2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: memory management
To: 'Benjamin Franksen' <[email protected]>
Cc: 'Eric Norum' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Matej Sekoranja' <[email protected]>, 'Marty Kraimer' <[email protected]>, 'Andrew Johnson' <[email protected]>, 'Ken Evans' <[email protected]>, 'Bob Dalesio' <[email protected]>, "'Kasemir, Kay'" <[email protected]>
Date: Wed, 02 Mar 2005 16:35:32 -0700
> -----Original Message-----
> From: Benjamin Franksen [mailto:[email protected]] >
> On Wednesday 02 March 2005 22:02, Jeff Hill wrote:
> > My solution to the wide character issue was to have the
putChar
> > and getChar interfaces pass type int. UTF-8 then becomes an
> > implementation (an internal storage compression) issue.
> Ok, this is a possibility. But it means that, for instance,
> an IOC will use wide characters throughout its code. Just
> caring about our precious memory, you know... ;) That is,
> provided it doesn't want to re-encode everything
> again, of course...
The stringSegment interface requires only that internal string
tokens
can be converted to a int sized universal code only when getChar
and putChar are called, but there is no requirement that the
implemenation use an internal storage of size int.
The getChar interface will be used in one character at
a time situations where the storage overhead of an int can be
safely
neglected. Otherwise if there are any multi-token segments being
stored
they would only be stored in an implementation defined format
accessed
through the stringSegment interface. Anyways, that is the
standard
dataAccess approach: interface to data, but do not specify a
storage
format.
Jeff
Re: memory management Benjamin Franksen
Prev: Re: memory management Benjamin Franksen
Next: Re: memory management Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
