EPICS Base  7.0.7.0
stringinRecord.h
1
7 #ifndef INC_stringinRecord_H
8 #define INC_stringinRecord_H
9
10 #include "epicsTypes.h"
11 #include "link.h"
12 #include "epicsMutex.h"
13 #include "ellLib.h"
14 #include "devSup.h"
15 #include "epicsTime.h"
16
17 /* Declare Device Support Entry Table */
18 struct stringinRecord;
19 typedef struct stringindset {
20  dset common; /*init_record returns: (-1,0)=>(failure,success)*/
21  long (*read_stringin)(struct stringinRecord *prec); /*returns: (-1,0)=>(failure,success)*/
22 } stringindset;
23 #define HAS_stringindset
24
25 #include "callback.h"
26
27 #ifndef stringinPOST_NUM_CHOICES
28
29 typedef enum {
32 } stringinPOST;
34 #define stringinPOST_NUM_CHOICES 2
35 #endif
36
38 typedef struct stringinRecord {
39  char name[61];
40  char desc[41];
41  char asg[29];
42  epicsEnum16 scan;
43  epicsEnum16 pini;
44  epicsInt16 phas;
45  char evnt[40];
46  epicsInt16 tse;
47  DBLINK tsel;
48  epicsEnum16 dtyp;
49  epicsInt16 disv;
50  epicsInt16 disa;
51  DBLINK sdis;
55  epicsUInt8 disp;
56  epicsUInt8 proc;
57  epicsEnum16 stat;
58  epicsEnum16 sevr;
59  char amsg[40];
60  epicsEnum16 nsta;
61  epicsEnum16 nsev;
62  char namsg[40];
63  epicsEnum16 acks;
64  epicsEnum16 ackt;
65  epicsEnum16 diss;
66  epicsUInt8 lcnt;
67  epicsUInt8 pact;
68  epicsUInt8 putf;
69  epicsUInt8 rpro;
70  struct asgMember *asp;
71  struct processNotify *ppn;
72  struct processNotifyRecord *ppnr;
73  struct scan_element *spvt;
74  struct typed_rset *rset;
76  void *dpvt;
77  struct dbRecordType *rdes;
78  struct lockRecord *lset;
79  epicsEnum16 prio;
80  epicsUInt8 tpro;
81  epicsUInt8 bkpt;
82  epicsUInt8 udf;
83  epicsEnum16 udfs;
85  epicsUInt64 utag;
86  DBLINK flnk;
87  char val[40];
88  char oval[40];
89  DBLINK inp;
90  epicsEnum16 mpst;
91  epicsEnum16 apst;
92  DBLINK siol;
93  char sval[40];
94  DBLINK siml;
95  epicsEnum16 simm;
96  epicsEnum16 sims;
97  epicsEnum16 oldsimm;
98  epicsEnum16 sscn;
99  epicsFloat64 sdly;
102
103 typedef enum {
104  stringinRecordNAME = 0,
105  stringinRecordDESC = 1,
106  stringinRecordASG = 2,
107  stringinRecordSCAN = 3,
108  stringinRecordPINI = 4,
109  stringinRecordPHAS = 5,
110  stringinRecordEVNT = 6,
111  stringinRecordTSE = 7,
112  stringinRecordTSEL = 8,
113  stringinRecordDTYP = 9,
114  stringinRecordDISV = 10,
115  stringinRecordDISA = 11,
116  stringinRecordSDIS = 12,
117  stringinRecordMLOK = 13,
118  stringinRecordMLIS = 14,
119  stringinRecordBKLNK = 15,
120  stringinRecordDISP = 16,
121  stringinRecordPROC = 17,
122  stringinRecordSTAT = 18,
123  stringinRecordSEVR = 19,
124  stringinRecordAMSG = 20,
125  stringinRecordNSTA = 21,
126  stringinRecordNSEV = 22,
127  stringinRecordNAMSG = 23,
128  stringinRecordACKS = 24,
129  stringinRecordACKT = 25,
130  stringinRecordDISS = 26,
131  stringinRecordLCNT = 27,
132  stringinRecordPACT = 28,
133  stringinRecordPUTF = 29,
134  stringinRecordRPRO = 30,
135  stringinRecordASP = 31,
136  stringinRecordPPN = 32,
137  stringinRecordPPNR = 33,
138  stringinRecordSPVT = 34,
139  stringinRecordRSET = 35,
140  stringinRecordDSET = 36,
141  stringinRecordDPVT = 37,
142  stringinRecordRDES = 38,
143  stringinRecordLSET = 39,
144  stringinRecordPRIO = 40,
145  stringinRecordTPRO = 41,
146  stringinRecordBKPT = 42,
147  stringinRecordUDF = 43,
148  stringinRecordUDFS = 44,
149  stringinRecordTIME = 45,
150  stringinRecordUTAG = 46,
151  stringinRecordFLNK = 47,
152  stringinRecordVAL = 48,
153  stringinRecordOVAL = 49,
154  stringinRecordINP = 50,
155  stringinRecordMPST = 51,
156  stringinRecordAPST = 52,
157  stringinRecordSIOL = 53,
158  stringinRecordSVAL = 54,
159  stringinRecordSIML = 55,
160  stringinRecordSIMM = 56,
161  stringinRecordSIMS = 57,
162  stringinRecordOLDSIMM = 58,
163  stringinRecordSSCN = 59,
164  stringinRecordSDLY = 60,
165  stringinRecordSIMPVT = 61
166 } stringinFieldIndex;
167
168 #ifdef GEN_SIZE_OFFSET
169
170 #include <epicsExport.h>
171 #include <cantProceed.h>
172 #ifdef __cplusplus
173 extern "C" {
174 #endif
175 static int stringinRecordSizeOffset(dbRecordType *prt)
176 {
177  stringinRecord *prec = 0;
178
179  if (prt->no_fields != 62) {
180  cantProceed("IOC build or installation error:\n"
181  " The stringinRecord defined in the DBD file has %d fields,\n"
182  " but the record support code was built with 62.\n",
183  prt->no_fields);
184  }
185  prt->papFldDes[stringinRecordNAME]->size = sizeof(prec->name);
186  prt->papFldDes[stringinRecordNAME]->offset = (unsigned short)((char *)&prec->name - (char *)prec);
187  prt->papFldDes[stringinRecordDESC]->size = sizeof(prec->desc);
188  prt->papFldDes[stringinRecordDESC]->offset = (unsigned short)((char *)&prec->desc - (char *)prec);
189  prt->papFldDes[stringinRecordASG]->size = sizeof(prec->asg);
190  prt->papFldDes[stringinRecordASG]->offset = (unsigned short)((char *)&prec->asg - (char *)prec);
191  prt->papFldDes[stringinRecordSCAN]->size = sizeof(prec->scan);
192  prt->papFldDes[stringinRecordSCAN]->offset = (unsigned short)((char *)&prec->scan - (char *)prec);
193  prt->papFldDes[stringinRecordPINI]->size = sizeof(prec->pini);
194  prt->papFldDes[stringinRecordPINI]->offset = (unsigned short)((char *)&prec->pini - (char *)prec);
195  prt->papFldDes[stringinRecordPHAS]->size = sizeof(prec->phas);
196  prt->papFldDes[stringinRecordPHAS]->offset = (unsigned short)((char *)&prec->phas - (char *)prec);
197  prt->papFldDes[stringinRecordEVNT]->size = sizeof(prec->evnt);
198  prt->papFldDes[stringinRecordEVNT]->offset = (unsigned short)((char *)&prec->evnt - (char *)prec);
199  prt->papFldDes[stringinRecordTSE]->size = sizeof(prec->tse);
200  prt->papFldDes[stringinRecordTSE]->offset = (unsigned short)((char *)&prec->tse - (char *)prec);
201  prt->papFldDes[stringinRecordTSEL]->size = sizeof(prec->tsel);
202  prt->papFldDes[stringinRecordTSEL]->offset = (unsigned short)((char *)&prec->tsel - (char *)prec);
203  prt->papFldDes[stringinRecordDTYP]->size = sizeof(prec->dtyp);
204  prt->papFldDes[stringinRecordDTYP]->offset = (unsigned short)((char *)&prec->dtyp - (char *)prec);
205  prt->papFldDes[stringinRecordDISV]->size = sizeof(prec->disv);
206  prt->papFldDes[stringinRecordDISV]->offset = (unsigned short)((char *)&prec->disv - (char *)prec);
207  prt->papFldDes[stringinRecordDISA]->size = sizeof(prec->disa);
208  prt->papFldDes[stringinRecordDISA]->offset = (unsigned short)((char *)&prec->disa - (char *)prec);
209  prt->papFldDes[stringinRecordSDIS]->size = sizeof(prec->sdis);
210  prt->papFldDes[stringinRecordSDIS]->offset = (unsigned short)((char *)&prec->sdis - (char *)prec);
211  prt->papFldDes[stringinRecordMLOK]->size = sizeof(prec->mlok);
212  prt->papFldDes[stringinRecordMLOK]->offset = (unsigned short)((char *)&prec->mlok - (char *)prec);
213  prt->papFldDes[stringinRecordMLIS]->size = sizeof(prec->mlis);
214  prt->papFldDes[stringinRecordMLIS]->offset = (unsigned short)((char *)&prec->mlis - (char *)prec);
215  prt->papFldDes[stringinRecordBKLNK]->size = sizeof(prec->bklnk);
216  prt->papFldDes[stringinRecordBKLNK]->offset = (unsigned short)((char *)&prec->bklnk - (char *)prec);
217  prt->papFldDes[stringinRecordDISP]->size = sizeof(prec->disp);
218  prt->papFldDes[stringinRecordDISP]->offset = (unsigned short)((char *)&prec->disp - (char *)prec);
219  prt->papFldDes[stringinRecordPROC]->size = sizeof(prec->proc);
220  prt->papFldDes[stringinRecordPROC]->offset = (unsigned short)((char *)&prec->proc - (char *)prec);
221  prt->papFldDes[stringinRecordSTAT]->size = sizeof(prec->stat);
222  prt->papFldDes[stringinRecordSTAT]->offset = (unsigned short)((char *)&prec->stat - (char *)prec);
223  prt->papFldDes[stringinRecordSEVR]->size = sizeof(prec->sevr);
224  prt->papFldDes[stringinRecordSEVR]->offset = (unsigned short)((char *)&prec->sevr - (char *)prec);
225  prt->papFldDes[stringinRecordAMSG]->size = sizeof(prec->amsg);
226  prt->papFldDes[stringinRecordAMSG]->offset = (unsigned short)((char *)&prec->amsg - (char *)prec);
227  prt->papFldDes[stringinRecordNSTA]->size = sizeof(prec->nsta);
228  prt->papFldDes[stringinRecordNSTA]->offset = (unsigned short)((char *)&prec->nsta - (char *)prec);
229  prt->papFldDes[stringinRecordNSEV]->size = sizeof(prec->nsev);
230  prt->papFldDes[stringinRecordNSEV]->offset = (unsigned short)((char *)&prec->nsev - (char *)prec);
231  prt->papFldDes[stringinRecordNAMSG]->size = sizeof(prec->namsg);
232  prt->papFldDes[stringinRecordNAMSG]->offset = (unsigned short)((char *)&prec->namsg - (char *)prec);
233  prt->papFldDes[stringinRecordACKS]->size = sizeof(prec->acks);
234  prt->papFldDes[stringinRecordACKS]->offset = (unsigned short)((char *)&prec->acks - (char *)prec);
235  prt->papFldDes[stringinRecordACKT]->size = sizeof(prec->ackt);
236  prt->papFldDes[stringinRecordACKT]->offset = (unsigned short)((char *)&prec->ackt - (char *)prec);
237  prt->papFldDes[stringinRecordDISS]->size = sizeof(prec->diss);
238  prt->papFldDes[stringinRecordDISS]->offset = (unsigned short)((char *)&prec->diss - (char *)prec);
239  prt->papFldDes[stringinRecordLCNT]->size = sizeof(prec->lcnt);
240  prt->papFldDes[stringinRecordLCNT]->offset = (unsigned short)((char *)&prec->lcnt - (char *)prec);
241  prt->papFldDes[stringinRecordPACT]->size = sizeof(prec->pact);
242  prt->papFldDes[stringinRecordPACT]->offset = (unsigned short)((char *)&prec->pact - (char *)prec);
243  prt->papFldDes[stringinRecordPUTF]->size = sizeof(prec->putf);
244  prt->papFldDes[stringinRecordPUTF]->offset = (unsigned short)((char *)&prec->putf - (char *)prec);
245  prt->papFldDes[stringinRecordRPRO]->size = sizeof(prec->rpro);
246  prt->papFldDes[stringinRecordRPRO]->offset = (unsigned short)((char *)&prec->rpro - (char *)prec);
247  prt->papFldDes[stringinRecordASP]->size = sizeof(prec->asp);
248  prt->papFldDes[stringinRecordASP]->offset = (unsigned short)((char *)&prec->asp - (char *)prec);
249  prt->papFldDes[stringinRecordPPN]->size = sizeof(prec->ppn);
250  prt->papFldDes[stringinRecordPPN]->offset = (unsigned short)((char *)&prec->ppn - (char *)prec);
251  prt->papFldDes[stringinRecordPPNR]->size = sizeof(prec->ppnr);
252  prt->papFldDes[stringinRecordPPNR]->offset = (unsigned short)((char *)&prec->ppnr - (char *)prec);
253  prt->papFldDes[stringinRecordSPVT]->size = sizeof(prec->spvt);
254  prt->papFldDes[stringinRecordSPVT]->offset = (unsigned short)((char *)&prec->spvt - (char *)prec);
255  prt->papFldDes[stringinRecordRSET]->size = sizeof(prec->rset);
256  prt->papFldDes[stringinRecordRSET]->offset = (unsigned short)((char *)&prec->rset - (char *)prec);
257  prt->papFldDes[stringinRecordDSET]->size = sizeof(prec->dset);
258  prt->papFldDes[stringinRecordDSET]->offset = (unsigned short)((char *)&prec->dset - (char *)prec);
259  prt->papFldDes[stringinRecordDPVT]->size = sizeof(prec->dpvt);
260  prt->papFldDes[stringinRecordDPVT]->offset = (unsigned short)((char *)&prec->dpvt - (char *)prec);
261  prt->papFldDes[stringinRecordRDES]->size = sizeof(prec->rdes);
262  prt->papFldDes[stringinRecordRDES]->offset = (unsigned short)((char *)&prec->rdes - (char *)prec);
263  prt->papFldDes[stringinRecordLSET]->size = sizeof(prec->lset);
264  prt->papFldDes[stringinRecordLSET]->offset = (unsigned short)((char *)&prec->lset - (char *)prec);
265  prt->papFldDes[stringinRecordPRIO]->size = sizeof(prec->prio);
266  prt->papFldDes[stringinRecordPRIO]->offset = (unsigned short)((char *)&prec->prio - (char *)prec);
267  prt->papFldDes[stringinRecordTPRO]->size = sizeof(prec->tpro);
268  prt->papFldDes[stringinRecordTPRO]->offset = (unsigned short)((char *)&prec->tpro - (char *)prec);
269  prt->papFldDes[stringinRecordBKPT]->size = sizeof(prec->bkpt);
270  prt->papFldDes[stringinRecordBKPT]->offset = (unsigned short)((char *)&prec->bkpt - (char *)prec);
271  prt->papFldDes[stringinRecordUDF]->size = sizeof(prec->udf);
272  prt->papFldDes[stringinRecordUDF]->offset = (unsigned short)((char *)&prec->udf - (char *)prec);
273  prt->papFldDes[stringinRecordUDFS]->size = sizeof(prec->udfs);
274  prt->papFldDes[stringinRecordUDFS]->offset = (unsigned short)((char *)&prec->udfs - (char *)prec);
275  prt->papFldDes[stringinRecordTIME]->size = sizeof(prec->time);
276  prt->papFldDes[stringinRecordTIME]->offset = (unsigned short)((char *)&prec->time - (char *)prec);
277  prt->papFldDes[stringinRecordUTAG]->size = sizeof(prec->utag);
278  prt->papFldDes[stringinRecordUTAG]->offset = (unsigned short)((char *)&prec->utag - (char *)prec);
279  prt->papFldDes[stringinRecordFLNK]->size = sizeof(prec->flnk);
280  prt->papFldDes[stringinRecordFLNK]->offset = (unsigned short)((char *)&prec->flnk - (char *)prec);
281  prt->papFldDes[stringinRecordVAL]->size = sizeof(prec->val);
282  prt->papFldDes[stringinRecordVAL]->offset = (unsigned short)((char *)&prec->val - (char *)prec);
283  prt->papFldDes[stringinRecordOVAL]->size = sizeof(prec->oval);
284  prt->papFldDes[stringinRecordOVAL]->offset = (unsigned short)((char *)&prec->oval - (char *)prec);
285  prt->papFldDes[stringinRecordINP]->size = sizeof(prec->inp);
286  prt->papFldDes[stringinRecordINP]->offset = (unsigned short)((char *)&prec->inp - (char *)prec);
287  prt->papFldDes[stringinRecordMPST]->size = sizeof(prec->mpst);
288  prt->papFldDes[stringinRecordMPST]->offset = (unsigned short)((char *)&prec->mpst - (char *)prec);
289  prt->papFldDes[stringinRecordAPST]->size = sizeof(prec->apst);
290  prt->papFldDes[stringinRecordAPST]->offset = (unsigned short)((char *)&prec->apst - (char *)prec);
291  prt->papFldDes[stringinRecordSIOL]->size = sizeof(prec->siol);
292  prt->papFldDes[stringinRecordSIOL]->offset = (unsigned short)((char *)&prec->siol - (char *)prec);
293  prt->papFldDes[stringinRecordSVAL]->size = sizeof(prec->sval);
294  prt->papFldDes[stringinRecordSVAL]->offset = (unsigned short)((char *)&prec->sval - (char *)prec);
295  prt->papFldDes[stringinRecordSIML]->size = sizeof(prec->siml);
296  prt->papFldDes[stringinRecordSIML]->offset = (unsigned short)((char *)&prec->siml - (char *)prec);
297  prt->papFldDes[stringinRecordSIMM]->size = sizeof(prec->simm);
298  prt->papFldDes[stringinRecordSIMM]->offset = (unsigned short)((char *)&prec->simm - (char *)prec);
299  prt->papFldDes[stringinRecordSIMS]->size = sizeof(prec->sims);
300  prt->papFldDes[stringinRecordSIMS]->offset = (unsigned short)((char *)&prec->sims - (char *)prec);
301  prt->papFldDes[stringinRecordOLDSIMM]->size = sizeof(prec->oldsimm);
302  prt->papFldDes[stringinRecordOLDSIMM]->offset = (unsigned short)((char *)&prec->oldsimm - (char *)prec);
303  prt->papFldDes[stringinRecordSSCN]->size = sizeof(prec->sscn);
304  prt->papFldDes[stringinRecordSSCN]->offset = (unsigned short)((char *)&prec->sscn - (char *)prec);
305  prt->papFldDes[stringinRecordSDLY]->size = sizeof(prec->sdly);
306  prt->papFldDes[stringinRecordSDLY]->offset = (unsigned short)((char *)&prec->sdly - (char *)prec);
307  prt->papFldDes[stringinRecordSIMPVT]->size = sizeof(prec->simpvt);
308  prt->papFldDes[stringinRecordSIMPVT]->offset = (unsigned short)((char *)&prec->simpvt - (char *)prec);
309  prt->rec_size = sizeof(*prec);
310  return 0;
311 }
312 epicsExportRegistrar(stringinRecordSizeOffset);
313
314 #ifdef __cplusplus
315 }
316 #endif
317 #endif /* GEN_SIZE_OFFSET */
318
319 #endif /* INC_stringinRecord_H */
DBLINK sdis
Scanning Disable.
Declaration of stringin record type.
epicsInt16 disv
Disable Value.
epicsUInt8 putf
dbPutField process
epicsEnum16 udfs
Undefined Alarm Sevrty.
epicsEnum16 nsev
New Alarm Severity.
char namsg[40]
New Alarm Message.
epicsEnum16 sevr
Alarm Severity.
epicsInt16 disa
Disable.
struct dbRecordType * rdes
Address of dbRecordType.
DBLINK siol
Simulation Input Link.
epicsEnum16 pini
Process at iocInit.
epicsUInt8 udf
Undefined.
char oval[40]
Previous Value.
DBLINK tsel
Time Stamp Link.
LIBCOM_API void cantProceed(const char *errorMessage,...) EPICS_PRINTF_STYLE(1
Suspend this thread, the caller cannot continue or return.
epicsEnum16 dtyp
Device Type.
epicsCallback * simpvt
Sim. Mode Private.
The core data types used by epics.
struct typed_rset * rset
Address of RSET.
struct processNotify * ppn
pprocessNotify
State string &quot;Always&quot;.
epicsUInt8 proc
Force Processing.
Exporting IOC objects.
epicsEnum16 scan
Scan Mechanism.
epicsEnum16 mpst
Post Value Monitors.
char sval[40]
Simulation Value.
epicsEnum16 sscn
Sim. Mode Scan.
Routines for code that can&#39;t continue or return after an error.
char evnt[40]
Event Name.
DBLINK inp
Input Specification.
epicsUInt8 tpro
Trace Processing.
char desc[41]
Descriptor.
epicsUInt8 pact
Record active.
epicsFloat64 sdly
Sim. Mode Async Delay.
epicsUInt8 rpro
Reprocess.
ELLLIST bklnk
Backwards link tracking.
State string &quot;On Change&quot;.
Definition: devSup.h:141
epicsEnum16 diss
Disable Alarm Sevrty.
epicsUInt8 lcnt
Lock Count.
EPICS time stamp, for use from C code.
Definition: epicsTime.h:42
A doubly-linked list library.
struct asgMember * asp
Access Security Pvt.
epicsEnum16 sims
Simulation Mode Severity.
List header type.
Definition: ellLib.h:57
struct lockRecord * lset
Lock Set.
char name[61]
Record Name.
epicsEnum16 oldsimm
Prev. Simulation Mode.
epicsEnum16 prio
Scheduling Priority.
ELLLIST mlis
Monitor List.
stringinPOST
Enumerated type from menu stringinPOST.
char asg[29]
Access Security Group.
APIs for the epicsMutex mutual exclusion semaphore.
epicsUInt64 utag
Time Tag.
Device support routines.
epicsEnum16 stat
Alarm Status.
struct scan_element * spvt
Scan Private.
epicsEnum16 acks
Alarm Ack Severity.
epicsEnum16 ackt
Alarm Ack Transient.
epicsTimeStamp time
Time.
epicsUInt8 disp
Disable putField.
epicsEnum16 nsta
New Alarm Status.
char amsg[40]
Alarm Message.
#define epicsExportRegistrar(fun)
Declare a registrar function for exporting.
Definition: epicsExport.h:94
unambiguous_dset * dset
DSET address.
DBLINK siml
Simulation Mode Link.
epicsMutexId mlok
Monitor lock.
struct processNotifyRecord * ppnr
pprocessNotifyRecord
DBLINK flnk
Forward Process Link.
void * dpvt
Device Private.
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times...
char val[40]
Current Value.
epicsInt16 phas
Scan Phase.
epicsUInt8 bkpt
Break Point.
epicsInt16 tse
Time Stamp Event.
struct epicsMutexParm * epicsMutexId
An identifier for an epicsMutex for use with the C API.
Definition: epicsMutex.h:49
epicsEnum16 simm
Simulation Mode.
epicsEnum16 apst
Post Archive Monitors.
