2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Type descriptor vs. enum
To: Kay-Uwe Kasemir <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 20 Jul 2005 06:56:47 -0700
I've been thinking about this issue, and I still believe the client needs to be able to understand any data type that a server can make available.
Kay-Uwe Kasemir wrote:
Hi:
Where are we with the type enum?
Before the APS meeting,
Ben & Ralph had suggested a type descriptor
similar to what John Sinclair and I
implemented for EDM:
    typedef struct
        // Character of this PV
        enum { real, integer, enumerated, text, special } type;
        // real ... enumerated: bit size
        // text               : max length, 0 for variable length
        // special            : no clue
        size_t size;
        // Human-readable description. Currently supported:
        // "integer:32"
        // "real:64"  for double
        // "enumerated:16"
        // "text:0"
        const char *description;
    } Type;
... with added info for structs and arrays.
At the APS meeting, Marty presented a simple enum:
   int16
   int32
   uint16
   uint32
   array
   struct
... which would require additional calls in case you find
an array or struct.
He recently tried to nail the contents down,
when Ben raised concerns which I didn't fully understand.
Now what?
Kay
I also think clients will be written in Java going forward, but nonetheless here's some C++ and general OO ideas.
First, apart from the enum, I think we need a class to describe a data type and another to describe an instance. How about the following:
enum EpicsDataType
       EDT_UNKNOWN = 0,
       EDT_BOOL    = 1,
       EDT_OCTET   = 2,
       EDT_INT16   = 3,
       EDT_INT32   = 4,
       EDT_INT64   = 5,
       EDT_FLOAT32 = 6,
       EDT_FLOAT64 = 7,
       EDT_STRING  = 8,
       EDT_TIME    = 9,
       EDT_USERDEF = 10,
In particular, arrays are not included. The class to describe types could look like this (those who believe the STL is unusable can substitute their own container class for vector). The second class describes an instance of a specific type, but not the space associated with it:
    * Defines the type, size and contents of
    * an EPICS data element.  It describes a
    * type, not an instance.
   class EpicsSymbolDef
       public:
           bool isArray();            // for convenience
           bool isVector();        // for convenience
           bool isScalar();        // for convenience
           int getNumDims();
string getDataTypeName(); // not always required; a type name.
           EpicsDataType getDataType();
           unsigned int getArraySize( unsigned int dimension);
                           // get array size of given array dimension
       protected:
           void setDataType( EpicsDataType thisType);
void setArrayDimSize( unsigned int dimension, unsigned int size);
       private:
           EpicsDataType _type;        /* type of this element */
string _dataTypeName; /* optional name of this data type */ vector<unsigned int> _dims; /* a size for each array dimension */
    * Describes an instance of an EPICS data
    * element.  It is an EpicsSymbolDef with
    * a specific instance name.  It does not
    * have storage associated with it.
    * Derived classes allocate space and have
    * storage accessor methods to manage the
    * actual data.
   class EpicsSymbol : public EpicsSymbolDef
       public:
           string getName();
       protected:
            * can only be created by a derived class instance.
           EpicsSymbol( const char *name, const EpicsDataType type);
           ~EpicsSymbol();
       private:
            * each instance has a name
           string _name;                    /* name of this element */
and finally, each instance would be described in a generic way to include actual data. Here's a minimal example, and one could imagine a lot of accessor methods here, including a constructor to fully describe the type to the inherited constructor (I'm not sure I've got the syntax right here, but a typedef for each of the enums at the top of this message would be used to get a specific instance, like 'class EpicsData<Int16> x;' or similar):
   template<class T>
   class EpicsData : public EpicsSymbol
public: // missing a copy constructor, and most other useful methods!
           T& operator[]( int src);
           T& operator=( const T& src);
       protected:
       private:
           <T> *_data;
Also, the user defined (struct) kind of record would need a container of Symbols, so this isn't really complete in that respect.
I would assume an Epics record definition would then be a container for the types of these epics values and their properties and sub-properties... (pardon the scarcity of usable methods here!), as would the representation of a View. Only the data types are described here, although an instance of such an object could also be used to contain actual data, since EpicsSymbol is a base class for EpicsData<Int16> for example, which can contain actual data.
   class EpicsRecordDef
       public:
       protected:
       private:
           string _recordName;
           vector<EpicsSymbol> _fields;
This would allow a client to understand the data definitions, as well as give it a scheme to store actual data in a type safe way.
I just realized there's a bit much here for an e-mail message, perhaps I could post this to the wiki.
-doug
Re: Type descriptor vs. enum Marty Kraimer
Type descriptor vs. enum Kay-Uwe Kasemir
Prev: Type descriptor vs. enum Kay-Uwe Kasemir
Next: RE: Type descriptor vs. enum Dalesio, Leo `Bob`
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Type descriptor vs. enum Marty Kraimer
