I'm not quite sure what Jeff's point is, but if you ignore what I wrote
(which was worded before I had completely understood Paul's message) the
important issue here is that in the two definitions of dbr_time_double,
one of them effectively uses int RISC_pad and the other long RISC_pad.
One of them needs changing for CA to work properly on any architecture where
sizeof int != sizeof long
Paul suggests using int, and has confirmed that this works. Does it need
any more discussion? Granted someone should probably check the other dbr_
types too, now we know there is a potential problem. I doubt if there is
anywhere else that is likely to have two definitions of the same structure
as this only comes about because of the dbAccess.h/db_access.h mismatch.
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
- RE: RISC_pad in dbr_time_double Jeff Hill
<2002>
2025
2026
<2002>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
