28 #ifndef INCepicsRingPointerh
29 #define INCepicsRingPointerh
33 #include "libComAPI.h"
104 int getUsedNoLock()
const;
108 volatile int nextPush;
109 volatile int nextPop;
112 T *
volatile * buffer;
120 typedef void const *epicsRingPointerIdConst;
208 #define epicsRingPointerSize epicsRingPointerGetSize
221 lock(0), nextPush(0), nextPop(0), size(sz+1), highWaterMark(0),
222 buffer(new T* [sz+1])
240 int newNext = next + 1;
241 if(newNext>=size) newNext=0;
242 if (newNext == nextPop) {
248 int used = getUsedNoLock();
249 if (used > highWaterMark) highWaterMark = used;
259 if (next == nextPush) {
265 if(next >=size) next = 0;
284 int n = nextPop - nextPush - 1;
285 if (n < 0) n += size;
293 int n = nextPush - nextPop;
294 if (n < 0) n += size;
302 int n = getUsedNoLock();
318 isEmpty = (nextPush == nextPop);
327 int count = nextPush - nextPop +1;
329 return((count == 0) || (count == size));
335 return highWaterMark;
342 highWaterMark = getUsedNoLock();
LIBCOM_API void epicsSpinLock(epicsSpinId lockId)
Acquires the spin lock.
T * pop()
Take an element off the ring.
LIBCOM_API int epicsStdCall epicsRingPointerGetFree(epicsRingPointerId id)
Return the amount of empty space in the ring buffer.
LIBCOM_API void epicsStdCall epicsRingPointerFlush(epicsRingPointerId id)
Remove all elements from the ring.
LIBCOM_API epicsRingPointerId epicsStdCall epicsRingPointerLockedCreate(int size)
Create a new ring buffer, secured by a spinlock.
LIBCOM_API void epicsStdCall epicsRingPointerDelete(epicsRingPointerId id)
Delete the ring buffer and free any associated memory.
LIBCOM_API int epicsStdCall epicsRingPointerIsEmpty(epicsRingPointerId id)
Check if the ring buffer is currently empty.
LIBCOM_API int epicsStdCall epicsRingPointerGetUsed(epicsRingPointerId id)
Return the number of elements stored in the ring buffer.
LIBCOM_API epicsSpinId epicsSpinCreate(void)
Creates a spin lock.
int getFree() const
Get how much free space remains in the ring.
LIBCOM_API int epicsStdCall epicsRingPointerPush(epicsRingPointerId id, void *p)
Push pointer into the ring buffer.
struct epicsSpin * epicsSpinId
bool push(T *p)
Push a new entry on the ring.
A C++ template class providing methods for creating and using a ring buffer (a first in...
LIBCOM_API int epicsStdCall epicsRingPointerIsFull(epicsRingPointerId id)
Check if the ring buffer is currently full.
LIBCOM_API void *epicsStdCall epicsRingPointerPop(epicsRingPointerId id)
LIBCOM_API void epicsSpinDestroy(epicsSpinId lockId)
Destroys spin lock.
LIBCOM_API void epicsStdCall epicsRingPointerResetHighWaterMark(epicsRingPointerId id)
Reset the Highwater mark of the ring buffer.
OS independent interface for creating spin locks.
LIBCOM_API int epicsStdCall epicsRingPointerGetHighWaterMark(epicsRingPointerIdConst id)
Get the Highwater mark of the ring buffer.
LIBCOM_API int epicsStdCall epicsRingPointerGetSize(epicsRingPointerId id)
Return the size of the ring.
LIBCOM_API void epicsSpinUnlock(epicsSpinId lockId)
Releases spin lock.
int getHighWaterMark() const
See how full the ring has got since it was last checked.
~epicsRingPointer()
Destructor.
void resetHighWaterMark()
Reset high water mark.
int getSize() const
Get the size of the ring.
LIBCOM_API epicsRingPointerId epicsStdCall epicsRingPointerCreate(int size)
Create a new ring buffer.
int getUsed() const
Get how many elements are stored on the ring.
bool isFull() const
Test if the ring is currently full.
void * epicsRingPointerId
An identifier for the C API to a ring buffer storing pointers.
bool isEmpty() const
Test if the ring is currently empty.
void flush()
