2007-2011, Lloyd Hilaiel <[email protected]>
3  *
4  * Permission to use, copy, modify, and/or distribute this software for any
5  * purpose with or without fee is hereby granted, provided that the above
6  * copyright notice and this permission notice appear in all copies.
7  *
8  * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
9  * WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
10  * MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
11  * ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
12  * WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
13  * ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
14  * OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
15  */
16
23 #ifndef __YAJL_GEN_H__
24 #define __YAJL_GEN_H__
25
26 #include "yajl_common.h"
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif
31
32  typedef enum {
57
59  typedef struct yajl_gen_t * yajl_gen;
60
62  typedef void (*yajl_print_t)(void * ctx,
63  const char * str,
64  size_t len);
65
69  typedef enum {
143  } yajl_gen_option;
144
150  YAJL_API int yajl_gen_config(yajl_gen hand, int option, ...);
151
160  YAJL_API yajl_gen yajl_gen_alloc(const yajl_alloc_funcs * allocFuncs);
161
163  YAJL_API void yajl_gen_free(yajl_gen handle);
164
166  YAJL_API yajl_gen_status yajl_gen_integer(yajl_gen hand, long long int number);
175  YAJL_API yajl_gen_status yajl_gen_double(yajl_gen hand, double number);
178  const char * num,
179  size_t len);
182  const unsigned char * str,
183  size_t len);
185  YAJL_API yajl_gen_status yajl_gen_null(yajl_gen hand);
187  YAJL_API yajl_gen_status yajl_gen_bool(yajl_gen hand, int boolean);
198
203  const unsigned char ** buf,
204  size_t * len);
205
209  YAJL_API void yajl_gen_clear(yajl_gen hand);
210
222  YAJL_API void yajl_gen_reset(yajl_gen hand, const char * sep);
223
224 #ifdef __cplusplus
225 }
226 #endif
227
228 #endif
Definition: yajl_gen.h:59
YAJL_API yajl_gen_status yajl_gen_array_close(yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_number(yajl_gen hand, const char *num, size_t len)
#define YAJL_API
Definition: yajl_common.h:68
YAJL_API int yajl_gen_config(yajl_gen hand, int option,...)
YAJL_API yajl_gen_status yajl_gen_map_open(yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_map_close(yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_array_open(yajl_gen hand)
Common routines and macros used by other YAJL APIs.
void(* yajl_print_t)(void *ctx, const char *str, size_t len)
Definition: yajl_gen.h:62
YAJL_API yajl_gen_status yajl_gen_string(yajl_gen hand, const unsigned char *str, size_t len)
YAJL_API void yajl_gen_reset(yajl_gen hand, const char *sep)
yajl_gen_option
Definition: yajl_gen.h:69
YAJL_API yajl_gen_status yajl_gen_get_buf(yajl_gen hand, const unsigned char **buf, size_t *len)
YAJL_API yajl_gen yajl_gen_alloc(const yajl_alloc_funcs *allocFuncs)
yajl_gen_status
Definition: yajl_gen.h:32
