2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: More flexible record scanning
To: [email protected]
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 27 Jun 2005 09:33:22 -0500
Benjamin Franksen wrote:
Only for record (sic!), because I just had a problem where this would have been quite useful: In R4, each record (i.e. dbCommon) should have an input link targeting the PROC field.
Standard application: a potentially large number of records needs to be scanned according to what happens at some central place.
Can that requirement not be implemented already in V3 using this?
    SCAN=Event
    EVNT=<some number>
    Use an Event record to generate that numbered soft event.
If the records to be processed are spread across multiple IOCs, you need to have one Event record in each IOC.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: More flexible record scanning Benjamin Franksen
Prev: Interesting reading material Benjamin Franksen
Next: Re: V4 design issue: Should primitive data types have well defined precisions? Ralph Lange
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: More flexible record scanning Benjamin Franksen
Next: Re: More flexible record scanning Benjamin Franksen
