2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: name resolution performance
To: EPICS Core Talk <[email protected]>
Date: Thu, 07 Jul 2005 11:10:29 -0400
Hi:
Thanks to Jeff for adding the number.
~60000 lookups (or is it connections?) per second for CA
sure beats the OpenLDAP number of only 1500 lookups/sec
to pulp.
What's harder to measure/test/compare:
When I start a new EDM screen, it connects quickly,
which I guess is because of the 60000/sec.
But when I reboot all ~40 SCL LLRF IOCs,
the screen will often not reconnect for a minute.
Is that because of SNS network misconfiguration?
Is the concept of detecting changes in beacon timing
too tricky, and a straight directory lookup
of where a PV is supposed to be would be quicker?
-Kay
On Jul 6, 2005, at 17:39, Jeff Hill wrote:
All,
I added the attached text to Kay's name resolution discussion (on the wiki).
Jeff
JOH: For comparison purposes, here is the performance of CA's built-in name
resolution.
Testing with 100000 channels named joh:bill
channel connect test
Elapsed Per Item = 0.00001683 sec, 59427.3 Items per sec, 31.4 Mbps
Search tries per chan - mean=1.000930 std dev=0.030482 min=1.000000
max=2.000000
RE: name resolution performance Jeff Hill
Prev: Re: Agenda for next week Benjamin Franksen
Next: Re: Record support and user-defined fields Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: name resolution performance Jeff Hill
Next: RE: name resolution performance Jeff Hill
