EPICS Base  7.0.6.1
Classes | Macros | Typedefs | Functions | Variables
devSup.h File Reference
Device support routines. More...
#include "errMdef.h"
#include "dbCoreAPI.h"
Include dependency graph for devSup.h:
This graph shows which files directly or indirectly include this file:
Classes
struct  typed_dset
struct  dsxt
struct  dset
Macros
#define S_dev_noDevSup   (M_devSup| 1) /*SDR_DEVSUP: Device support missing*/
#define S_dev_noDSET   (M_devSup| 3) /*Missing device support entry table*/
#define S_dev_missingSup   (M_devSup| 5) /*Missing device support routine*/
#define S_dev_badInpType   (M_devSup| 7) /*Bad INP link type*/
#define S_dev_badOutType   (M_devSup| 9) /*Bad OUT link type*/
#define S_dev_badInitRet   (M_devSup|11) /*Bad init_rec return value */
#define S_dev_badBus   (M_devSup|13) /*Illegal bus type*/
#define S_dev_badCard   (M_devSup|15) /*Illegal or nonexistent module*/
#define S_dev_badSignal   (M_devSup|17) /*Illegal signal*/
#define S_dev_NoInit   (M_devSup|19) /*No init*/
#define S_dev_Conflict   (M_devSup|21) /*Multiple records accessing same signal*/
#define S_dev_noDeviceFound   (M_devSup|23) /*No device found at specified address*/
Typedefs
typedef struct ioscan_head * IOSCANPVT
typedef long(* DEVSUPFUN )(void *)
typedef dset unambiguous_dset
Functions
DBCORE_API struct link * dbGetDevLink (struct dbCommon *prec)
DBCORE_API void devExtend (dsxt *pdsxt)
DBCORE_API void dbInitDevSup (struct devSup *pdevSup, dset *pdset)
Variables
DBCORE_API dsxt devSoft_DSXT
Function Documentation
DBCORE_API struct link* dbGetDevLink ( struct dbCommon *  prec)
Fetch INP or OUT link (or NULL if record type has neither).
Recommended for use in device support init_record()
