EPICS Base
7.0.6.1
API for accessing hardware devices, mosty over VMEbus. More...
#include "dbDefs.h"#include "osdVME.h"#include "errMdef.h"#include "libComAPI.h"#include "devLib.h"#include "devLibVMEImpl.h"
Enumerations | |
| enum | epicsAddressType { atVMEA16, atVMEA24, atVMEA32, atISA, atVMECSR, atLast } |
| The available bus address types. More... | |
Functions | |
| LIBCOM_API long | devAddressMap (void) |
| Print a map of registered bus addresses. More... | |
| LIBCOM_API long | devBusToLocalAddr (epicsAddressType addrType, size_t busAddr, volatile void **ppLocalAddr) |
| Translate a bus address to a pointer the CPU can use. More... | |
| LIBCOM_API long | devReadProbe (unsigned wordSize, volatile const void *ptr, void *pValueRead) |
| Probe the bus for reading from a specific address. More... | |
| LIBCOM_API long | devNoResponseProbe (epicsAddressType addrType, size_t base, size_t size) |
| Read-probe a range of bus addresses, looking for empty space. More... | |
| LIBCOM_API long | devWriteProbe (unsigned wordSize, volatile void *ptr, const void *pValueWritten) |
| Probe the bus for writing to a specific address. More... | |
| LIBCOM_API long | devRegisterAddress (const char *pOwnerName, epicsAddressType addrType, size_t logicalBaseAddress, size_t size, volatile void **pPhysicalAddress) |
| Register a bus address range with a name. More... | |
| LIBCOM_API long | devUnregisterAddress (epicsAddressType addrType, size_t logicalBaseAddress, const char *pOwnerName) |
| Release a bus address range previously registered. More... | |
| LIBCOM_API long | devAllocAddress (const char *pOwnerName, epicsAddressType addrType, size_t size, unsigned alignment, volatile void **pLocalAddress) |
| Allocate and register an unoccupied address block. More... | |
VME Interrupt Management | |
Routines to manage VME interrupts. | |
| LIBCOM_API long | devConnectInterruptVME (unsigned vectorNumber, void(*pFunction)(void *), void *parameter) |
| Connect an ISR up to a VME interrupt vector. More... | |
| LIBCOM_API long | devDisconnectInterruptVME (unsigned vectorNumber, void(*pFunction)(void *)) |
| Disconnect an ISR from its VME interrupt vector. More... | |
| LIBCOM_API int | devInterruptInUseVME (unsigned vectorNumber) |
| Determine if a VME interrupt vector is in use. More... | |
| LIBCOM_API long | devEnableInterruptLevelVME (unsigned level) |
| Enable a VME interrupt level onto the CPU. More... | |
| LIBCOM_API long | devDisableInterruptLevelVME (unsigned level) |
| Disable a VME interrupt level. More... | |
Memory for VME DMA Operations | |
These routines manage memory that can be directly accessed from the VMEbus in the A24 address space by another bus master such as a DMA controller. | |
| LIBCOM_API void * | devLibA24Malloc (size_t size) |
| malloc() for VME drivers that support DMA. More... | |
| LIBCOM_API void * | devLibA24Calloc (size_t size) |
| calloc() for VME drivers that support DMA. More... | |
| LIBCOM_API void | devLibA24Free (void *pBlock) |
| free() for VME drivers that support DMA. More... | |
ISA Interrupt Management | |
Routines to manage ISAbus interrupts.
| LIBCOM_API long | devConnectInterruptISA (unsigned interruptLevel, void(*pFunction)(void *), void *parameter) |
| LIBCOM_API long | devDisconnectInterruptISA (unsigned interruptLevel, void(*pFunction)(void *)) |
| LIBCOM_API int | devInterruptLevelInUseISA (unsigned interruptLevel) |
| LIBCOM_API long | devEnableInterruptLevelISA (unsigned level) |
| LIBCOM_API long | devDisableInterruptLevelISA (unsigned level) |
Variables | |
| LIBCOM_API const char * | epicsAddressTypeName [] |
| A string representation of each of the bus address types. | |
Deprecated Interfaces | |
| enum | epicsInterruptType { intVME, intVXI, intISA } |
| LIBCOM_API long | devConnectInterrupt (epicsInterruptType intType, unsigned vectorNumber, void(*pFunction)(void *), void *parameter) |
| LIBCOM_API long | devDisconnectInterrupt (epicsInterruptType intType, unsigned vectorNumber, void(*pFunction)(void *)) |
| LIBCOM_API long | devEnableInterruptLevel (epicsInterruptType intType, unsigned level) |
| LIBCOM_API long | devDisableInterruptLevel (epicsInterruptType intType, unsigned level) |
| LIBCOM_API long | locationProbe (epicsAddressType addrType, char *pLocation) |
If all VMEbus drivers register with these routines then addressing conflicts caused by multiple device/drivers trying to use the same VME addresses will be detected. This API also makes it easy for a single driver to be written that works on both VxWorks and RTEMS.
Definition in file devLibVME.h.
| enum epicsAddressType |
| Enumerator | |
| atVMEA16 |
VME short I/O. |
| atVMEA24 |
VME standard I/O. |
| atVMEA32 |
VME extended I/O. |
| atISA |
Memory mapped ISA access. |
| atVMECSR |
VME-64 CR/CSR address space. |
| atLast |
Invalid, must be the last entry. |
Definition at line 41 of file devLibVME.h.
| LIBCOM_API long devAddressMap | ( | void | ) |
Display a table of registered bus address ranges, including the owner of each registered address.
| LIBCOM_API long devBusToLocalAddr | ( | epicsAddressType | addrType, |
| size_t | busAddr, | ||
| volatile void ** | ppLocalAddr | ||
Given a bus address, returns a pointer to that location in the CPU's memory map, or an error if direct access isn't currently possible.
| addrType | The bus address type. |
| busAddr | Bus address to be translated. |
| *ppLocalAddr | Where to put the CPU pointer. |
| LIBCOM_API long devReadProbe | ( | unsigned | wordSize, |
| volatile const void * | ptr, | ||
| void * | pValueRead | ||
Performs a bus-error-safe wordSize atomic read from a specific address and returns an error if this caused a bus error.
| wordSize | The word size to read: 1, 2, 4 or 8 bytes. |
| ptr | Pointer to the location in the CPU's memory map to read. |
| pValueRead | Where to put the value read. |
| LIBCOM_API long devNoResponseProbe | ( | epicsAddressType | addrType, |
| size_t | base, | ||
| size_t | size | ||
Verifies that no device responds at any naturally aligned addresses within the given range. Tries to read every aligned address at every word size between char and long over the entire range, returning success only if none of the reads succeed.
| base | First address base to probe. |
| size | Range of bus addresses to test, in bytes. |
| LIBCOM_API long devWriteProbe | ( | unsigned | wordSize, |
| volatile void * | ptr, | ||
| const void * | pValueWritten | ||
Performs a bus-error-safe wordSize atomic write to a specific address and returns an error if this caused a bus error.
| wordSize | The word size to write: 1, 2, 4 or 8 bytes. |
| ptr | Pointer to the location in the CPU's memory map to write to. |
| pValueWritten | The value to write. |
| LIBCOM_API long devRegisterAddress | ( | const char * | pOwnerName, |
| epicsAddressType | addrType, | ||
| size_t | logicalBaseAddress, | ||
| size_t | size, | ||
| volatile void ** | pPhysicalAddress | ||
The devLib code keeps a list of all bus address ranges registered with this routine and returns an error if a later call attempts to register any addresses that overlap with a range already registered. The call to registering a range also converts the given base address into a pointer in the CPU address space for the driver to use (see devBusToLocalAddr()).
| pOwnerName | Name of a driver that will own this range. |
| logicalBaseAddress | The bus start address. |
| size | Number of bytes to reserve. |
| pPhysicalAddress | Where to put the converted CPU pointer. |
| LIBCOM_API long devUnregisterAddress | ( | epicsAddressType | addrType, |
| const char * | pOwnerName | ||
Release an address range that was previously registered by a call to devRegisterAddress() or devAllocAddress().
| pOwnerName | The name of the driver that owns this range. |
| LIBCOM_API long devAllocAddress | ( | const char * | pOwnerName, |
| size_t | size, | ||
| unsigned | alignment, | ||
| volatile void ** | pLocalAddress | ||
Asks devLib to allocate an address block of a particular address type. This is useful for devices that appear in more than one address space and can program the base address of one window using registers found in another window. As with devRegisterAddress() this call also converts the new base address into a pointer in the CPU address space for the driver to use (see devBusToLocalAddr()).
| size | Number of bytes to be allocated. |
| alignment | How many low bits in the address must all be zero. |
| pLocalAddress | Where to put the CPU pointer. |
| LIBCOM_API long devConnectInterruptVME | ( | unsigned | vectorNumber, |
| void(*)(void *) | pFunction, | ||
| void * | parameter | ||
Interrupt Service Routines (ISRs) are normally written in C, and get passed a context parameter given with them to this connection routine.
There are many restrictions on the routines that an ISR may call; see epicsEvent.h, epicsInterrupt.h, epicsMessageQueue.h, epicsRingBytes.h, epicsRingPointer.h and epicsTime.h for some APIs known to be suitable. It is safest just to trigger a high-priority task to handle any complex work that must happen as a result of the interrupt.
| vectorNumber | VME interrupt vector number. |
| pFunction | The ISR to be called. |
| parameter | Context parameter for the ISR. |
| LIBCOM_API long devDisconnectInterruptVME | ( | unsigned | vectorNumber, |
| void(*)(void *) | pFunction | ||
Device drivers may disconnect an ISR they connected earlier using this routine. In addition to taking the vectorNumber the ISR itself is required and used as a check to prevent a driver from inadvertently removing an interrupt handler that it didn't install.
On a PowerPC target running VxWorks, this routine will always return with an error status.
| pFunction | The ISR to be disconnected. |
| LIBCOM_API int devInterruptInUseVME | ( | unsigned | vectorNumber | ) |
On a PowerPC target running VxWorks this routine will always return false, indicating that a vector is unused.
| vectorNumber | Interrupt vector number. |
| LIBCOM_API long devEnableInterruptLevelVME | ( | unsigned | level | ) |
The VMEbus allows multiple CPU boards to be installed in the same backplane. When this is done, the different VME interrupt levels must be assigned to the CPUs since they cannot be shared. This routine tells the VME interface that it should connect interrupts from the indicated interrupt level to a CPU interrupt line.
| level | VMEbus interrupt level to enable, 1-7. |
| LIBCOM_API long devDisableInterruptLevelVME | ( | unsigned | level | ) |
This routine is the reverse of devEnableInterruptLevelVME().
| level | VMEbus interrupt level to disable, 1-7. |
| LIBCOM_API void* devLibA24Malloc | ( | size_t | size | ) |
Allocate memory of a given size from a region that can be accessed from the VMEbus in the A24 address space.
| size | How many bytes to allocate |
| LIBCOM_API void* devLibA24Calloc | ( | size_t | size | ) |
Allocate and zero-fill a block of memory of a given size from a region that can be accessed from the VMEbus in the A24 address space.
| size | How many bytes to allocate and zero. |
| LIBCOM_API void devLibA24Free | ( | void * | pBlock | ) |
Free a block of memory that was allocated using either devLibA24Malloc() or devLibA24Calloc().
| pBlock | Block to be released. |
| LIBCOM_API long devConnectInterruptISA | ( | unsigned | interruptLevel, |
Connect ISR to a ISA interrupt.
| interruptLevel | Bus interrupt level to connect to. |
| pFunction | C function pointer to connect to. |
| parameter | Parameter to the called function. |
| LIBCOM_API long devDisconnectInterruptISA | ( | unsigned | interruptLevel, |
Disconnect ISR from a ISA interrupt level.
| interruptLevel | Interrupt level. |
| pFunction | C function pointer that was connected. |
| LIBCOM_API int devInterruptLevelInUseISA | ( | unsigned | interruptLevel | ) |
Determine if an ISA interrupt level is in use
| LIBCOM_API long devEnableInterruptLevelISA | ( | unsigned | level | ) |
Enable ISA interrupt level
| level | Interrupt level. |
| LIBCOM_API long devDisableInterruptLevelISA | ( | unsigned | level | ) |
Disable ISA interrupt level
| LIBCOM_API long devConnectInterrupt | ( | epicsInterruptType | intType, |
| unsigned | vectorNumber, | ||
| LIBCOM_API long devDisconnectInterrupt | ( | epicsInterruptType | intType, |
| LIBCOM_API long devEnableInterruptLevel | ( | epicsInterruptType | intType, |
| unsigned | level | ||
| LIBCOM_API long devDisableInterruptLevel | ( | epicsInterruptType | intType, |
| LIBCOM_API long locationProbe | ( | epicsAddressType | addrType, |
| char * | pLocation | ||
1.8.5
