> > In any case, it seems
> > that we should have the goal of using the same interfaces for each of
> > the fundamental data types?
> Agreed about the goal, but your interfaces don't necessarily take into
> account all of our requirements, and we think some of your interfaces
> are stricter than they need to be, which harms performance. I suspect
> we would have few problems implementing most of your interfaces on top
> of ours, but adopting ours should be more efficient since you don't have
> to do everything one character or element at a time - we expose a whole
> segment at once.
1) I think that the above comment applies only to strings as all other types
in data access are accessed in chunks - allowing the highest level of
performance.
2) The data access string interface StringSegment certainly does force all
string access through a stream interface indexed int wide getChar/putChar. I
wanted to support all character widths through one interface. I was inclined
to conclude that if they are communicating in strings they can't be too
concerned about performance. I was also, I admit, not thinking about UTF-8.
3) Since your interface allows writing multiple characters to the string at
a time doesn't this force a UTF-8 implementation of complex characters
(contrary to what I seem to recall reading in your doc)?
4) Forcing UTF-8 probably isn't a bad idea. I would be amenable to just
saying that if we will have wide characters they will be UTF-8. This would
be a real nice simplification of course when compressing the data for the CA
protocol. The StringSegment interface in data access certainly could be
revised to allow blocks of characters to be read/written in UTF-8 format
(assuming that all strings are streams of octets).
5) We should carefully consider implementations and interfaces, and how they
may become dependent on each other. Of course, for review, interfaces are
pure virtual and implementations have data in them. For fundamental types we
should be careful about making implementation dependent on implementations
because we can end up with code maintenance issues (been there, done that).
I notice that EpicsEnum is an implementation and it is based on EpicsString
- another implementation. In contrast, the data access StringSegment
interface is just an interface. Another example is EpicsArray which is
admitted to not be type safe. That might be fine as an internal scaffolding
for an array, but when crossing boundaries between components the interface
presented by data access might be more appropriate because it *is* type
safe.
6) I used a stream type of interface as a foundation for the StringSegment
interface. This appears to be a nice approach in my IMHO. By the way, I did
look at basing strings on stream strings in the C++ standard library but
gave up on that when I realized that most implementations were calling
malloc in the stream objects constructor - too much overhead for temporary
object mapping protocol streams so that they can cross interfaces. The
fundamental problem here by the way is that the standard library made the
core stream an implementation, and not an interface.
7) Dejavu. I am always defining interfaces without epics in their name which
are subsequently superseded by revised interfaces that do. Who owns this
EPICS name anyways? This is vaguely reminiscent of IBM calling there
computer the "personal computer" and Microsoft calling there window system
"windows" - whoever owns the most generic name wins :-). Is it somewhat
redundant to have to type epics every time that I type an interface name?
Should there be a C++ namespace called "epics"? Is that too course of a
granularity for a name space, and possibly also too limiting for generic
things like fundamental types (is this buffer only useable with EPICS)?
8) I notice that some of these classes hand off pointers to internal
storage. EpicsBuffer does this of course when we are granted access to a
buffer segment, and some of the other do it also when they return a pointer
to the buffer creator (it should probably be a reference that is returned).
The problem is that users may continue to use handles to internal objects
after the object that owns them (and manages there existence) don't exist.
Admittedly, a buffer is a very low level object and you might make
exceptions for performance reasons. However, when these C++ systems become
large and complex object lifespan mistakes seem to be one of the primary
failure modes. In any case I tried to avoid this in data access by making
all buffer internal access occur only during the duration of the callback.
It's clear in the callback that we can only access the incoming arguments
for the duration of the callback. The performance is the same because we
still have direct access to large chunks.
9) I really do feel that using unsigned types for integers that should never
be negative is best. Oh well, perhaps I am the only one yelling this out
from the bottom of a well, and no one is listening anyways.
> Go back and read the section on the EpicsBuffer interface again;
> none of our classes require contiguous buffer storage.
Sorry, after reflecting more carefully on the code snippets (yes, I do that
too) I now understand what is being done. This buffer thingy is an
implementation, and not an interface, and yes it does allow segmented
storage.
> Since we never really write down and agree what all the detailed
> requirements are, but just present each other with code snippets that
> implement our view of them, I think we're going to continue to have
> disagreements like these. It would speed things up immensely if we
> could first agree in writing on what we are going to accomplish *before*
> we actually start implementing it (and I plead as guilty as everyone
> else on that charge).
I think that this is another way of expressing a desire for better
coordination of the overall design process. Coordination is good and more of
it can't be worse than the current situation (almost none). However, dialog
like this shouldn't be seen as a problem either. Coordination without dialog
(multiple voices) would probably be worse.
Jeff
- Re: Fundamental Types document Benjamin Franksen
- Re: Fundamental Types document Andrew Johnson
Re: V4 Data Types: Request for tagged unions Andrew Johnson
RE: V4 Data Types: Request for tagged unions Jeff Hill
<2005>
2025
2026
<2005>
2025
2026
