EPICS Base  7.0.6.1
Classes | Macros | Typedefs | Enumerations | Functions
epicsThread.h File Reference
C++ and C descriptions for a thread. More...
#include <stddef.h>
#include "libComAPI.h"
#include "compilerDependencies.h"
#include "epicsEvent.h"
#include "epicsMutex.h"
#include "osdThread.h"
Include dependency graph for epicsThread.h:
This graph shows which files directly or indirectly include this file:
Classes
struct  epicsThreadOpts
class  epicsThreadRunable
 Interface used with class epicsThread. More...
class  epicsThread
 An OS thread. More...
class  epicsThreadPrivateBase
class  epicsThreadPrivateBase::unableToCreateThreadPrivate
class  epicsThreadPrivate< T >
Macros
#define EPICS_THREAD_ONCE_INIT   0
#define EPICS_THREAD_OPTS_INIT
#define EPICS_THREAD_CAN_JOIN
Some Named Thread Priorities
#define epicsThreadPriorityMax   99
#define epicsThreadPriorityMin   0
#define epicsThreadPriorityLow   10
#define epicsThreadPriorityMedium   50
#define epicsThreadPriorityHigh   90
#define epicsThreadPriorityCAServerLow   20
#define epicsThreadPriorityCAServerHigh   40
#define epicsThreadPriorityScanLow   60
#define epicsThreadPriorityScanHigh   70
#define epicsThreadPriorityIocsh   91
#define epicsThreadPriorityBaseMax   91
Typedefs
typedef void(* EPICSTHREADFUNC )(void *parm)
typedef epicsThreadId epicsThreadOnceId
typedef void(* EPICS_THREAD_HOOK_ROUTINE )(epicsThreadId id)
typedef struct
epicsThreadPrivateOSD *
epicsThreadPrivateId
Enumerations
enum  epicsThreadStackSizeClass { epicsThreadStackSmall, epicsThreadStackMedium, epicsThreadStackBig }
enum  epicsThreadBooleanStatus { epicsThreadBooleanStatusFail, epicsThreadBooleanStatusSuccess }
Functions
LIBCOM_API unsigned int
epicsStdCall
epicsThreadGetStackSize (epicsThreadStackSizeClass size)
LIBCOM_API void epicsStdCall epicsThreadOnce (epicsThreadOnceId *id, EPICSTHREADFUNC, void *arg)
LIBCOM_API void epicsThreadRealtimeLock (void)
LIBCOM_API void epicsStdCall epicsThreadExitMain (void) EPICS_DEPRECATED
LIBCOM_API epicsThreadId epicsThreadCreateOpt (const char *name, EPICSTHREADFUNC funptr, void *parm, const epicsThreadOpts *opts)
 Allocate and start a new OS thread. More...
epicsStdCall
epicsThreadCreate (const char *name, unsigned int priority, unsigned int stackSize, EPICSTHREADFUNC funptr, void *parm)
epicsStdCall
epicsThreadMustCreate (const char *name, unsigned int priority, unsigned int stackSize, EPICSTHREADFUNC funptr, void *parm)
LIBCOM_API void epicsThreadMustJoin (epicsThreadId id)
LIBCOM_API void epicsStdCall epicsThreadSuspendSelf (void)
LIBCOM_API void epicsStdCall epicsThreadResume (epicsThreadId id)
epicsStdCall
epicsThreadGetPriority (epicsThreadId id)
epicsStdCall
epicsThreadGetPrioritySelf (void)
LIBCOM_API void epicsStdCall epicsThreadSetPriority (epicsThreadId id, unsigned int priority)
LIBCOM_API
epicsStdCall
epicsThreadHighestPriorityLevelBelow (unsigned int priority, unsigned *pPriorityJustBelow)
LIBCOM_API
epicsStdCall
epicsThreadLowestPriorityLevelAbove (unsigned int priority, unsigned *pPriorityJustAbove)
LIBCOM_API int epicsStdCall epicsThreadIsEqual (epicsThreadId id1, epicsThreadId id2)
LIBCOM_API int epicsStdCall epicsThreadIsSuspended (epicsThreadId id)
LIBCOM_API void epicsStdCall epicsThreadSleep (double seconds)
 Block the calling thread for at least the specified time. More...
LIBCOM_API double epicsStdCall epicsThreadSleepQuantum (void)
 Query a value approximating the OS timer/scheduler resolution. More...
epicsStdCall
epicsThreadGetIdSelf (void)
epicsStdCall
epicsThreadGetId (const char *name)
LIBCOM_API int epicsThreadGetCPUs (void)
LIBCOM_API const char *epicsStdCall epicsThreadGetNameSelf (void)
LIBCOM_API void epicsStdCall epicsThreadGetName (epicsThreadId id, char *name, size_t size)
LIBCOM_API int epicsStdCall epicsThreadIsOkToBlock (void)
LIBCOM_API void epicsStdCall epicsThreadSetOkToBlock (int isOkToBlock)
LIBCOM_API void epicsStdCall epicsThreadShowAll (unsigned int level)
LIBCOM_API void epicsStdCall epicsThreadShow (epicsThreadId id, unsigned int level)
LIBCOM_API int epicsThreadHookAdd (EPICS_THREAD_HOOK_ROUTINE hook)
LIBCOM_API int epicsThreadHookDelete (EPICS_THREAD_HOOK_ROUTINE hook)
LIBCOM_API void epicsThreadHooksShow (void)
LIBCOM_API void epicsThreadMap (EPICS_THREAD_HOOK_ROUTINE func)
LIBCOM_API
epicsStdCall
epicsThreadPrivateCreate (void)
LIBCOM_API void epicsStdCall epicsThreadPrivateDelete (epicsThreadPrivateId id)
LIBCOM_API void epicsStdCall epicsThreadPrivateSet (epicsThreadPrivateId, void *)
LIBCOM_API void *epicsStdCall epicsThreadPrivateGet (epicsThreadPrivateId)
void epicsThreadCallEntryPoint (void *)
Detailed Description
The epicsThread API is meant as a somewhat minimal interface for multithreaded applications. It can be implemented on a wide variety of systems with the restriction that the system MUST support a multithreaded environment. A POSIX pthreads version is provided.
The interface provides the following thread facilities, with restrictions as noted:
Definition in file epicsThread.h.
Macro Definition Documentation
Value:
epicsThreadPriorityLow, epicsThreadStackMedium, 0}
Default initial values for epicsThreadOpts Applications should always use this macro to initialize an epicsThreadOpts structure. Additional fields may be added in the future, and the order of the fields might also change, thus code that assumes the above definition might break if these rules are not followed.
Definition at line 173 of file epicsThread.h.
Typedef Documentation
typedef void(* EPICS_THREAD_HOOK_ROUTINE)(epicsThreadId id)
Hooks called when a thread starts, map function called once for every thread.
Definition at line 308 of file epicsThread.h.
typedef struct epicsThreadPrivateOSD* epicsThreadPrivateId
Thread local storage
Definition at line 334 of file epicsThread.h.
Enumeration Type Documentation
Stack sizes for each stackSizeClass are implementation and CPU dependent.
Definition at line 91 of file epicsThread.h.
Function Documentation
LIBCOM_API unsigned int epicsStdCall epicsThreadGetStackSize ( epicsThreadStackSizeClass  size)
Get a stack size value that can be given to epicsThreadCreate().
Parameters
sizeone of the values epicsThreadStackSmall, epicsThreadStackMedium or epicsThreadStackBig.
LIBCOM_API void epicsStdCall epicsThreadOnce ( epicsThreadOnceId *  id,
EPICSTHREADFUNC  ,
void *  arg
Perform one-time initialization.
Run the provided function if it has not run, and is not running in some other thread.
For each unique epicsThreadOnceId, epicsThreadOnce guarantees that
  1. myInitFunc will only be called only once.
  2. myInitFunc will have returned before any other epicsThreadOnce call using the same epicsThreadOnceId returns.
static epicsThreadOnceId onceId = EPICS_THREAD_ONCE_INIT;
static void myInitFunc(void *arg) { ... }
static void some Function(void) {
epicsThreadOnce(&onceId, &myInitFunc, NULL);
LIBCOM_API void epicsThreadRealtimeLock ( void  )
When real-time scheduling is active, attempt any post-init operations that preserve real-time performance. For POSIX targets this locks the process into RAM, preventing swap-related VM faults.
LIBCOM_API void epicsStdCall epicsThreadExitMain ( void  )
If the main routine is done but wants to let other threads run it can call this routine. This should be the last call in main, except the final return. On most systems epicsThreadExitMain never returns.This must only be called by the main thread.
Deprecated:
Deprecated for lack of use. Please report any usage. Recommended replacement is loop + epicsThreadSleep(), epicsEventMustWait(), or similar.
LIBCOM_API epicsThreadId epicsThreadCreateOpt ( const char *  name,
void *  parm,
const epicsThreadOpts *  opts
Parameters
nameA name describing this thread. Appears in various log and error message.
funptrThe thread main function.
parmPassed to thread main function.
optsModifiers for the new thread, or NULL to use target specific defaults.
Returns
NULL on error
LIBCOM_API epicsThreadId epicsStdCall epicsThreadCreate ( const char *  name,
void *  parm
Short-hand for epicsThreadCreateOpt() to create an un-joinable thread.
LIBCOM_API epicsThreadId epicsStdCall epicsThreadMustCreate ( const char *  name,
void *  parm
Short-hand for epicsThreadCreateOpt() to create an un-joinable thread. On error calls cantProceed()
LIBCOM_API void epicsThreadMustJoin ( epicsThreadId  id)
Wait for a joinable thread to exit (return from its main function)
LIBCOM_API void epicsStdCall epicsThreadSuspendSelf ( void  )
Block the current thread until epicsThreadResume().
LIBCOM_API void epicsStdCall epicsThreadResume ( epicsThreadId  id)
Resume a thread suspended with epicsThreadSuspendSelf()
LIBCOM_API unsigned int epicsStdCall epicsThreadGetPriority ( epicsThreadId  id)
Return thread OSI priority
LIBCOM_API unsigned int epicsStdCall epicsThreadGetPrioritySelf ( void  )
LIBCOM_API void epicsStdCall epicsThreadSetPriority ( epicsThreadId  id,
Change OSI priority of target thread.
LIBCOM_API epicsThreadBooleanStatus epicsStdCall epicsThreadHighestPriorityLevelBelow ( unsigned int  priority,
unsigned *  pPriorityJustBelow
Lookup the next usage OSI priority such that priority > *pPriorityJustBelow if this is possible with the current target configuration and privlages.
LIBCOM_API epicsThreadBooleanStatus epicsStdCall epicsThreadLowestPriorityLevelAbove ( unsigned int  priority,
unsigned *  pPriorityJustAbove
Lookup the next usage OSI priority such that priority < *pPriorityJustBelow if this is possible with the current target configuration and privlages.
LIBCOM_API int epicsStdCall epicsThreadIsEqual ( epicsThreadId  id1,
epicsThreadId  id2
Test if two thread IDs actually refer to the same OS thread
LIBCOM_API int epicsStdCall epicsThreadIsSuspended ( epicsThreadId  id)
How and why a thread can be suspended is implementation dependent. A thread calling epicsThreadSuspendSelf() should result in this routine returning true for that thread, but a thread may also be suspended for other reasons.
LIBCOM_API void epicsStdCall epicsThreadSleep ( double  seconds)
Parameters
secondsTime to wait in seconds. Values <=0 blocks for the shortest possible time.
LIBCOM_API double epicsStdCall epicsThreadSleepQuantum ( void  )
Returns
A value in seconds >=0
Warning
On targets other than vxWorks and RTEMS, the quantum value often isn't meaningful. Use of this function is discouraged in portable code.
LIBCOM_API epicsThreadId epicsStdCall epicsThreadGetIdSelf ( void  )
Find an epicsThreadId associated with the current thread. For non-EPICS threads, a new epicsThreadId may be allocated.
LIBCOM_API epicsThreadId epicsStdCall epicsThreadGetId ( const char *  name)
Attempt to find the first instance of a thread by name.
Returns
An epicsThreadId, or NULL if no such thread is currently running. Note that a non-NULL ID may still be invalid if this call races with thread exit.
Warning
Safe use of this function requires external knowledge that this thread will not return.
LIBCOM_API int epicsThreadGetCPUs ( void  )
Return a value approximating the number of threads which this target can run in parallel. This value is advisory.
Returns
>=1
LIBCOM_API const char* epicsStdCall epicsThreadGetNameSelf ( void  )
Return the name of the current thread.
Returns
Never NULL. Storage lifetime tied to epicsThreadId.
This is either a copy of the string passed to epicsThread*Create*(), or an arbitrary unique string for non-EPICS threads.
LIBCOM_API void epicsStdCall epicsThreadGetName ( epicsThreadId  id,
char *  name,
size_t  size
Copy out the thread name into the provided buffer.
Guaranteed to be null terminated. size is number of bytes in buffer to hold name (including terminator). Failure results in an empty string stored in name.
LIBCOM_API int epicsStdCall epicsThreadIsOkToBlock ( void  )
Is it OK for a thread to block? This can be called by support code that does not know if it is called in a thread that should not block. For example the errlog system calls this to decide when messages should be displayed on the console.
LIBCOM_API void epicsStdCall epicsThreadSetOkToBlock ( int  isOkToBlock)
When a thread is started the default is that it is not allowed to block. This method can be called to change the state. For example iocsh calls this to specify that it is OK to block.
LIBCOM_API void epicsStdCall epicsThreadShowAll ( unsigned int  level)
Print to stdout information about all running EPICS threads.
Parameters
level0 prints minimal output. Higher values print more details.
LIBCOM_API void epicsStdCall epicsThreadShow ( epicsThreadId  id,
unsigned int  level
Print info about a single EPICS thread.
LIBCOM_API int epicsThreadHookAdd ( EPICS_THREAD_HOOK_ROUTINE  hook)
Register a routine to be called by every new thread before the thread function gets run. Hook routines will often register a thread exit routine with epicsAtThreadExit() to release thread-specific resources they have allocated.
LIBCOM_API int epicsThreadHookDelete ( EPICS_THREAD_HOOK_ROUTINE  hook)
Remove routine from the list of hooks run at thread creation time.
LIBCOM_API void epicsThreadHooksShow ( void  )
Print the current list of hook function pointers.
LIBCOM_API void epicsThreadMap ( EPICS_THREAD_HOOK_ROUTINE  func)
Call func once for every known thread.
LIBCOM_API epicsThreadPrivateId epicsStdCall epicsThreadPrivateCreate ( void  )
Allocate a new thread local variable. This variable will initially hold NULL for each thread.
LIBCOM_API void epicsStdCall epicsThreadPrivateDelete ( epicsThreadPrivateId  id)
Free a thread local variable
LIBCOM_API void epicsStdCall epicsThreadPrivateSet ( epicsThreadPrivateId  ,
void *
Update thread local variable
LIBCOM_API void* epicsStdCall epicsThreadPrivateGet ( epicsThreadPrivateId  )
Fetch the current value of a thread local variable
