2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bug in MVME167 BSP?
To: "Andrew Johnson" <[email protected]>
Cc: "Core-Talk" <[email protected]>
Date: Tue, 9 Mar 2004 14:58:41 -0600
Hi Andrew,
Wow, I'm impressed!  Thanks for tracking it down.
> Of course the IOC's idea of the boot host name
> doesn't have to be the same as the rest of the world's either - you
could
> tell the IOC that it's booting from HOSTx17b3 and it'll be perfectly
happy and
> everything will work correctly.
Right.  Does the bug affect only fetching the startup script with FTP,
or is it more general host name lookup problem?  If I boot with a "fake"
hostname and then use hostAdd to add a real IP name will nfsMount work
with the real host name?The only reason I might want to use the "real"
host name is to avoid confusion when people look at the nfsMount
commands.
Prev: Re: Bug in MVME167 BSP? Andrew Johnson
Next: Re: Timestamp (drvTS) progress Korhonen Timo
Index: 2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
