EPICS Base
7.0.8.1
Mark external symbols and entry points for shared libraries. More...
Macros | |
| #define | epicsShareExtern extern |
| #define | epicsShareAPI |
| #define | epicsShareClass |
| #define | epicsShareDef |
| #define | epicsShareFunc |
| #define | READONLY const |
| #define | INLINE_defs_EPICS |
This is the header file for the "decorated names" that appear in header files, e.g.
#define epicsExportSharedSymbols epicsShareFunc int epicsShareAPI a_func(int arg);
These are needed to properly create DLLs on MS Windows.
epicsExportSharedSymbols macro. If you are implementing a library, refer to the documentation within **makeAPIheader.pl** or run makeAPIheader.pl -h.There are two distinct classes of keywords in this file:
epicsShareAPI - specifies a multi-language calling mechanism. On windows this is the pascal calling convention which is used by visual basic and other high level tools. This is only necessary if a C/C++ function needs to be called from other languages or from high level tools. The epicsShareAPI keyword must be present between the function's returned data type and the function's name. All compilers targeting windows accept the __stdcall keyword in this location. Functions with variable argument lists should not use the epicsShareAPI keyword because __stdcall (pascal) calling convention cannot support variable length ed argument lists.
int epicsShareAPI myExtFunc ( int arg );
int epicsShareAPI myExtFunc ( int arg ) {}
In header files declare references to externally visible variables, classes and functions like this:
#include "shareLib.h"
epicsShareFunc int myExtFunc ( int arg );
epicsShareExtern int myExtVar;
class epicsShareClass myClass { int func ( void ); };
In the implementation file, however, you write:
#include <interfaces_imported_from_other_shareable_libraries.h>
#include <interfaces_implemented_in_this_shareable_library.h>
epicsShareDef int myExtVar = 4;
int myExtFunc ( int arg ) {}
int myClass::func ( void ) {}
By default shareLib.h sets the DLL import / export keywords to import from a DLL so that, for DLL consumers (users), nothing special must be done. However, DLL implementers must set epicsExportSharedSymbols as above to specify which functions are exported from the DLL and which of them are imported from other DLLs.
You must first #include what you import and then #define epicsExportSharedSymbols only right before you #include the prototypes for what you implement! You must include shareLib.h again each time that the state of the import/export keywords changes, but this usually occurs as a side effect of including the shareable libraries header file(s).
The construct described below is used in some EPICS header files bit is no longer recommended as it makes it difficult to diagnose the incorrect inclusion of headers that are the wrong side of an epicsExportSharedSymbols marker.
Sometimes a header file for a shareable library exported interface will have some preprocessor switches like this if this header file must also include header files describing interfaces to other shareable libraries.
#ifdef epicsExportSharedSymbols
# define interfacePDQ_epicsExportSharedSymbols
# undef epicsExportSharedSymbols
#endif
#include "epicsTypes.h"
#include "epicsTime.h"
#ifdef interfacePDQ_epicsExportSharedSymbols
# define epicsExportSharedSymbols
# include "shareLib.h"
#endif
class epicsShareClass myClass {};
Fortunately, the above is only the concern of library authors and will have no impact on persons using functions and or external data from a library.
Definition in file shareLib.h.
1.8.5
