EPICS Base  7.0.6.1
Typedefs | Enumerations | Functions
yajl_gen.h File Reference
Interface to YAJL's JSON generation facilities. More...
#include "yajl_common.h"
Include dependency graph for yajl_gen.h:
Typedefs
typedef struct yajl_gen_t * yajl_gen
typedef void(* yajl_print_t )(void *ctx, const char *str, size_t len)
Enumerations
enum  yajl_gen_status {
  yajl_gen_status_ok = 0, yajl_gen_keys_must_be_strings, yajl_max_depth_exceeded, yajl_gen_in_error_state,
  yajl_gen_generation_complete, yajl_gen_invalid_number, yajl_gen_no_buf, yajl_gen_invalid_string
enum  yajl_gen_option {
  yajl_gen_beautify = 0x01, yajl_gen_indent_string = 0x02, yajl_gen_print_callback = 0x04, yajl_gen_validate_utf8 = 0x08,
  yajl_gen_escape_solidus = 0x10, yajl_gen_json5 = 0x20
Functions
YAJL_API int yajl_gen_config (yajl_gen hand, int option,...)
YAJL_API yajl_gen yajl_gen_alloc (const yajl_alloc_funcs *allocFuncs)
YAJL_API void yajl_gen_free (yajl_gen handle)
YAJL_API yajl_gen_status yajl_gen_integer (yajl_gen hand, long long int number)
YAJL_API yajl_gen_status yajl_gen_double (yajl_gen hand, double number)
YAJL_API yajl_gen_status yajl_gen_number (yajl_gen hand, const char *num, size_t len)
YAJL_API yajl_gen_status yajl_gen_string (yajl_gen hand, const unsigned char *str, size_t len)
YAJL_API yajl_gen_status yajl_gen_null (yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_bool (yajl_gen hand, int boolean)
YAJL_API yajl_gen_status yajl_gen_map_open (yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_map_close (yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_array_open (yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_array_close (yajl_gen hand)
YAJL_API yajl_gen_status yajl_gen_get_buf (yajl_gen hand, const unsigned char **buf, size_t *len)
YAJL_API void yajl_gen_clear (yajl_gen hand)
YAJL_API void yajl_gen_reset (yajl_gen hand, const char *sep)
Detailed Description
Author
Lloyd Hilaiel
Definition in file yajl_gen.h.
Typedef Documentation
typedef struct yajl_gen_t* yajl_gen
An opaque handle to a generator.
Definition at line 59 of file yajl_gen.h.
typedef void(* yajl_print_t)(void *ctx, const char *str, size_t len)
A callback used for "printing" the results.
Definition at line 62 of file yajl_gen.h.
Enumeration Type Documentation
Generator status codes.
Enumerator
yajl_gen_status_ok
No error.
At a point where a map key is generated, a function other than yajl_gen_string() was called.
YAJL's maximum generation depth was exceeded. See YAJL_MAX_DEPTH
A yajl_gen_XXX() generator function was called while in an error state.
A complete JSON document has been generated.
yajl_gen_double() was passed an invalid floating point value (infinity or NaN) without yajl_gen_json5 set.
yajl_gen_no_buf
A print callback was passed in, so there is no internal buffer to get from.
Returned from yajl_gen_string() when the yajl_gen_validate_utf8 option is enabled and an invalid UTF8 code was passed by client.
Definition at line 32 of file yajl_gen.h.
Configuration parameters for the parser, these may be passed to yajl_gen_config() along with option-specific argument(s). In general, all configuration parameters default to off.
Enumerator
yajl_gen_beautify
Generate indented (beautiful) output.
   yajl_gen_config() argument type: int (boolean)
   Example:@code {.cpp}
   yajl_gen_config(g, yajl_gen_beautify, 1); // Human format please
   \endcode
Set the indent string which is used when yajl_gen_beautify is enabled, which may only contain whitespace characters such as \t or some number of spaces. The default is four spaces ' '.
yajl_gen_config() argument type: const char *
Example:
Set a function and context argument that should be used to output the generated json. The function should conform to the yajl_print_t prototype while the context argument may be any void * of your choosing.
yajl_gen_config() arguments: yajl_print_t, void *
Example:
Normally the generator does not validate that strings you pass to it via yajl_gen_string() are valid UTF8. Enabling this option will cause it to do so.
Example:
The forward solidus (slash or '/' in human) is not required to be escaped in JSON text. By default, YAJL will not escape it in the interest of saving bytes. Setting this flag will cause YAJL to always escape '/' in generated JSON strings.
yajl_gen_json5
JSON5 is an updated version of JSON with additional capabilities. Special numbers such as NaN and Infinity cannot be represented in the original JSON, but are permitted in JSON5. Setting this flag allows YAJL to output the JSON5 representation of these special numbers instead of returning with an error, and to emit map keys that are valid javascript identifiers without quotes.
Example:
yajl_gen_config(g, yajl_gen_json5, 1); // Output JSON5
Definition at line 69 of file yajl_gen.h.
Function Documentation
YAJL_API int yajl_gen_config ( yajl_gen  hand,
int  option,
Set generator options associated with a generator handle. See the yajl_gen_option documentation for details of the available options and their arguments.
Returns
Zero in case of error, non-zero otherwise.
YAJL_API yajl_gen yajl_gen_alloc ( const yajl_alloc_funcs *  allocFuncs)
Allocate a generator handle.
Parameters
allocFuncsAn optional pointer to a structure which allows the client to provide memory allocation functions for use by yajl. May be NULL to use the C runtime library's malloc(), free() and realloc().
Returns
An allocated handle on success, NULL on failure (bad params)
YAJL_API void yajl_gen_free ( yajl_gen  handle)
Free a generator handle.
YAJL_API yajl_gen_status yajl_gen_integer ( yajl_gen  hand,
Generate an integer number.
YAJL_API yajl_gen_status yajl_gen_double ( yajl_gen  hand,
double  number
Generate a floating point number.
Parameters
handThe generator handle.
numberThe value to output. The values Infinity or NaN are only accepted if the yajl_gen_json5 option is set, as these values have no legal representation in JSON; the generator will return yajl_gen_invalid_number otherwise.
YAJL_API yajl_gen_status yajl_gen_number ( yajl_gen  hand,
const char *  num,
size_t  len
Generate a number from the string given in num.
YAJL_API yajl_gen_status yajl_gen_string ( yajl_gen  hand,
const unsigned char *  str,
size_t  len
Generate a string value or map key from str.
YAJL_API yajl_gen_status yajl_gen_null ( yajl_gen  hand)
Generate a null value.
YAJL_API yajl_gen_status yajl_gen_bool ( yajl_gen  hand,
int  boolean
Generate a true or false value from boolean.
YAJL_API yajl_gen_status yajl_gen_map_open ( yajl_gen  hand)
Start generating a JSON map. This should be followed by calls to yajl_gen_string() to provide a key and another yajl_gen routine to provide the value associated with that key.
YAJL_API yajl_gen_status yajl_gen_map_close ( yajl_gen  hand)
Finish generating a JSON map.
YAJL_API yajl_gen_status yajl_gen_array_open ( yajl_gen  hand)
Start generating a JSON array.
YAJL_API yajl_gen_status yajl_gen_array_close ( yajl_gen  hand)
Finish generating a JSON array.
YAJL_API yajl_gen_status yajl_gen_get_buf ( yajl_gen  hand,
const unsigned char **  buf,
size_t *  len
Access the zero-terminated generator buffer. If incrementally outputting JSON, one should call yajl_gen_clear() to clear the buffer. This allows stream generation.
YAJL_API void yajl_gen_clear ( yajl_gen  hand)
Clear yajl's output buffer, but maintain all internal generation state. This function will not reset the generator state, and is intended to enable incremental JSON output.
YAJL_API void yajl_gen_reset ( yajl_gen  hand,
const char *  sep
Reset the generator state. Allows a client to generate multiple JSON entities in a stream.
Parameters
sepThis string will be inserted to separate the previously generated output from the following; passing NULL means no separation of entities (beware that generating multiple JSON numbers without a separator creates ambiguous output).
Note: This call does not clear yajl's output buffer, which must be accomplished explicitly by calling yajl_gen_clear().
