2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Network Accessable Types
To: EPICS Core Talk <[email protected]>
Date: Tue, 26 Jul 2005 16:51:11 +0200
Well, yes. Sure. But: wasn't that the point?!
Maybe I'm misunderstanding the discussion, but for me the line of argumentation is as follows:
- There will be buffer boundary issues when transferring strings (or structs or arrays). If one of these things is larger than a buffer - for sure. Else - only now and then when filling these things into a network buffer hits the buffer end.
- The user interfaces (APIs) to those things should completely hide these issues.
- Therefore the implementations of these APIs must be able to cope with buffer boundary issues, i.e. they must be able to handle storage in non-contiguous blocks. The interface must allow for such implementations.
If we're trying to agree on one interface, that interface must allow non-contig.-storage implementations, else CA won't be able to use it.
If we're trying to agree on one implementation that is reusable all over the place, that implementation must be able to handle non-contiguous storage, else CA won't be able to use it.
It is desireable to separate the interface from the implementation, as this would allow other implementations (that might be smaller/simpler/faster by not supporting non-contig.-storage) to be used in adequate places while still keeping the same interface.
If we allow something in the interface that requires contiguous storage (such as c_str), we either restrict the implementation to contiguous storage (which won't work for network buffers) or force the implementation to double-buffer everything to have it in a contiguous place (which is bad in performance and memory fragmentation issues).
Or do I miss something important here?!
Ralph
Kay-Uwe Kasemir wrote:
On Jul 26, 2005, at 05:49, Ralph Lange wrote:
1. Learning the native type of data is part of the DA interface. The DA interface is purely about data and does not have any notion of network transport. An application may access things within a library or through shared memory using DA without any network involved.
I agree, and if you do,
doesn't it follows that the application
shouldn't have to deal with
possible network buffer boundaries?
The application should see a data interface
that allows random access:
List the properties,
learn that the 5th property is the "value",
typed as some sort of number, then fetch it as a double.
Ask for the "units" property as a string, ...
The V3 channel access library does hide the network
delays and buffer boundaries from me,
I eventually get the full DBR_CTRL_XXX
and can access any piece in there in random order.
(Yes, it requires pre-configuration of the max. array size)
Why should the new data access interface
involve the application in the handling of the
incoming network stream byte-by-byte,
maybe first receiving the time stamp,
then a few initial characters of a string value,
then the next 2 chars, ...?
-Kay
Ralph Lange               [email protected]     Tel: +49 30 6392-2117
BESSY Controls Group      www.bessy.de             Fax:      ...   -4859
Re: Network Accessable Types Kay-Uwe Kasemir
RE: Network Accessable Types Jeff Hill
Re: Network Accessable Types Marty Kraimer
Re: Network Accessable Types Andrew Johnson
Re: Network Accessable Types Ralph Lange
Prev: Re: Network Accessable Types Kay-Uwe Kasemir
Next: Re: Network Accessable Types Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Network Accessable Types Kay-Uwe Kasemir
