EPICS Base
7.0.8.1
Functions to convert strings to primitive types. More...
#include <stdlib.h>#include <limits.h>#include "libComAPI.h"#include "osdStrtod.h"#include "epicsTypes.h"#include "errMdef.h"
Macros | |
| #define | S_stdlib_noConversion (M_stdlib | 1) /* No digits to convert */ |
| #define | S_stdlib_extraneous (M_stdlib | 2) /* Extraneous characters */ |
| #define | S_stdlib_underflow (M_stdlib | 3) /* Too small to represent */ |
| #define | S_stdlib_overflow (M_stdlib | 4) /* Too large to represent */ |
| #define | S_stdlib_badBase (M_stdlib | 5) /* Number base not supported */ |
| #define | epicsParseFloat32(str, to, units) epicsParseFloat(str, to, units) |
| #define | epicsParseFloat64(str, to, units) epicsParseDouble(str, to, units) |
| #define | epicsScanLong(str, to, base) (!epicsParseLong(str, to, base, NULL)) |
| #define | epicsScanULong(str, to, base) (!epicsParseULong(str, to, base, NULL)) |
| #define | epicsScanLLong(str, to, base) (!epicsParseLLong(str, to, base, NULL)) |
| #define | epicsScanULLong(str, to, base) (!epicsParseULLong(str, to, base, NULL)) |
| #define | epicsScanFloat(str, to) (!epicsParseFloat(str, to, NULL)) |
| #define | epicsScanDouble(str, to) (!epicsParseDouble(str, to, NULL)) |
Functions | |
| LIBCOM_API int | epicsParseLong (const char *str, long *to, int base, char **units) |
| Convert a string to a long type. More... | |
| LIBCOM_API int | epicsParseULong (const char *str, unsigned long *to, int base, char **units) |
| Convert a string to a unsigned long type. More... | |
| LIBCOM_API int | epicsParseLLong (const char *str, long long *to, int base, char **units) |
| Convert a string to a long long type. More... | |
| LIBCOM_API int | epicsParseULLong (const char *str, unsigned long long *to, int base, char **units) |
| Convert a string to a unsigned long long type. More... | |
| LIBCOM_API int | epicsParseDouble (const char *str, double *to, char **units) |
| Convert a string to a double type. More... | |
| LIBCOM_API int | epicsParseFloat (const char *str, float *to, char **units) |
| Convert a string to a float type. More... | |
| LIBCOM_API int | epicsParseInt8 (const char *str, epicsInt8 *to, int base, char **units) |
| Convert a string to an epicsInt8 type. More... | |
| LIBCOM_API int | epicsParseUInt8 (const char *str, epicsUInt8 *to, int base, char **units) |
| Convert a string to an epicsUInt8 type. More... | |
| LIBCOM_API int | epicsParseInt16 (const char *str, epicsInt16 *to, int base, char **units) |
| Convert a string to an epicsInt16 type. More... | |
| LIBCOM_API int | epicsParseUInt16 (const char *str, epicsUInt16 *to, int base, char **units) |
| Convert a string to an epicsUInt16 type. More... | |
| LIBCOM_API int | epicsParseInt32 (const char *str, epicsInt32 *to, int base, char **units) |
| Convert a string to an epicsInt32 type. More... | |
| LIBCOM_API int | epicsParseUInt32 (const char *str, epicsUInt32 *to, int base, char **units) |
| Convert a string to an epicsUInt32 type. More... | |
| LIBCOM_API int | epicsParseInt64 (const char *str, epicsInt64 *to, int base, char **units) |
| Convert a string to an epicsInt64 type. More... | |
| LIBCOM_API int | epicsParseUInt64 (const char *str, epicsUInt64 *to, int base, char **units) |
| Convert a string to an epicsUInt64 type. More... | |
These routines convert a string into an integer of the indicated type and number base, or into a floating point type. The units pointer argument may be NULL, but if not it will be left pointing to the first non-whitespace character following the numeric string, or to the terminating zero byte.
The return value from these routines is a status code, zero meaning OK. For the macro functions beginning with epicsScan the return code is 0 or 1 (0=failure or 1=success, similar to the sscanf() function).
Definition in file epicsStdlib.h.
| #define S_stdlib_noConversion (M_stdlib | 1) /* No digits to convert */ |
Return code for No digits to convert
Definition at line 43 of file epicsStdlib.h.
| #define S_stdlib_extraneous (M_stdlib | 2) /* Extraneous characters */ |
Return code for Extraneous characters
Definition at line 45 of file epicsStdlib.h.
| #define S_stdlib_underflow (M_stdlib | 3) /* Too small to represent */ |
Return code for Too small to represent
Definition at line 47 of file epicsStdlib.h.
| #define S_stdlib_overflow (M_stdlib | 4) /* Too large to represent */ |
Return code for Too large to represent
Definition at line 49 of file epicsStdlib.h.
| #define S_stdlib_badBase (M_stdlib | 5) /* Number base not supported */ |
Return code for Number base not supported
Definition at line 51 of file epicsStdlib.h.
| #define epicsParseFloat32 | ( | str, | |
| to, | |||
| units | |||
| ) | epicsParseFloat(str, to, units) |
Macro utilizing epicsParseFloat to convert
Definition at line 161 of file epicsStdlib.h.
| #define epicsParseFloat64 | ( | str, | |
| to, | |||
| units | |||
| ) | epicsParseDouble(str, to, units) |
Macro utilizing epicsParseDouble to convert
Definition at line 163 of file epicsStdlib.h.
| #define epicsScanLong | ( | str, | |
| to, | |||
| base | |||
| ) | (!epicsParseLong(str, to, base, NULL)) |
Macro utilizing epicsParseLong to convert
Definition at line 173 of file epicsStdlib.h.
| #define epicsScanULong | ( | str, | |
| to, | |||
| base | |||
| ) | (!epicsParseULong(str, to, base, NULL)) |
Macro utilizing epicsParseULong to convert
Definition at line 179 of file epicsStdlib.h.
| #define epicsScanLLong | ( | str, | |
| to, | |||
| base | |||
| ) | (!epicsParseLLong(str, to, base, NULL)) |
Macro utilizing epicsParseLLong to convert
Definition at line 185 of file epicsStdlib.h.
| #define epicsScanULLong | ( | str, | |
| to, | |||
| base | |||
| ) | (!epicsParseULLong(str, to, base, NULL)) |
Macro utilizing epicsParseULLong to convert
Definition at line 191 of file epicsStdlib.h.
| #define epicsScanFloat | ( | str, | |
| to | |||
| ) | (!epicsParseFloat(str, to, NULL)) |
Definition at line 197 of file epicsStdlib.h.
| #define epicsScanDouble | ( | str, | |
| to | |||
| ) | (!epicsParseDouble(str, to, NULL)) |
Definition at line 203 of file epicsStdlib.h.
| LIBCOM_API int epicsParseLong | ( | const char * | str, |
| long * | to, | ||
| int | base, | ||
| char ** | units | ||
| str | Pointer to a constant character array |
| to | Pointer to the specified type (this will be set during the conversion) |
| base | The number base to use |
| units | Pointer to a char * (this will be set with the units string) |
| LIBCOM_API int epicsParseULong | ( | const char * | str, |
| unsigned long * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseLLong | ( | const char * | str, |
| long long * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseULLong | ( | const char * | str, |
| unsigned long long * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseDouble | ( | const char * | str, |
| double * | to, | ||
| to | Pointer to the specified type (this will be set only upon successful conversion) |
| units | Pointer to a char * (this will be set with the units string only upon successful conversion) |
| LIBCOM_API int epicsParseFloat | ( | const char * | str, |
| float * | to, | ||
| LIBCOM_API int epicsParseInt8 | ( | const char * | str, |
| epicsInt8 * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseUInt8 | ( | const char * | str, |
| epicsUInt8 * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseInt16 | ( | const char * | str, |
| epicsInt16 * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseUInt16 | ( | const char * | str, |
| epicsUInt16 * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseInt32 | ( | const char * | str, |
| epicsInt32 * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseUInt32 | ( | const char * | str, |
| epicsUInt32 * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseInt64 | ( | const char * | str, |
| epicsInt64 * | to, | ||
| int | base, | ||
| LIBCOM_API int epicsParseUInt64 | ( | const char * | str, |
| epicsUInt64 * | to, | ||
| int | base, | ||
1.8.5
