EPICS Base  7.0.6.1
devSup.h
1 /*************************************************************************\
2 * Copyright (c) 2009 UChicago Argonne LLC, as Operator of Argonne
3 * National Laboratory.
4 * Copyright (c) 2002 The Regents of the University of California, as
5 * Operator of Los Alamos National Laboratory.
6 * SPDX-License-Identifier: EPICS
7 * EPICS BASE is distributed subject to a Software License Agreement found
8 * in file LICENSE that is included with this distribution.
9 \*************************************************************************/
15 /*
16  * Author: Marty Kraimer
17  * Date: 6-1-90
18  */
19
20 #ifndef INCdevSuph
21 #define INCdevSuph 1
22
23 #include "errMdef.h"
24 #include "dbCoreAPI.h"
25
26 /* structures defined elsewhere */
27 struct dbCommon;
28 struct devSup;
29 typedef struct ioscan_head *IOSCANPVT;
30 struct link; /* aka DBLINK */
31
65 typedef struct typed_dset {
68  long number;
70  long (*report)(int lvl);
75  long (*init)(int after);
77  long (*init_record)(struct dbCommon *prec);
108  long (*get_ioint_info)(int detach, struct dbCommon *prec, IOSCANPVT* pscan);
109  /* Any further functions are specified by the record type. */
110 } typed_dset;
111
118 typedef struct dsxt {
123  long (*add_record)(struct dbCommon *precord);
128  long (*del_record)(struct dbCommon *precord);
129  /* Only future Base releases may extend this table. */
130 } dsxt;
131
132 #ifdef __cplusplus
133 extern "C" {
134  typedef long (*DEVSUPFUN)(void *); /* ptr to device support function*/
135 #else
136  typedef long (*DEVSUPFUN)(); /* ptr to device support function*/
137 #endif
138
139 #ifndef USE_TYPED_DSET
140
141 typedef struct dset { /* device support entry table */
142  long number; /*number of support routines*/
143  DEVSUPFUN report; /*print report*/
144  DEVSUPFUN init; /*init support layer*/
145  DEVSUPFUN init_record; /*init device for particular record*/
146  DEVSUPFUN get_ioint_info; /* get io interrupt information*/
147  /*other functions are record dependent*/
148 } dset;
149
150 #else
151 typedef typed_dset dset;
152 #endif /* USE_TYPED_DSET */
153
154 /* exists only to disambiguate dset dbCommon::dset */
155 typedef dset unambiguous_dset;
156
161 DBCORE_API struct link* dbGetDevLink(struct dbCommon* prec);
162
163 DBCORE_API extern dsxt devSoft_DSXT; /* Allow anything table */
164
165 DBCORE_API void devExtend(dsxt *pdsxt);
166 DBCORE_API void dbInitDevSup(struct devSup *pdevSup, dset *pdset);
167
168
169 #define S_dev_noDevSup (M_devSup| 1) /*SDR_DEVSUP: Device support missing*/
170 #define S_dev_noDSET (M_devSup| 3) /*Missing device support entry table*/
171 #define S_dev_missingSup (M_devSup| 5) /*Missing device support routine*/
172 #define S_dev_badInpType (M_devSup| 7) /*Bad INP link type*/
173 #define S_dev_badOutType (M_devSup| 9) /*Bad OUT link type*/
174 #define S_dev_badInitRet (M_devSup|11) /*Bad init_rec return value */
175 #define S_dev_badBus (M_devSup|13) /*Illegal bus type*/
176 #define S_dev_badCard (M_devSup|15) /*Illegal or nonexistent module*/
177 #define S_dev_badSignal (M_devSup|17) /*Illegal signal*/
178 #define S_dev_NoInit (M_devSup|19) /*No init*/
179 #define S_dev_Conflict (M_devSup|21) /*Multiple records accessing same signal*/
180 #define S_dev_noDeviceFound (M_devSup|23) /*No device found at specified address*/
181
182 #ifdef __cplusplus
183 } /* extern "C" */
184 #endif
185
186 #endif
Definition: devSup.h:118
long number
Definition: devSup.h:68
Declaration of dbCommon.
Definition: dbCommon.h:18
long(* init)(int after)
Definition: devSup.h:75
Definition: devSup.h:141
Definition: dbBase.h:39
long(* init_record)(struct dbCommon *prec)
Definition: devSup.h:77
DBCORE_API struct link * dbGetDevLink(struct dbCommon *prec)
long(* report)(int lvl)
Definition: devSup.h:70
long(* add_record)(struct dbCommon *precord)
Definition: devSup.h:123
long(* del_record)(struct dbCommon *precord)
Definition: devSup.h:128
long(* get_ioint_info)(int detach, struct dbCommon *prec, IOSCANPVT *pscan)
Definition: devSup.h:108
