2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in MSI
To: Marty Kraimer <[email protected]>
Cc: Janet Anderson <[email protected]>, Bob Dalesio <[email protected]>, Jeff Hill <[email protected]>, Andrew Johnson <[email protected]>, Eric Norum <[email protected]>, Core-Talk Archive <[email protected]>
Date: Thu, 13 Mar 2003 14:32:45 +0100
Hi.
The EPICS Bug 26 / 28 applies also to MSI.
----- 8< -------------------------------
Summary
   dbExpand behaves inappropriately on error
Description
   When dbExpand encounters an error while executing, it neither deletes
   the (empty) target file nor returns an error value <> 0 to the shell.
   Thus make does not detect the error, does not stop and leaves behind
   a zero-size dbd file that gets installed as if correct. Even
   additional make commands in that directory will not regenerate the invalid file.
   As further consequence invalid database definition files get
   installed to the production system.
There the consequences are even worse as the zero-length databases do
not generate errors or warnings when the IOC boots. Really hard to track
down.
Should there be a warning when a database file exists and gets loaded,
but does not contain a single record?
Cheers,
Ralph
....just trying to get the control system running after a 3 week shutdown...
Prev: RE: EPICS Timer Roundoff Jeff Hill
Next: Re: -mlongcall test Andrew Johnson
Index: 2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
