EPICS Base
7.0.6.1
Declarations for the calcout record type. More...
#include "epicsTypes.h"#include "link.h"#include "epicsMutex.h"#include "ellLib.h"#include "devSup.h"#include "epicsTime.h"#include "dbScan.h"#include "postfix.h"
Classes | |
| struct | calcoutdset |
| struct | calcoutRecord |
| Declaration of calcout record type. More... | |
Macros | |
| #define | HAS_calcoutdset |
| #define | calcoutINAV_NUM_CHOICES 4 |
| Number of states defined for menu calcoutINAV. | |
| #define | calcoutDOPT_NUM_CHOICES 2 |
| Number of states defined for menu calcoutDOPT. | |
| #define | calcoutOOPT_NUM_CHOICES 6 |
| Number of states defined for menu calcoutOOPT. | |
Enumerations | |
| enum | calcoutINAV { calcoutINAV_EXT_NC, calcoutINAV_EXT, calcoutINAV_LOC, calcoutINAV_CON } |
| Enumerated type from menu calcoutINAV. More... | |
| enum | calcoutDOPT { calcoutDOPT_Use_VAL, calcoutDOPT_Use_OVAL } |
| Enumerated type from menu calcoutDOPT. More... | |
| enum | calcoutOOPT { calcoutOOPT_Every_Time, calcoutOOPT_On_Change, calcoutOOPT_When_Zero, calcoutOOPT_When_Non_zero, calcoutOOPT_Transition_To_Zero, calcoutOOPT_Transition_To_Non_zero } |
| Enumerated type from menu calcoutOOPT. More... | |
| enum | calcoutFieldIndex { calcoutRecordNAME = 0, calcoutRecordDESC = 1, calcoutRecordASG = 2, calcoutRecordSCAN = 3, calcoutRecordPINI = 4, calcoutRecordPHAS = 5, calcoutRecordEVNT = 6, calcoutRecordTSE = 7, calcoutRecordTSEL = 8, calcoutRecordDTYP = 9, calcoutRecordDISV = 10, calcoutRecordDISA = 11, calcoutRecordSDIS = 12, calcoutRecordMLOK = 13, calcoutRecordMLIS = 14, calcoutRecordBKLNK = 15, calcoutRecordDISP = 16, calcoutRecordPROC = 17, calcoutRecordSTAT = 18, calcoutRecordSEVR = 19, calcoutRecordAMSG = 20, calcoutRecordNSTA = 21, calcoutRecordNSEV = 22, calcoutRecordNAMSG = 23, calcoutRecordACKS = 24, calcoutRecordACKT = 25, calcoutRecordDISS = 26, calcoutRecordLCNT = 27, calcoutRecordPACT = 28, calcoutRecordPUTF = 29, calcoutRecordRPRO = 30, calcoutRecordASP = 31, calcoutRecordPPN = 32, calcoutRecordPPNR = 33, calcoutRecordSPVT = 34, calcoutRecordRSET = 35, calcoutRecordDSET = 36, calcoutRecordDPVT = 37, calcoutRecordRDES = 38, calcoutRecordLSET = 39, calcoutRecordPRIO = 40, calcoutRecordTPRO = 41, calcoutRecordBKPT = 42, calcoutRecordUDF = 43, calcoutRecordUDFS = 44, calcoutRecordTIME = 45, calcoutRecordUTAG = 46, calcoutRecordFLNK = 47, calcoutRecordRPVT = 48, calcoutRecordVAL = 49, calcoutRecordPVAL = 50, calcoutRecordCALC = 51, calcoutRecordCLCV = 52, calcoutRecordINPA = 53, calcoutRecordINPB = 54, calcoutRecordINPC = 55, calcoutRecordINPD = 56, calcoutRecordINPE = 57, calcoutRecordINPF = 58, calcoutRecordINPG = 59, calcoutRecordINPH = 60, calcoutRecordINPI = 61, calcoutRecordINPJ = 62, calcoutRecordINPK = 63, calcoutRecordINPL = 64, calcoutRecordOUT = 65, calcoutRecordINAV = 66, calcoutRecordINBV = 67, calcoutRecordINCV = 68, calcoutRecordINDV = 69, calcoutRecordINEV = 70, calcoutRecordINFV = 71, calcoutRecordINGV = 72, calcoutRecordINHV = 73, calcoutRecordINIV = 74, calcoutRecordINJV = 75, calcoutRecordINKV = 76, calcoutRecordINLV = 77, calcoutRecordOUTV = 78, calcoutRecordOOPT = 79, calcoutRecordODLY = 80, calcoutRecordDLYA = 81, calcoutRecordDOPT = 82, calcoutRecordOCAL = 83, calcoutRecordOCLV = 84, calcoutRecordOEVT = 85, calcoutRecordEPVT = 86, calcoutRecordIVOA = 87, calcoutRecordIVOV = 88, calcoutRecordEGU = 89, calcoutRecordPREC = 90, calcoutRecordHOPR = 91, calcoutRecordLOPR = 92, calcoutRecordHIHI = 93, calcoutRecordLOLO = 94, calcoutRecordHIGH = 95, calcoutRecordLOW = 96, calcoutRecordHHSV = 97, calcoutRecordLLSV = 98, calcoutRecordHSV = 99, calcoutRecordLSV = 100, calcoutRecordHYST = 101, calcoutRecordADEL = 102, calcoutRecordMDEL = 103, calcoutRecordA = 104, calcoutRecordB = 105, calcoutRecordC = 106, calcoutRecordD = 107, calcoutRecordE = 108, calcoutRecordF = 109, calcoutRecordG = 110, calcoutRecordH = 111, calcoutRecordI = 112, calcoutRecordJ = 113, calcoutRecordK = 114, calcoutRecordL = 115, calcoutRecordOVAL = 116, calcoutRecordLA = 117, calcoutRecordLB = 118, calcoutRecordLC = 119, calcoutRecordLD = 120, calcoutRecordLE = 121, calcoutRecordLF = 122, calcoutRecordLG = 123, calcoutRecordLH = 124, calcoutRecordLI = 125, calcoutRecordLJ = 126, calcoutRecordLK = 127, calcoutRecordLL = 128, calcoutRecordPOVL = 129, calcoutRecordLALM = 130, calcoutRecordALST = 131, calcoutRecordMLST = 132, calcoutRecordRPCL = 133, calcoutRecordORPC = 134 } |
This header was generated from calcoutRecord.dbd
Definition in file calcoutRecord.h.
| enum calcoutINAV |
| Enumerator | |
| calcoutINAV_EXT_NC |
State string "Ext PV NC". |
| calcoutINAV_EXT |
State string "Ext PV OK". |
| calcoutINAV_LOC |
State string "Local PV". |
| calcoutINAV_CON |
State string "Constant". |
Definition at line 29 of file calcoutRecord.h.
| enum calcoutDOPT |
| Enumerator | |
| calcoutDOPT_Use_VAL |
State string "Use CALC". |
| calcoutDOPT_Use_OVAL |
State string "Use OCAL". |
Definition at line 41 of file calcoutRecord.h.
| enum calcoutOOPT |
Definition at line 51 of file calcoutRecord.h.
1.8.5
