EPICS Base
7.0.7.0
C++ and C descriptions for a thread. More...
#include <stddef.h>#include "libComAPI.h"#include "compilerDependencies.h"#include "epicsEvent.h"#include "epicsMutex.h"#include "osdThread.h"
Classes | |
| struct | epicsThreadOpts |
| class | epicsThreadRunable |
| Interface used with class epicsThread. More... | |
| class | epicsThread |
| An OS thread. More... | |
| class | epicsThreadPrivateBase |
| class | epicsThreadPrivateBase::unableToCreateThreadPrivate |
| class | epicsThreadPrivate< T > |
Macros | |
| #define | EPICS_THREAD_ONCE_INIT 0 |
| #define | EPICS_THREAD_OPTS_INIT |
| #define | EPICS_THREAD_CAN_JOIN |
Some Named Thread Priorities | |
| #define | epicsThreadPriorityMax 99 |
| #define | epicsThreadPriorityMin 0 |
| #define | epicsThreadPriorityLow 10 |
| #define | epicsThreadPriorityMedium 50 |
| #define | epicsThreadPriorityHigh 90 |
| #define | epicsThreadPriorityCAServerLow 20 |
| #define | epicsThreadPriorityCAServerHigh 40 |
| #define | epicsThreadPriorityScanLow 60 |
| #define | epicsThreadPriorityScanHigh 70 |
| #define | epicsThreadPriorityIocsh 91 |
| #define | epicsThreadPriorityBaseMax 91 |
Typedefs | |
| typedef void(* | EPICSTHREADFUNC )(void *parm) |
| typedef epicsThreadId | epicsThreadOnceId |
| typedef void(* | EPICS_THREAD_HOOK_ROUTINE )(epicsThreadId id) |
| typedef struct epicsThreadPrivateOSD * | epicsThreadPrivateId |
Enumerations | |
| enum | epicsThreadStackSizeClass { epicsThreadStackSmall, epicsThreadStackMedium, epicsThreadStackBig } |
| enum | epicsThreadBooleanStatus { epicsThreadBooleanStatusFail, epicsThreadBooleanStatusSuccess } |
Functions | |
| LIBCOM_API unsigned int epicsStdCall | epicsThreadGetStackSize (epicsThreadStackSizeClass size) |
| LIBCOM_API void epicsStdCall | epicsThreadOnce (epicsThreadOnceId *id, EPICSTHREADFUNC, void *arg) |
| LIBCOM_API void | epicsThreadRealtimeLock (void) |
| LIBCOM_API void epicsStdCall | epicsThreadExitMain (void) EPICS_DEPRECATED |
| LIBCOM_API epicsThreadId | epicsThreadCreateOpt (const char *name, EPICSTHREADFUNC funptr, void *parm, const epicsThreadOpts *opts) |
| Allocate and start a new OS thread. More... | |
| LIBCOM_API epicsThreadId epicsStdCall | epicsThreadCreate (const char *name, unsigned int priority, unsigned int stackSize, EPICSTHREADFUNC funptr, void *parm) |
| LIBCOM_API epicsThreadId epicsStdCall | epicsThreadMustCreate (const char *name, unsigned int priority, unsigned int stackSize, EPICSTHREADFUNC funptr, void *parm) |
| LIBCOM_API void | epicsThreadMustJoin (epicsThreadId id) |
| LIBCOM_API void epicsStdCall | epicsThreadSuspendSelf (void) |
| LIBCOM_API void epicsStdCall | epicsThreadResume (epicsThreadId id) |
| LIBCOM_API unsigned int epicsStdCall | epicsThreadGetPriority (epicsThreadId id) |
| LIBCOM_API unsigned int epicsStdCall | epicsThreadGetPrioritySelf (void) |
| LIBCOM_API void epicsStdCall | epicsThreadSetPriority (epicsThreadId id, unsigned int priority) |
| LIBCOM_API epicsThreadBooleanStatus epicsStdCall | epicsThreadHighestPriorityLevelBelow (unsigned int priority, unsigned *pPriorityJustBelow) |
| LIBCOM_API epicsThreadBooleanStatus epicsStdCall | epicsThreadLowestPriorityLevelAbove (unsigned int priority, unsigned *pPriorityJustAbove) |
| LIBCOM_API int epicsStdCall | epicsThreadIsEqual (epicsThreadId id1, epicsThreadId id2) |
| LIBCOM_API int epicsStdCall | epicsThreadIsSuspended (epicsThreadId id) |
| LIBCOM_API void epicsStdCall | epicsThreadSleep (double seconds) |
| Block the calling thread for at least the specified time. More... | |
| LIBCOM_API double epicsStdCall | epicsThreadSleepQuantum (void) |
| Query a value approximating the OS timer/scheduler resolution. More... | |
| LIBCOM_API epicsThreadId epicsStdCall | epicsThreadGetIdSelf (void) |
| LIBCOM_API epicsThreadId epicsStdCall | epicsThreadGetId (const char *name) |
| LIBCOM_API int | epicsThreadGetCPUs (void) |
| LIBCOM_API const char *epicsStdCall | epicsThreadGetNameSelf (void) |
| LIBCOM_API void epicsStdCall | epicsThreadGetName (epicsThreadId id, char *name, size_t size) |
| LIBCOM_API int epicsStdCall | epicsThreadIsOkToBlock (void) |
| LIBCOM_API void epicsStdCall | epicsThreadSetOkToBlock (int isOkToBlock) |
| LIBCOM_API void epicsStdCall | epicsThreadShowAll (unsigned int level) |
| LIBCOM_API void epicsStdCall | epicsThreadShow (epicsThreadId id, unsigned int level) |
| LIBCOM_API int | epicsThreadHookAdd (EPICS_THREAD_HOOK_ROUTINE hook) |
| LIBCOM_API int | epicsThreadHookDelete (EPICS_THREAD_HOOK_ROUTINE hook) |
| LIBCOM_API void | epicsThreadHooksShow (void) |
| LIBCOM_API void | epicsThreadMap (EPICS_THREAD_HOOK_ROUTINE func) |
| LIBCOM_API epicsThreadPrivateId epicsStdCall | epicsThreadPrivateCreate (void) |
| LIBCOM_API void epicsStdCall | epicsThreadPrivateDelete (epicsThreadPrivateId id) |
| LIBCOM_API void epicsStdCall | epicsThreadPrivateSet (epicsThreadPrivateId, void *) |
| LIBCOM_API void *epicsStdCall | epicsThreadPrivateGet (epicsThreadPrivateId) |
| void | epicsThreadCallEntryPoint (void *) |
The epicsThread API is meant as a somewhat minimal interface for multithreaded applications. It can be implemented on a wide variety of systems with the restriction that the system MUST support a multithreaded environment. A POSIX pthreads version is provided.
The interface provides the following thread facilities, with restrictions as noted:
Definition in file epicsThread.h.
| #define EPICS_THREAD_OPTS_INIT |
Default initial values for epicsThreadOpts Applications should always use this macro to initialize an epicsThreadOpts structure. Additional fields may be added in the future, and the order of the fields might also change, thus code that assumes the above definition might break if these rules are not followed.
Definition at line 173 of file epicsThread.h.
| typedef void(* EPICS_THREAD_HOOK_ROUTINE)(epicsThreadId id) |
Hooks called when a thread starts, map function called once for every thread.
Definition at line 308 of file epicsThread.h.
| typedef struct epicsThreadPrivateOSD* epicsThreadPrivateId |
Thread local storage
Definition at line 334 of file epicsThread.h.
Stack sizes for each stackSizeClass are implementation and CPU dependent.
Definition at line 91 of file epicsThread.h.
| LIBCOM_API unsigned int epicsStdCall epicsThreadGetStackSize | ( | epicsThreadStackSizeClass | size | ) |
Get a stack size value that can be given to epicsThreadCreate().
| size | one of the values epicsThreadStackSmall, epicsThreadStackMedium or epicsThreadStackBig. |
| LIBCOM_API void epicsStdCall epicsThreadOnce | ( | epicsThreadOnceId * | id, |
| EPICSTHREADFUNC | , | ||
| void * | arg | ||
Perform one-time initialization.
Run the provided function if it has not run, and is not running in some other thread.
For each unique epicsThreadOnceId, epicsThreadOnce guarantees that
| LIBCOM_API void epicsThreadRealtimeLock | ( | void | ) |
When real-time scheduling is active, attempt any post-init operations that preserve real-time performance. For POSIX targets this locks the process into RAM, preventing swap-related VM faults.
| LIBCOM_API void epicsStdCall epicsThreadExitMain | ( | void | ) |
If the main routine is done but wants to let other threads run it can call this routine. This should be the last call in main, except the final return. On most systems epicsThreadExitMain never returns.This must only be called by the main thread.
| LIBCOM_API epicsThreadId epicsThreadCreateOpt | ( | const char * | name, |
| EPICSTHREADFUNC | funptr, | ||
| void * | parm, | ||
| const epicsThreadOpts * | opts | ||
| name | A name describing this thread. Appears in various log and error message. |
| funptr | The thread main function. |
| parm | Passed to thread main function. |
| opts | Modifiers for the new thread, or NULL to use target specific defaults. |
| LIBCOM_API epicsThreadId epicsStdCall epicsThreadCreate | ( | const char * | name, |
| unsigned int | priority, | ||
| unsigned int | stackSize, | ||
| void * | parm | ||
Short-hand for epicsThreadCreateOpt() to create an un-joinable thread.
| LIBCOM_API epicsThreadId epicsStdCall epicsThreadMustCreate | ( | const char * | name, |
| void * | parm | ||
Short-hand for epicsThreadCreateOpt() to create an un-joinable thread. On error calls cantProceed()
| LIBCOM_API void epicsThreadMustJoin | ( | epicsThreadId | id | ) |
Wait for a joinable thread to exit (return from its main function)
| LIBCOM_API void epicsStdCall epicsThreadSuspendSelf | ( | void | ) |
Block the current thread until epicsThreadResume().
| LIBCOM_API void epicsStdCall epicsThreadResume | ( | epicsThreadId | id | ) |
Resume a thread suspended with epicsThreadSuspendSelf()
| LIBCOM_API unsigned int epicsStdCall epicsThreadGetPriority | ( | epicsThreadId | id | ) |
Return thread OSI priority
| LIBCOM_API unsigned int epicsStdCall epicsThreadGetPrioritySelf | ( | void | ) |
| LIBCOM_API void epicsStdCall epicsThreadSetPriority | ( | epicsThreadId | id, |
| unsigned int | priority | ||
Change OSI priority of target thread.
| LIBCOM_API epicsThreadBooleanStatus epicsStdCall epicsThreadHighestPriorityLevelBelow | ( | unsigned int | priority, |
| unsigned * | pPriorityJustBelow | ||
Lookup the next usage OSI priority such that priority > *pPriorityJustBelow if this is possible with the current target configuration and privlages.
| LIBCOM_API epicsThreadBooleanStatus epicsStdCall epicsThreadLowestPriorityLevelAbove | ( | unsigned int | priority, |
| unsigned * | pPriorityJustAbove | ||
Lookup the next usage OSI priority such that priority < *pPriorityJustBelow if this is possible with the current target configuration and privlages.
| LIBCOM_API int epicsStdCall epicsThreadIsEqual | ( | epicsThreadId | id1, |
| epicsThreadId | id2 | ||
Test if two thread IDs actually refer to the same OS thread
| LIBCOM_API int epicsStdCall epicsThreadIsSuspended | ( | epicsThreadId | id | ) |
How and why a thread can be suspended is implementation dependent. A thread calling epicsThreadSuspendSelf() should result in this routine returning true for that thread, but a thread may also be suspended for other reasons.
| LIBCOM_API void epicsStdCall epicsThreadSleep | ( | double | seconds | ) |
| seconds | Time to wait in seconds. Values <=0 blocks for the shortest possible time. |
| LIBCOM_API double epicsStdCall epicsThreadSleepQuantum | ( | void | ) |
| LIBCOM_API epicsThreadId epicsStdCall epicsThreadGetIdSelf | ( | void | ) |
Find an epicsThreadId associated with the current thread. For non-EPICS threads, a new epicsThreadId may be allocated.
| LIBCOM_API epicsThreadId epicsStdCall epicsThreadGetId | ( | const char * | name | ) |
Attempt to find the first instance of a thread by name.
| LIBCOM_API int epicsThreadGetCPUs | ( | void | ) |
Return a value approximating the number of threads which this target can run in parallel. This value is advisory.
| LIBCOM_API const char* epicsStdCall epicsThreadGetNameSelf | ( | void | ) |
Return the name of the current thread.
This is either a copy of the string passed to epicsThread*Create*(), or an arbitrary unique string for non-EPICS threads.
| LIBCOM_API void epicsStdCall epicsThreadGetName | ( | epicsThreadId | id, |
| char * | name, | ||
| size_t | size | ||
Copy out the thread name into the provided buffer.
Guaranteed to be null terminated. size is number of bytes in buffer to hold name (including terminator). Failure results in an empty string stored in name.
| LIBCOM_API int epicsStdCall epicsThreadIsOkToBlock | ( | void | ) |
Is it OK for a thread to block? This can be called by support code that does not know if it is called in a thread that should not block. For example the errlog system calls this to decide when messages should be displayed on the console.
| LIBCOM_API void epicsStdCall epicsThreadSetOkToBlock | ( | int | isOkToBlock | ) |
When a thread is started the default is that it is not allowed to block. This method can be called to change the state. For example iocsh calls this to specify that it is OK to block.
| LIBCOM_API void epicsStdCall epicsThreadShowAll | ( | unsigned int | level | ) |
Print to stdout information about all running EPICS threads.
| level | 0 prints minimal output. Higher values print more details. |
| LIBCOM_API void epicsStdCall epicsThreadShow | ( | epicsThreadId | id, |
| unsigned int | level | ||
Print info about a single EPICS thread.
| LIBCOM_API int epicsThreadHookAdd | ( | EPICS_THREAD_HOOK_ROUTINE | hook | ) |
Register a routine to be called by every new thread before the thread function gets run. Hook routines will often register a thread exit routine with epicsAtThreadExit() to release thread-specific resources they have allocated.
| LIBCOM_API int epicsThreadHookDelete | ( | EPICS_THREAD_HOOK_ROUTINE | hook | ) |
Remove routine from the list of hooks run at thread creation time.
| LIBCOM_API void epicsThreadHooksShow | ( | void | ) |
Print the current list of hook function pointers.
| LIBCOM_API void epicsThreadMap | ( | EPICS_THREAD_HOOK_ROUTINE | func | ) |
Call func once for every known thread.
| LIBCOM_API epicsThreadPrivateId epicsStdCall epicsThreadPrivateCreate | ( | void | ) |
Allocate a new thread local variable. This variable will initially hold NULL for each thread.
| LIBCOM_API void epicsStdCall epicsThreadPrivateDelete | ( | epicsThreadPrivateId | id | ) |
Free a thread local variable
| LIBCOM_API void epicsStdCall epicsThreadPrivateSet | ( | epicsThreadPrivateId | , |
| void * | |||
Update thread local variable
| LIBCOM_API void* epicsStdCall epicsThreadPrivateGet | ( | epicsThreadPrivateId | ) |
Fetch the current value of a thread local variable
1.8.5
