2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM 3.13 vs. 3.14
To: Jeff Hill <[email protected]>
Cc: "'Marty Kraimer'" <[email protected]>, "'Kenneth Evans, Jr.'" <[email protected]>, [email protected], "'Johnson, Andrew N.'" <[email protected]>, Bob Dalesio <[email protected]>, [email protected]
Date: Tue, 21 Jan 2003 13:15:37 -0600
Jeff Hill wrote:
I can't provide R3.13 test results at the moment because R3.13 patch
release changes to its build system seem to prevent an R3.13 "catime"
from being built as in the past using the makefile in R3.13's
base/src/ca.
The "TESTPROD := catime acctst" line never worked properly for
host builds with any version of R3.13 (I tried R3.13.4 - R3.13.7).
The catime executable will be built if it does not exist, but will
not be rebuilt when catime.c is modified. You need to add the
following 2 lines to the ca Makefile.Host.
catime_SRCS += catime.c
acctst_SRCS += acctst.c
Janet
RE: MEDM 3.13 vs. 3.14 Jeff Hill
Prev: RE: MEDM 3.13 vs. 3.14 Jeff Hill
Next: RE: MEDM 3.13 vs. 3.14 Jeff Hill
Index: 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
