#include <devSup.h>
Type safe version of 'struct dset'
Recommended usage:
In Makefile:
USR_CPPFLAGS += -DUSE_TYPED_RSET -DUSE_TYPED_DSET
In C source file:
#include <dbScan.h>
#include <epicsExport.h>
static long get_iointr_info(
int detach,
dbCommon *prec, IOCSCANPVT* pscan);
5,
NULL,
NULL,
&get_iointr_info
&longin_read
Definition at line 65 of file devSup.h.
Number of function pointers which follow. The value depends on the recordtype, but must be >=4
Definition at line 68 of file devSup.h.
| long(* typed_dset::report)(int lvl) |
Called from dbior()
Definition at line 70 of file devSup.h.
| long(* typed_dset::init)(int after) |
Called twice during iocInit(). First with after = 0 before init_record() or array field allocation. Again with after = 1 after init_record() has finished.
Definition at line 75 of file devSup.h.
| long(* typed_dset::init_record)(struct dbCommon *prec) |
Called once per record instance
Definition at line 77 of file devSup.h.
| long(* typed_dset::get_ioint_info)(int detach, struct dbCommon *prec, IOSCANPVT *pscan) |
Called when SCAN="I/O Intr" on startup, or after SCAN is changed.
Caller must assign the third argument (IOCSCANPVT*). eg.
struct mpvt {
IOSCANPVT drvlist;
scanIoInit(&pvt->drvlist);
pscan = &((mypvt*)prec->
dpvt)->drvlist;
When a particular record instance can/will only used a single scan list, the detach argument can be ignored.
If this is not the case, then the following should be noted.
- get_ioint_info() is called with detach = 0 to fetch the scan list to which this record will be added.
- get_ioint_info() is called later with detach = 1 to fetch the scan list from which this record should be removed.
- Calls will be balanced, so a call with detach = 0 will be followed by one with detach = 1.
- Note
- get_ioint_info() will be called during IOC shutdown if the dsxt::del_record() extended callback is defined. (from 3.15.0.1)
Definition at line 108 of file devSup.h.
The documentation for this struct was generated from the following file:
