This chapter provides a brief introduction to creating EPICS IOC applications. It contains:
This chapter will be hard to understand unless you have some familarity with IOC concepts such as record/device/driver support and have had some experience with creating ioc databases. Once you have this experience, this chapter provides most of the information needed to build applications. The example that follows assumes that EPICS base has already been built.
This section explains how to create an example IOC application in a directory <top>
, naming the application
myexampleApp
and the ioc directory iocmyexample
Execute the command:
echo $EPICS_HOST_ARCH (Unix/Linux)or
set EPICS_HOST_ARCH (Windows)
This should display your workstation architecture, for example linux-x86
or win32-x86
. If you get an ``Undefined
variable" error, you should set EPICS_HOST_ARCH
to your host operating system followed by a dash and then your host
architecture, e.g. solaris-sparc
. The perl script EpicsHostArch.pl
in the base/startup directory has been provided to help
set EPICS_HOST_ARCH
The following commands create an example application.
mkdir <top> cd <top> <base>/bin/<arch>/makeBaseApp.pl -t example myexample <base>/bin/<arch>/makeBaseApp.pl -i -t example myexample
Here, <arch>
indicates the operating system architecture of your computer. For example, solaris-sparc
. The last command
will ask you to enter an architecture for the IOC. It provides a list of architectures for which base has been built.
The full path name to <base>
(an already built copy of EPICS base) must be given. Check with your EPICS system
administrator to see what the path to your <base>
is. For example:
/home/phoebus/MRK/epics/base/bin/linux-x86/makeBaseApp.pl ...
Windows Users Note: Perl scripts must be invoked with the command perl <scriptname>
on Windows. Perl script names are
case sensitive. For example to create an application on Windows:
perl C:\epics\base\bin\win32-x86\makeBaseApp.pl -t example myexample
Spend some time looking at the files that appear under <top>
. Do this before building. This allows you to see typical
files which are needed to build an application without seeing the files generated by make.
The sequencer is now supported as an unbundled product. The example includes an example state notation program,
sncExample.stt
. As created by makeBaseApp the example is not built or executed.
Before sncExample.stt
can be compiled, the sequencer module must have been built using the same version of base that the example uses.
To build sncExample edit the following files:
configure/RELEASE
- Set SNCSEQ to the location of the sequencer.
iocBoot/iocmyexample/st.cmd
- Remove the comment character # from this line:
#seq sncExample, "user=<user>"
The Makefile contains commands for building the sncExample code both as a component of the example IOC application
and as a standalone program called sncProgram
, an executable that connects through Channel Access to a separate IOC database.
In directory <top>
execute the command
make
NOTE: On systems where GNU make is not the default another command is required, e.g. gnumake
, gmake
, etc. See
you EPICS system administrator.
This time you will see the files generated by make as well as the original files.
The example can be run on vxWorks, RTEMS, or on a supported host.
cd <top>/iocBoot/iocmyexample ../../bin/linux-x86/myexample st.cmd
After the ioc is started try some of the shell commands (e.g. dbl
or dbpr <recordname>
) described in the chapter ``IOC
Test Facilities". In particular run dbl
to get a list of the records.
The iocsh command interpreter used on non-vxWorks IOCs provides a help facility. Just type:
helpor
help <cmd>where
<cmd>
is one of the commands displayed by help. The help command accepts wildcards, so
help db*will provide information on all commands beginning with the characters db. On vxWorks the help facility is available by first typing:
iocsh
An example host example can be generated by:
cd <mytop> <base>/bin/<arch>/makeBaseApp.pl -t caClient caClient make(or gnumake, as required by your operating system)
Two channel access examples are provided:
caExample
<mytop>/bin/<hostarch>/caExample <pvname>
where
<mytop>
is the full path name to your application top directory.
<hostarch>
is your host architecture.
<pvname>
is one of the record names displayed by the dbl
ioc shell command.
caMonitor
Because the vxWorks shell is only available on vxWorks, EPICS base provides iocsh. In the main program it can be invoked as follows:
iocsh("filename")or
iocsh(0)If the argument is a filename, the commands in the file are executed and iocsh returns. If the argument is 0 then iocsh goes into interactive mode, i.e. it prompts for and executes commands until an exit command is issued.
This shell is described in more detail in Chapter 18, ``IOC Shell" on page 249 FIXPAGEEREF.
On vxWorks iocsh is not automatically started. It can be started by just giving the following command to the vxWorks shell.
iocshTo get back to the vxWorks shell just say
exit
Detailed build rules are given in chapter ``Epics Build Facility". This section describes methods for building most
components needed for IOC applications. It uses excerpts from the myexampleApp/src/Makefile
that is generated by
makeBaseApp.
The following two types of applications can be built:
These are applications meant for use by ioc applications. The rules described here install things into one of the
following directories that are created just below <top>
include
xxxRecord.dbd
or xxxMenu.dbd
files.
dbd
include
, recordtype
, device
, driver
, and
registrar
database definition commands. The following are installed:
xxxRecord.dbd
and xxxMenu.dbd
files
xxx.dbd
file
yyy.dbd
generated from file yyyInclude.dbd
db
lib/<arch>
These are applications loaded into actual IOCs.
Because many IOC components are bound only during ioc initialization, some method of linking to the appropriate shared
and/or static libraries must be provided. The method used for IOCs is to generate, from an xxxInclude.dbd
file, a C++
program that contains references to the appropriate library modules. The following database definitions keywords are used
for this purpose:
recordtype device driver function variable registrar
The method also requires that IOC components contain an appropriate epicsExport statement. All components must contain the statement:
#include <epicsExport.h>
Any component that defines any exported functions must also contain:
#include <registryFunction.h>
Each record support module must contain a statement like:
epicsExportAddress(rset,xxxRSET);
Each device support module must contain a statement like:
epicsExportAddress(dset,devXxxSoft);
Each driver support module must contain a statement like:
epicsExportAddress(drvet,drvXxx);
Functions are registered using an epicsRegisterFunction
macro in the C source file containing the function, along
with a function
statement in the application database description file. The makeBaseApp example thus contains the
following statements to register a pair of functions for use with a subroutine record:
epicsRegisterFunction(mySubInit); epicsRegisterFunction(mySubProcess);
The database definition keyword variable
forces a reference to an integer or double variable, e.g. debugging variables.
The xxxInclude.dbd
file can contain definitions like:
variable(asCaDebug,int) variable(myDefaultTimeout,double)
The code that defines the variables must include code like:
int asCaDebug = 0; epicsExportAddress(int,asCaDebug);
The keyword registrar
signifies that the epics component supplies a named registrar function that has the prototype:
typedef void (*REGISTRAR)(void);
This function normally registers things, as described in Chapter 21, ``Registry" on page . The makeBaseApp example
provides a sample iocsh command which is registered with the following registrar function:
static void helloRegister(void) { iocshRegister(&helloFuncDef, helloCallFunc); } epicsExportRegistrar(helloRegister);
# xxxRecord.h will be created from xxxRecord.dbd DBDINC += xxxRecord DBD += myexampleSupport.dbd LIBRARY_IOC += myexampleSupport myexampleSupport_SRCS += xxxRecord.c myexampleSupport_SRCS += devXxxSoft.c myexampleSupport_SRCS += dbSubExample.c myexampleSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
The DBDINC
rule looks for a file xxxRecord.dbd
. From this file a file xxxRecord.h
is created and installed into <top>/include
The DBD
rule finds myexampleSupport.dbd
in the source directory and installs it into <top>/dbd
The LIBRARY_IOC
statement states that a shared/static library should be created and installed into <top>/lib/<arch>
The myexampleSupport_SRCS
statements name all the source files that are compiled and put into the library.
The above statements are all that is needed for building many support applications.
The following statements build the IOC application:
PROD_IOC = myexample DBD += myexample.dbd # myexample.dbd will be made up from these files: myexample_DBD += base.dbd myexample_DBD += xxxSupport.dbd myexample_DBD += dbSubExample.dbd # <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd myexample_SRCS += myexample_registerRecordDeviceDriver.cpp myexample_SRCS_DEFAULT += myexampleMain.cpp myexample_SRCS_vxWorks += -nil- # Add locally compiled object code myexample_SRCS += dbSubExample.c #The following adds support from base/src/vxWorks myexample_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary myexample_LIBS += myexampleSupport myexample_LIBS += $(EPICS_BASE_IOC_LIBS)
PROD_IOC
sets the name of the ioc application, here called myexample
The DBD definition myexample.dbd
will cause build rules to create the database definition include file
myexampleInclude.dbd
from files in the myexample_DBD
definition. For each filename in that
definition, the created myexampleInclude.dbd
will contain an include statement for that filename.
In this case the created myexampleInclude.dbd
file will contain the following lines.
include "base.dbd" include "xxxSupport.dbd" include "dbSubExample.dbd"
When the DBD build rules find the created file myexampleInclude.dbd
, the rules then call dbExpand which reads
to generate file myexample.dbd
, and install it into <top>/dbd
An arbitrary number of myexample_SRCS
statements can be given. Names of the form
<name>_registerRecordDeviceDriver.cpp,
are special; when they are seen the perl script
registerRecordDeviceDriver.pl
is executed and given <name>.dbd
as input. This script generates the
file automatically.
makeBaseApp.pl
is a perl script that creates application areas. It can create the following:
<top>/Makefile
<top>/configure
- This directory contains the files needed by the EPICS build system.
<top>/xxxApp
- A set of directories and associated files for a major sub-module.
<top>/iocBoot
- A subdirectory and associated files.
<top>/iocBoot/iocxxx
- A subdirectory and files for a single ioc.
makeBaseApp.pl
creates directories and then copies template files into the newly created directories while expanding
macros in the template files. EPICS base provides two sets of template files: simple and example. These are meant for
simple applications. Each site, however, can create its own set of template files which may provide additional
functionality. This section describes the functionality of makeBaseApp itself, the next section provides details about the
simple and example templates.
makeBaseApp has four possible forms of command line:
<base>/bin/<arch>/makeBaseApp.pl -hProvides help.
<base>/bin/<arch>/makeBaseApp.pl -l [options]List the application templates available. This invocation does not alter the current directory.
<base>/bin/<arch>/makeBaseApp.pl [-t type] [options] app ...Create application directories.
<base>/bin/<arch>/makeBaseApp.pl -i -t type [options] ioc ...Create ioc boot directories.
Options for all command forms:
-b base
-T template
-d
Arguments unique to makeBaseApp.pl [-t type] [options] app ...
app
-t type
-l
invocation to get a list of valid types).
If this option is not used, type is taken from the environment variable EPICS_MBA_DEF_APP_TYPE, or if that is not set the values ``default" and then ``example" are tried.
Arguments unique to makeBaseApp.pl -i [options] ioc ...
ioc
-a arch
-a arch
is not specified, you will be prompted.
EPICS_MBA_TEMPLATE_TOP
To create a new <top>
issue the commands:
mkdir <top> cd <top> <base>/bin/<arch>/makeBaseApp.pl -t <type> <app> ... <base>/bin/<arch>/makeBaseApp.pl -i -t <type> <ioc> ...
makeBaseApp does the following:
EPICS_BASE
is located by checking the following in order:
-b
option is specified its value is used.
<top>/configure/RELEASE
file exists and defines a value for EPICS_BASE
it is used.
makeBaseApp.pl
script in the EPICS base release you are using must be given.
TEMPLATE_TOP
is located in a similar fashion:
-T
file exists and defines a value for TEMPLATE_TOP
it is used.
is defined its value is used.
<epics_base>/templates/makeBaseApp/top
-l
is specified the list of application types is listed and makeBaseApp terminates.
-i
is specified and -a
is not then the user is prompted for the IOC architecture.
-t
is specified it is used.
defaultApp
exists, the application type is set equal to default.
exampleApp
exists, the application type is set equal to example.
TEMPLATE_TOP
, makeBaseApp issues an error and terminates.
Makefile
does not exist, it is created.
configure
does not exist, it is created and populated with all the configure
files.
-i
is specified:
iocBoot
does not exist, it is created and the files from the template boot directory are copied
into it.
<ioc>
specified on the command line a directory iocBoot/ioc<ioc>
is created and populated with the files from the template (with ReplaceLine()
tag replacement, see below).
-i
is NOT specified:
<app>
specified on the command line a directory <app>App
is created and populated with the directory tree from the template (with ReplaceLine()
When copying certain files from the template to the new application structure, makeBaseApp replaces some predefined tags in the name or text of the files concerned with values that are known at the time. An application template can extend this functionality as follows:
ReplaceFilename
_APPNAME_ _APPTYPE_
ReplaceLine
_USER_ _EPICS_BASE_ _ARCH_ _APPNAME_ _APPTYPE_ _TEMPLATE_TOP_ _IOC_
Replace.pl
, it can:
ReplaceFilenameHook($file)
which is called at the end of ReplaceFilename
ReplaceLineHook($line)
which is called at the end of ReplaceLine
This creates files appropriate for building a support application.
Without the -i
option, this creates files appropriate for building an ioc application.
With the -i
option it creates an ioc boot directory.
Without the -i
option it creates files for running an example.
Both a support and an ioc application are built.
With the -i
option it creates an ioc boot directory that can be used to run the example.
This builds two Channel Access clients.
This builds an example Portable Access Server.
The vxWorks boot parameters are set via the console serial port on your IOC.
Life is much easier if you can connect the console to a terminal window on your workstation.
On Linux the `screen' program lets you communicate through a local serial port; run screen /dev/ttyS0
if the IOC is connected to ttyS0
The vxWorks boot parameters look something like the following:
boot device : xxx processor number : 0 host name : xxx file name : <full path to board support>/vxWorks inet on ethernet (e) : xxx.xxx.xxx.xxx:<netmask> host inet (h) : xxx.xxx.xxx.xxx user (u) : xxx ftp password (pw) : xxx flags (f) : 0x0 target name (tn) : <hostname for this inet address> startup script (s) : <top>/iocBoot/iocmyexample/st.cmdThe actual values for each field are site and IOC dependent. Two fields that you can change at will are the vxWorks boot image and the location of the startup script.
Note that the full path name for the correct board support boot image must be specified. If bootp is used the same information will need to be placed in the bootp host's configuration database instead.
When your boot parameters are set properly, just press the reset button on your IOC, or use the @
command to commence booting.
You will find it VERY convenient to have the console port of the IOC attached to a scrolling window on your workstation.
RTEMS uses the vendor-supplied bootstrap mechanism so the method for booting an IOC depends upon the hardware in use.
Many boards can use BOOTP/DHCP to read their network configuration and then use TFTP to read the applicaion program. RTEMS can then use TFTP or NFS to read startup scripts and configuration files. If you are using TFTP to read the startup scripts and configuration files you must install the EPICS application files on your TFTP server as follows:
db/xxx
files to <tftpbase>/epics/<target_hostname\>/db/xxx
dbd/xxx
files to <tftpbase>/epics/<target_hostname>/dbd/xxx
st.cmd
script to <tftpbase>/epics/<target_hostname>/st.cmd
Use DHCP site-specific option 129 to specify the path to the IOC startup script.
Motorola single-board computers which employ PPCBUG should have their `NIOT' parameters set up like:
Controller LUN =00
Device LUN =00
Node Control Memory Address =FFE10000
Client IP Address =
`Dotted-decimal' IP address of IOC
Server IP Address =
`Dotted-decimal' IP address of TFTP/NFS server
Subnet IP Address Mask =
`Dotted-decimal' IP address of subnet mask (255.255.255.0 for class C subnet)
Broadcast IP Address =
`Dotted-decimal' IP address of subnet broadcast address
Gateway IP Address =
`Dotted-decimal' IP address of network gateway (0.0.0.0 if none)
Boot File Name =
Path to application bootable image (..../bin/RTEMS-mvme2100/test.boot)
Argument File Name =
Path to application startup script (..../iocBoot/ioctest/st.cmd)
Boot File Load Address =001F0000
(actual value depends on BSP)
Boot File Execution Address =001F0000
Boot File Execution Delay =00000000
Boot File Length =00000000
Boot File Byte Offset =00000000
BOOTP/RARP Request Retry =00
TFTP/ARP Request Retry =00
Trace Character Buffer Address =00000000
Motrola single-board computers which employ MOTLOAD should have their network `Global Environment Variable' parameters set up like:
mot-/dev/enet0-cipa=
mot-/dev/enet0-sipa=
mot-/dev/enet0-snma=
mot-/dev/enet0-gipa=
`Dotted-decimal' IP address of network gateway (omit if none)
mot-/dev/enet0-file=
Path to application bootable image (..../bin/RTEMS-mvme5500/test.boot)
rtems-client-name=
IOC name (mot-/dev/enet0-cipa will be used if this parameter is missing)
rtems-dns-server=
'Dotted-decimal' IP address of domain name server (omit if none)
rtems-dns-domainname=
Domain name (if this parameter is omitted the compiled-in value will be used)
epics-script=
The mot-script-boot
parameter should be set up like:
tftpGet -a4000000 -cxxx -sxxx -mxxx -gxxx -d/dev/enet0 -f..../bin/RTEMS-mvme5500/test.boot netShut go -a4000000
where the -c
, -s
, -m
and -g
values should match the cipa, sipa, snma and gipa values, respectively and the -f
value should match the file value.
For IOCs which use NFS for remote file access the EPICS initialization code uses the startup script pathname to determine the parameters for the initial NFS mount.
If the startup script pathname begins with a `/
' the first component of the pathname is used as both the server path and the local mount point.
If the startup script pathname does not begin with a `/
' the first component of the pathname is used as the local mount point and the server path is ``/tftpboot/
'' followed by the first component of the pathname.
This allows the NFS client used for EPICS file access and the TFTP client used for bootstrapping the application to have a similar view of the remote filesystem.
The RTEMS `Cexp' add-on package provides the ability to load object modules at application run-time. If your RTEMS build includes this package you can load RTEMS IOC applications in the same fashion as vxWorks IOC applications.
