<20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RISC_pad in dbr_time_double
Cc: Jeff Hill - LANL <[email protected]>, Janet Anderson <[email protected]>, [email protected]
Date: Wed, 04 Dec 2002 10:11:31 -0600
I have a feeling that this is only the beginning of problems related to supporting 64 bit architectures.
Isn't there a compiler switch that says to generate 32 bit mode?
Didn't this also arise in 3.13 for the host support for Digital Unix?
Marty
Andrew Johnson wrote:
I received this bug report this morning from a Digital Unix user testing R3.14.0beta2. I've replied to him about the bug tracker stuff, but I'll leave the RISC_pad issue to Jeff and/or Marty to fix. I'm not convinced that we should be using dbr_long_t but it might be right.
RE: RISC_pad in dbr_time_double Jeff Hill
RISC_pad in dbr_time_double Andrew Johnson
Prev: RISC_pad in dbr_time_double Andrew Johnson
Next: RE: RISC_pad in dbr_time_double Jeff Hill
Index: <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
