2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel Access PV Gateway Server Problems (more investigation)
To: "Jeff Hill" <[email protected]>, "'Ralph Lange'" <[email protected]>, "'Ernest L. Williams Jr.'" <[email protected]>
Cc: <[email protected]>, "'Carl Lionberger'" <[email protected]>, "'David H. Thompson'" <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, "'Greg Lawson'" <[email protected]>, <[email protected]>, <[email protected]>, "'Core-Talk Archive'" <[email protected]>, "Ken Evans" <[email protected]>
Date: Mon, 3 Feb 2003 09:31:43 -0600
Jeff,
     A while back I looked at the documentation for threads and it said the
process was supposed to get any signals.  In other words, a kill should kill
the process.  This is something that needs to be investigated.  I know from
experience that a KILL either directly or via gateway.killer does not always
work.  It's on my list.
	-Ken
-----Original Message-----
Sent: Monday, January 27, 2003 10:33 AM
To: 'Ralph Lange'; 'Ernest L. Williams Jr.'
Cc: [email protected]; 'Carl Lionberger'; 'David H. Thompson';
[email protected]; [email protected]; [email protected];
[email protected]; 'Greg Lawson'; [email protected]; [email protected];
'Core-Talk Archive'
investigation)
There are known problems with the R3.14 gateway and the "gateway.killer"
script. The problem appears to be with proper delivery and dispatch of
the kill signal in a multi-threaded POSIX process. There will probably
need to be new code that calls ca_task_exit(), but not of course from
within the signal handler.
> If a second Gateway starts and detects the port is taken, it
> prints an error message and exits. There is no code in CA
> that would allow it to take a higher port.
It is possible for two processes to listen to the same UDP port, but
there are serious limitations with unicasts. With most IP kernels only
one of the servers will see unicasts addressed to the shared port.
Broadcasts and multicasts work fine.
Needless to say, it is not possible for two processes to share the same
TCP port.
If there are two CA servers using the same port on the same host, then
the first one to start up gets the specified TCP and UDP ports. The
second CA server listens to the specified UDP port, but it must
compromise with an ephemeral TCP port assignment. If the 2nd server
receives a UDP search message matching one of its PVs then it replies
with its ephemeral TCP port, and the client connects to that port.
There are some notes on this topic in the latest R3.14 CA reference
manual.
Jeff
RE: Channel Access PV Gateway Server Problems (more investigation) Jeff Hill
Prev: RE: Channel Access PV Gateway Server Problems (more investigation) Jeff Hill
Next: RE: R3.14.2 Jeff Hill
Index: 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
