Benjamin Franksen wrote:
On Tuesday 12 July 2005 17:52, Tim Mooney wrote:
I liked most of the original proposal, and I'm not sure what the Wiki
page that replaced it is trying to say. I don't understand how the
PROC field, a blanket command to process the record, is replaceable
by a 'processState' field, which seems not to be a command but merely
a state indicator. If it is a command, I don't think it helps very
much, because it would require an outside agent to know too much
about how the target record operates. I don't think we can guess in
advance all the states a record might actually be in anyway.
I think the 'processState' is not to replace PROC (a command field) but
rather to replace PACT (a status field). That is, the record's process
routine decides what to do depending on the current processState. Thus,
whenever record processing would want to suspend operation in order to
wait for an event, it would set processState and return to the caller.
It's a generalization of the way the PACT field is handled in V3.
Marty, please correct me if this is wrong.
You are correct.
Benjamin,
During the developer's meeting yesterday we had a discussion of V4
record processing.
I am attaching the presentation I prepared. Not the 2nd slide which
states that this is not even close to final design.
The V4_Design:_Record_Processing wiki needs major major changes based on
the presentation and especially on yesterday's discussion.
Marty
process.ppt
Description: MS-Powerpoint presentation
- V4 Design: Record Processing Marty Kraimer
- Re: V4 Design: Record Processing Tim Mooney
- Re: V4 Design: Record Processing Benjamin Franksen
Re: Record support and user-defined fields Benjamin Franksen
Re: Record support and user-defined fields Marty Kraimer
<2005>
2025
2026
RE: V4 Design: Record Processing Liyu, Andrei
<2005>
2025
2026
