EPICS Base  7.0.7.0
waveformRecord.h
1
7 #ifndef INC_waveformRecord_H
8 #define INC_waveformRecord_H
9
10 #include "epicsTypes.h"
11 #include "link.h"
12 #include "epicsMutex.h"
13 #include "ellLib.h"
14 #include "devSup.h"
15 #include "epicsTime.h"
16
17 /* Declare Device Support Entry Table */
18 struct waveformRecord;
19 typedef struct wfdset {
20  dset common; /*init_record returns: (-1,0)=>(failure,success)*/
21  long (*read_wf)(struct waveformRecord *prec); /*returns: (-1,0)=>(failure,success)*/
22 } wfdset;
23 #define HAS_wfdset
24
25 #include "callback.h"
26
27 #ifndef waveformPOST_NUM_CHOICES
28
29 typedef enum {
32 } waveformPOST;
34 #define waveformPOST_NUM_CHOICES 2
35 #endif
36
38 typedef struct waveformRecord {
39  char name[61];
40  char desc[41];
41  char asg[29];
42  epicsEnum16 scan;
43  epicsEnum16 pini;
44  epicsInt16 phas;
45  char evnt[40];
46  epicsInt16 tse;
47  DBLINK tsel;
48  epicsEnum16 dtyp;
49  epicsInt16 disv;
50  epicsInt16 disa;
51  DBLINK sdis;
55  epicsUInt8 disp;
56  epicsUInt8 proc;
57  epicsEnum16 stat;
58  epicsEnum16 sevr;
59  char amsg[40];
60  epicsEnum16 nsta;
61  epicsEnum16 nsev;
62  char namsg[40];
63  epicsEnum16 acks;
64  epicsEnum16 ackt;
65  epicsEnum16 diss;
66  epicsUInt8 lcnt;
67  epicsUInt8 pact;
68  epicsUInt8 putf;
69  epicsUInt8 rpro;
70  struct asgMember *asp;
71  struct processNotify *ppn;
72  struct processNotifyRecord *ppnr;
73  struct scan_element *spvt;
74  struct typed_rset *rset;
76  void *dpvt;
77  struct dbRecordType *rdes;
78  struct lockRecord *lset;
79  epicsEnum16 prio;
80  epicsUInt8 tpro;
81  epicsUInt8 bkpt;
82  epicsUInt8 udf;
83  epicsEnum16 udfs;
85  epicsUInt64 utag;
86  DBLINK flnk;
87  void * val;
88  epicsInt16 rarm;
89  epicsInt16 prec;
90  DBLINK inp;
91  char egu[16];
92  epicsFloat64 hopr;
93  epicsFloat64 lopr;
94  epicsUInt32 nelm;
95  epicsEnum16 ftvl;
96  epicsInt16 busy;
97  epicsUInt32 nord;
98  void * bptr;
99  DBLINK siol;
100  DBLINK siml;
101  epicsEnum16 simm;
102  epicsEnum16 sims;
103  epicsEnum16 oldsimm;
104  epicsEnum16 sscn;
105  epicsFloat64 sdly;
107  epicsEnum16 mpst;
108  epicsEnum16 apst;
109  epicsUInt32 hash;
111
112 typedef enum {
113  waveformRecordNAME = 0,
114  waveformRecordDESC = 1,
115  waveformRecordASG = 2,
116  waveformRecordSCAN = 3,
117  waveformRecordPINI = 4,
118  waveformRecordPHAS = 5,
119  waveformRecordEVNT = 6,
120  waveformRecordTSE = 7,
121  waveformRecordTSEL = 8,
122  waveformRecordDTYP = 9,
123  waveformRecordDISV = 10,
124  waveformRecordDISA = 11,
125  waveformRecordSDIS = 12,
126  waveformRecordMLOK = 13,
127  waveformRecordMLIS = 14,
128  waveformRecordBKLNK = 15,
129  waveformRecordDISP = 16,
130  waveformRecordPROC = 17,
131  waveformRecordSTAT = 18,
132  waveformRecordSEVR = 19,
133  waveformRecordAMSG = 20,
134  waveformRecordNSTA = 21,
135  waveformRecordNSEV = 22,
136  waveformRecordNAMSG = 23,
137  waveformRecordACKS = 24,
138  waveformRecordACKT = 25,
139  waveformRecordDISS = 26,
140  waveformRecordLCNT = 27,
141  waveformRecordPACT = 28,
142  waveformRecordPUTF = 29,
143  waveformRecordRPRO = 30,
144  waveformRecordASP = 31,
145  waveformRecordPPN = 32,
146  waveformRecordPPNR = 33,
147  waveformRecordSPVT = 34,
148  waveformRecordRSET = 35,
149  waveformRecordDSET = 36,
150  waveformRecordDPVT = 37,
151  waveformRecordRDES = 38,
152  waveformRecordLSET = 39,
153  waveformRecordPRIO = 40,
154  waveformRecordTPRO = 41,
155  waveformRecordBKPT = 42,
156  waveformRecordUDF = 43,
157  waveformRecordUDFS = 44,
158  waveformRecordTIME = 45,
159  waveformRecordUTAG = 46,
160  waveformRecordFLNK = 47,
161  waveformRecordVAL = 48,
162  waveformRecordRARM = 49,
163  waveformRecordPREC = 50,
164  waveformRecordINP = 51,
165  waveformRecordEGU = 52,
166  waveformRecordHOPR = 53,
167  waveformRecordLOPR = 54,
168  waveformRecordNELM = 55,
169  waveformRecordFTVL = 56,
170  waveformRecordBUSY = 57,
171  waveformRecordNORD = 58,
172  waveformRecordBPTR = 59,
173  waveformRecordSIOL = 60,
174  waveformRecordSIML = 61,
175  waveformRecordSIMM = 62,
176  waveformRecordSIMS = 63,
177  waveformRecordOLDSIMM = 64,
178  waveformRecordSSCN = 65,
179  waveformRecordSDLY = 66,
180  waveformRecordSIMPVT = 67,
181  waveformRecordMPST = 68,
182  waveformRecordAPST = 69,
183  waveformRecordHASH = 70
184 } waveformFieldIndex;
185
186 #ifdef GEN_SIZE_OFFSET
187
188 #include <epicsExport.h>
189 #include <cantProceed.h>
190 #ifdef __cplusplus
191 extern "C" {
192 #endif
193 static int waveformRecordSizeOffset(dbRecordType *prt)
194 {
195  waveformRecord *prec = 0;
196
197  if (prt->no_fields != 71) {
198  cantProceed("IOC build or installation error:\n"
199  " The waveformRecord defined in the DBD file has %d fields,\n"
200  " but the record support code was built with 71.\n",
201  prt->no_fields);
202  }
203  prt->papFldDes[waveformRecordNAME]->size = sizeof(prec->name);
204  prt->papFldDes[waveformRecordNAME]->offset = (unsigned short)((char *)&prec->name - (char *)prec);
205  prt->papFldDes[waveformRecordDESC]->size = sizeof(prec->desc);
206  prt->papFldDes[waveformRecordDESC]->offset = (unsigned short)((char *)&prec->desc - (char *)prec);
207  prt->papFldDes[waveformRecordASG]->size = sizeof(prec->asg);
208  prt->papFldDes[waveformRecordASG]->offset = (unsigned short)((char *)&prec->asg - (char *)prec);
209  prt->papFldDes[waveformRecordSCAN]->size = sizeof(prec->scan);
210  prt->papFldDes[waveformRecordSCAN]->offset = (unsigned short)((char *)&prec->scan - (char *)prec);
211  prt->papFldDes[waveformRecordPINI]->size = sizeof(prec->pini);
212  prt->papFldDes[waveformRecordPINI]->offset = (unsigned short)((char *)&prec->pini - (char *)prec);
213  prt->papFldDes[waveformRecordPHAS]->size = sizeof(prec->phas);
214  prt->papFldDes[waveformRecordPHAS]->offset = (unsigned short)((char *)&prec->phas - (char *)prec);
215  prt->papFldDes[waveformRecordEVNT]->size = sizeof(prec->evnt);
216  prt->papFldDes[waveformRecordEVNT]->offset = (unsigned short)((char *)&prec->evnt - (char *)prec);
217  prt->papFldDes[waveformRecordTSE]->size = sizeof(prec->tse);
218  prt->papFldDes[waveformRecordTSE]->offset = (unsigned short)((char *)&prec->tse - (char *)prec);
219  prt->papFldDes[waveformRecordTSEL]->size = sizeof(prec->tsel);
220  prt->papFldDes[waveformRecordTSEL]->offset = (unsigned short)((char *)&prec->tsel - (char *)prec);
221  prt->papFldDes[waveformRecordDTYP]->size = sizeof(prec->dtyp);
222  prt->papFldDes[waveformRecordDTYP]->offset = (unsigned short)((char *)&prec->dtyp - (char *)prec);
223  prt->papFldDes[waveformRecordDISV]->size = sizeof(prec->disv);
224  prt->papFldDes[waveformRecordDISV]->offset = (unsigned short)((char *)&prec->disv - (char *)prec);
225  prt->papFldDes[waveformRecordDISA]->size = sizeof(prec->disa);
226  prt->papFldDes[waveformRecordDISA]->offset = (unsigned short)((char *)&prec->disa - (char *)prec);
227  prt->papFldDes[waveformRecordSDIS]->size = sizeof(prec->sdis);
228  prt->papFldDes[waveformRecordSDIS]->offset = (unsigned short)((char *)&prec->sdis - (char *)prec);
229  prt->papFldDes[waveformRecordMLOK]->size = sizeof(prec->mlok);
230  prt->papFldDes[waveformRecordMLOK]->offset = (unsigned short)((char *)&prec->mlok - (char *)prec);
231  prt->papFldDes[waveformRecordMLIS]->size = sizeof(prec->mlis);
232  prt->papFldDes[waveformRecordMLIS]->offset = (unsigned short)((char *)&prec->mlis - (char *)prec);
233  prt->papFldDes[waveformRecordBKLNK]->size = sizeof(prec->bklnk);
234  prt->papFldDes[waveformRecordBKLNK]->offset = (unsigned short)((char *)&prec->bklnk - (char *)prec);
235  prt->papFldDes[waveformRecordDISP]->size = sizeof(prec->disp);
236  prt->papFldDes[waveformRecordDISP]->offset = (unsigned short)((char *)&prec->disp - (char *)prec);
237  prt->papFldDes[waveformRecordPROC]->size = sizeof(prec->proc);
238  prt->papFldDes[waveformRecordPROC]->offset = (unsigned short)((char *)&prec->proc - (char *)prec);
239  prt->papFldDes[waveformRecordSTAT]->size = sizeof(prec->stat);
240  prt->papFldDes[waveformRecordSTAT]->offset = (unsigned short)((char *)&prec->stat - (char *)prec);
241  prt->papFldDes[waveformRecordSEVR]->size = sizeof(prec->sevr);
242  prt->papFldDes[waveformRecordSEVR]->offset = (unsigned short)((char *)&prec->sevr - (char *)prec);
243  prt->papFldDes[waveformRecordAMSG]->size = sizeof(prec->amsg);
244  prt->papFldDes[waveformRecordAMSG]->offset = (unsigned short)((char *)&prec->amsg - (char *)prec);
245  prt->papFldDes[waveformRecordNSTA]->size = sizeof(prec->nsta);
246  prt->papFldDes[waveformRecordNSTA]->offset = (unsigned short)((char *)&prec->nsta - (char *)prec);
247  prt->papFldDes[waveformRecordNSEV]->size = sizeof(prec->nsev);
248  prt->papFldDes[waveformRecordNSEV]->offset = (unsigned short)((char *)&prec->nsev - (char *)prec);
249  prt->papFldDes[waveformRecordNAMSG]->size = sizeof(prec->namsg);
250  prt->papFldDes[waveformRecordNAMSG]->offset = (unsigned short)((char *)&prec->namsg - (char *)prec);
251  prt->papFldDes[waveformRecordACKS]->size = sizeof(prec->acks);
252  prt->papFldDes[waveformRecordACKS]->offset = (unsigned short)((char *)&prec->acks - (char *)prec);
253  prt->papFldDes[waveformRecordACKT]->size = sizeof(prec->ackt);
254  prt->papFldDes[waveformRecordACKT]->offset = (unsigned short)((char *)&prec->ackt - (char *)prec);
255  prt->papFldDes[waveformRecordDISS]->size = sizeof(prec->diss);
256  prt->papFldDes[waveformRecordDISS]->offset = (unsigned short)((char *)&prec->diss - (char *)prec);
257  prt->papFldDes[waveformRecordLCNT]->size = sizeof(prec->lcnt);
258  prt->papFldDes[waveformRecordLCNT]->offset = (unsigned short)((char *)&prec->lcnt - (char *)prec);
259  prt->papFldDes[waveformRecordPACT]->size = sizeof(prec->pact);
260  prt->papFldDes[waveformRecordPACT]->offset = (unsigned short)((char *)&prec->pact - (char *)prec);
261  prt->papFldDes[waveformRecordPUTF]->size = sizeof(prec->putf);
262  prt->papFldDes[waveformRecordPUTF]->offset = (unsigned short)((char *)&prec->putf - (char *)prec);
263  prt->papFldDes[waveformRecordRPRO]->size = sizeof(prec->rpro);
264  prt->papFldDes[waveformRecordRPRO]->offset = (unsigned short)((char *)&prec->rpro - (char *)prec);
265  prt->papFldDes[waveformRecordASP]->size = sizeof(prec->asp);
266  prt->papFldDes[waveformRecordASP]->offset = (unsigned short)((char *)&prec->asp - (char *)prec);
267  prt->papFldDes[waveformRecordPPN]->size = sizeof(prec->ppn);
268  prt->papFldDes[waveformRecordPPN]->offset = (unsigned short)((char *)&prec->ppn - (char *)prec);
269  prt->papFldDes[waveformRecordPPNR]->size = sizeof(prec->ppnr);
270  prt->papFldDes[waveformRecordPPNR]->offset = (unsigned short)((char *)&prec->ppnr - (char *)prec);
271  prt->papFldDes[waveformRecordSPVT]->size = sizeof(prec->spvt);
272  prt->papFldDes[waveformRecordSPVT]->offset = (unsigned short)((char *)&prec->spvt - (char *)prec);
273  prt->papFldDes[waveformRecordRSET]->size = sizeof(prec->rset);
274  prt->papFldDes[waveformRecordRSET]->offset = (unsigned short)((char *)&prec->rset - (char *)prec);
275  prt->papFldDes[waveformRecordDSET]->size = sizeof(prec->dset);
276  prt->papFldDes[waveformRecordDSET]->offset = (unsigned short)((char *)&prec->dset - (char *)prec);
277  prt->papFldDes[waveformRecordDPVT]->size = sizeof(prec->dpvt);
278  prt->papFldDes[waveformRecordDPVT]->offset = (unsigned short)((char *)&prec->dpvt - (char *)prec);
279  prt->papFldDes[waveformRecordRDES]->size = sizeof(prec->rdes);
280  prt->papFldDes[waveformRecordRDES]->offset = (unsigned short)((char *)&prec->rdes - (char *)prec);
281  prt->papFldDes[waveformRecordLSET]->size = sizeof(prec->lset);
282  prt->papFldDes[waveformRecordLSET]->offset = (unsigned short)((char *)&prec->lset - (char *)prec);
283  prt->papFldDes[waveformRecordPRIO]->size = sizeof(prec->prio);
284  prt->papFldDes[waveformRecordPRIO]->offset = (unsigned short)((char *)&prec->prio - (char *)prec);
285  prt->papFldDes[waveformRecordTPRO]->size = sizeof(prec->tpro);
286  prt->papFldDes[waveformRecordTPRO]->offset = (unsigned short)((char *)&prec->tpro - (char *)prec);
287  prt->papFldDes[waveformRecordBKPT]->size = sizeof(prec->bkpt);
288  prt->papFldDes[waveformRecordBKPT]->offset = (unsigned short)((char *)&prec->bkpt - (char *)prec);
289  prt->papFldDes[waveformRecordUDF]->size = sizeof(prec->udf);
290  prt->papFldDes[waveformRecordUDF]->offset = (unsigned short)((char *)&prec->udf - (char *)prec);
291  prt->papFldDes[waveformRecordUDFS]->size = sizeof(prec->udfs);
292  prt->papFldDes[waveformRecordUDFS]->offset = (unsigned short)((char *)&prec->udfs - (char *)prec);
293  prt->papFldDes[waveformRecordTIME]->size = sizeof(prec->time);
294  prt->papFldDes[waveformRecordTIME]->offset = (unsigned short)((char *)&prec->time - (char *)prec);
295  prt->papFldDes[waveformRecordUTAG]->size = sizeof(prec->utag);
296  prt->papFldDes[waveformRecordUTAG]->offset = (unsigned short)((char *)&prec->utag - (char *)prec);
297  prt->papFldDes[waveformRecordFLNK]->size = sizeof(prec->flnk);
298  prt->papFldDes[waveformRecordFLNK]->offset = (unsigned short)((char *)&prec->flnk - (char *)prec);
299  prt->papFldDes[waveformRecordVAL]->size = sizeof(prec->val);
300  prt->papFldDes[waveformRecordVAL]->offset = (unsigned short)((char *)&prec->val - (char *)prec);
301  prt->papFldDes[waveformRecordRARM]->size = sizeof(prec->rarm);
302  prt->papFldDes[waveformRecordRARM]->offset = (unsigned short)((char *)&prec->rarm - (char *)prec);
303  prt->papFldDes[waveformRecordPREC]->size = sizeof(prec->prec);
304  prt->papFldDes[waveformRecordPREC]->offset = (unsigned short)((char *)&prec->prec - (char *)prec);
305  prt->papFldDes[waveformRecordINP]->size = sizeof(prec->inp);
306  prt->papFldDes[waveformRecordINP]->offset = (unsigned short)((char *)&prec->inp - (char *)prec);
307  prt->papFldDes[waveformRecordEGU]->size = sizeof(prec->egu);
308  prt->papFldDes[waveformRecordEGU]->offset = (unsigned short)((char *)&prec->egu - (char *)prec);
309  prt->papFldDes[waveformRecordHOPR]->size = sizeof(prec->hopr);
310  prt->papFldDes[waveformRecordHOPR]->offset = (unsigned short)((char *)&prec->hopr - (char *)prec);
311  prt->papFldDes[waveformRecordLOPR]->size = sizeof(prec->lopr);
312  prt->papFldDes[waveformRecordLOPR]->offset = (unsigned short)((char *)&prec->lopr - (char *)prec);
313  prt->papFldDes[waveformRecordNELM]->size = sizeof(prec->nelm);
314  prt->papFldDes[waveformRecordNELM]->offset = (unsigned short)((char *)&prec->nelm - (char *)prec);
315  prt->papFldDes[waveformRecordFTVL]->size = sizeof(prec->ftvl);
316  prt->papFldDes[waveformRecordFTVL]->offset = (unsigned short)((char *)&prec->ftvl - (char *)prec);
317  prt->papFldDes[waveformRecordBUSY]->size = sizeof(prec->busy);
318  prt->papFldDes[waveformRecordBUSY]->offset = (unsigned short)((char *)&prec->busy - (char *)prec);
319  prt->papFldDes[waveformRecordNORD]->size = sizeof(prec->nord);
320  prt->papFldDes[waveformRecordNORD]->offset = (unsigned short)((char *)&prec->nord - (char *)prec);
321  prt->papFldDes[waveformRecordBPTR]->size = sizeof(prec->bptr);
322  prt->papFldDes[waveformRecordBPTR]->offset = (unsigned short)((char *)&prec->bptr - (char *)prec);
323  prt->papFldDes[waveformRecordSIOL]->size = sizeof(prec->siol);
324  prt->papFldDes[waveformRecordSIOL]->offset = (unsigned short)((char *)&prec->siol - (char *)prec);
325  prt->papFldDes[waveformRecordSIML]->size = sizeof(prec->siml);
326  prt->papFldDes[waveformRecordSIML]->offset = (unsigned short)((char *)&prec->siml - (char *)prec);
327  prt->papFldDes[waveformRecordSIMM]->size = sizeof(prec->simm);
328  prt->papFldDes[waveformRecordSIMM]->offset = (unsigned short)((char *)&prec->simm - (char *)prec);
329  prt->papFldDes[waveformRecordSIMS]->size = sizeof(prec->sims);
330  prt->papFldDes[waveformRecordSIMS]->offset = (unsigned short)((char *)&prec->sims - (char *)prec);
331  prt->papFldDes[waveformRecordOLDSIMM]->size = sizeof(prec->oldsimm);
332  prt->papFldDes[waveformRecordOLDSIMM]->offset = (unsigned short)((char *)&prec->oldsimm - (char *)prec);
333  prt->papFldDes[waveformRecordSSCN]->size = sizeof(prec->sscn);
334  prt->papFldDes[waveformRecordSSCN]->offset = (unsigned short)((char *)&prec->sscn - (char *)prec);
335  prt->papFldDes[waveformRecordSDLY]->size = sizeof(prec->sdly);
336  prt->papFldDes[waveformRecordSDLY]->offset = (unsigned short)((char *)&prec->sdly - (char *)prec);
337  prt->papFldDes[waveformRecordSIMPVT]->size = sizeof(prec->simpvt);
338  prt->papFldDes[waveformRecordSIMPVT]->offset = (unsigned short)((char *)&prec->simpvt - (char *)prec);
339  prt->papFldDes[waveformRecordMPST]->size = sizeof(prec->mpst);
340  prt->papFldDes[waveformRecordMPST]->offset = (unsigned short)((char *)&prec->mpst - (char *)prec);
341  prt->papFldDes[waveformRecordAPST]->size = sizeof(prec->apst);
342  prt->papFldDes[waveformRecordAPST]->offset = (unsigned short)((char *)&prec->apst - (char *)prec);
343  prt->papFldDes[waveformRecordHASH]->size = sizeof(prec->hash);
344  prt->papFldDes[waveformRecordHASH]->offset = (unsigned short)((char *)&prec->hash - (char *)prec);
345  prt->rec_size = sizeof(*prec);
346  return 0;
347 }
348 epicsExportRegistrar(waveformRecordSizeOffset);
349
350 #ifdef __cplusplus
351 }
352 #endif
353 #endif /* GEN_SIZE_OFFSET */
354
355 #endif /* INC_waveformRecord_H */
epicsUInt32 nelm
Number of Elements.
epicsInt16 phas
Scan Phase.
epicsMutexId mlok
Monitor lock.
State string &quot;Always&quot;.
DBLINK tsel
Time Stamp Link.
epicsEnum16 ftvl
Field Type of Value.
epicsFloat64 hopr
High Operating Range.
epicsEnum16 simm
Simulation Mode.
epicsEnum16 sevr
Alarm Severity.
epicsUInt8 tpro
Trace Processing.
epicsEnum16 ackt
Alarm Ack Transient.
char egu[16]
Engineering Units.
struct asgMember * asp
Access Security Pvt.
epicsUInt32 hash
Hash of OnChange data.
epicsUInt8 lcnt
Lock Count.
LIBCOM_API void cantProceed(const char *errorMessage,...) EPICS_PRINTF_STYLE(1
Suspend this thread, the caller cannot continue or return.
epicsEnum16 scan
Scan Mechanism.
epicsEnum16 prio
Scheduling Priority.
The core data types used by epics.
epicsEnum16 oldsimm
Prev. Simulation Mode.
epicsCallback * simpvt
Sim. Mode Private.
Exporting IOC objects.
epicsUInt64 utag
Time Tag.
epicsInt16 prec
Display Precision.
struct processNotifyRecord * ppnr
pprocessNotifyRecord
epicsInt16 busy
Busy Indicator.
epicsInt16 disa
Disable.
char amsg[40]
Alarm Message.
epicsUInt8 bkpt
Break Point.
epicsEnum16 acks
Alarm Ack Severity.
unambiguous_dset * dset
DSET address.
epicsUInt8 rpro
Reprocess.
Routines for code that can&#39;t continue or return after an error.
char name[61]
Record Name.
char namsg[40]
New Alarm Message.
epicsEnum16 nsta
New Alarm Status.
void * val
Value.
epicsEnum16 sims
Simulation Mode Severity.
epicsEnum16 pini
Process at iocInit.
epicsUInt8 putf
dbPutField process
void * bptr
Buffer Pointer.
char asg[29]
Access Security Group.
Definition: devSup.h:141
struct dbRecordType * rdes
Address of dbRecordType.
epicsUInt8 pact
Record active.
EPICS time stamp, for use from C code.
Definition: epicsTime.h:42
A doubly-linked list library.
ELLLIST mlis
Monitor List.
waveformPOST
Enumerated type from menu waveformPOST.
State string &quot;On Change&quot;.
List header type.
Definition: ellLib.h:57
DBLINK siol
Simulation Input Link.
void * dpvt
Device Private.
epicsEnum16 diss
Disable Alarm Sevrty.
DBLINK siml
Simulation Mode Link.
char evnt[40]
Event Name.
char desc[41]
Descriptor.
epicsUInt8 disp
Disable putField.
struct lockRecord * lset
Lock Set.
APIs for the epicsMutex mutual exclusion semaphore.
struct processNotify * ppn
pprocessNotify
epicsInt16 tse
Time Stamp Event.
Device support routines.
epicsEnum16 udfs
Undefined Alarm Sevrty.
epicsEnum16 dtyp
Device Type.
DBLINK flnk
Forward Process Link.
epicsTimeStamp time
Time.
Declaration of waveform record type.
epicsFloat64 lopr
Low Operating Range.
DBLINK inp
Input Specification.
struct scan_element * spvt
Scan Private.
epicsEnum16 stat
Alarm Status.
#define epicsExportRegistrar(fun)
Declare a registrar function for exporting.
Definition: epicsExport.h:94
DBLINK sdis
Scanning Disable.
epicsUInt8 udf
Undefined.
epicsUInt8 proc
Force Processing.
epicsUInt32 nord
Number elements read.
struct typed_rset * rset
Address of RSET.
EPICS time-stamps (epicsTimeStamp), epicsTime C++ class and C functions for handling wall-clock times...
epicsInt16 disv
Disable Value.
epicsEnum16 apst
Post Archive Monitors.
epicsInt16 rarm
Rearm the waveform.
epicsFloat64 sdly
Sim. Mode Async Delay.
ELLLIST bklnk
Backwards link tracking.
epicsEnum16 nsev
New Alarm Severity.
struct epicsMutexParm * epicsMutexId
An identifier for an epicsMutex for use with the C API.
Definition: epicsMutex.h:49
epicsEnum16 sscn
Sim. Mode Scan.
epicsEnum16 mpst
Post Value Monitors.
