Hi all,
I find that for all analog type records, the fixed number of alarm
limits and severities is a constraint that should be removed.
I would rather have the analog alarms organized like a breakpoint table,
consisting of a series of ranges with a severity (and a status?) for
each. The default would be no table, which is the complete range being
"NO_ALARM".
Maybe some breakpoint table code and parsing can be re-used.
The hard part is probably that CA and the clients on the other end would
have to reflect this structure, which is not a fixed-number set of
attributes anymore. Rather an array of (value, value, (status?),
severity) structures.
The other open question is: Changing alarm limits is not just setting a
field anymore, it means reloading a breakpoint table. Is that
acceptable? Must the alarm limits be writable through CA?
What do you think?
Ralph
Ralph Lange [email protected] Tel: +49 30 6392-2117
BESSY Controls Group www.bessy.de Fax: ... -4859
Re: EPICS base V4: iocCore database Benjamin Franksen
Announcing the core-talk mailing list Andrew Johnson
<2005>
2025
2026
Re: memory management Benjamin Franksen
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
