2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ICE and TIPC
To: Kay-Uwe Kasemir <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 27 Jul 2005 11:15:38 -0500
Kay-Uwe Kasemir wrote:
I suggest _not_ to allow con-contiguous storage.
I cannot imagine a server that keeps his
strings in segments.
I can; I am considering an implementation of variable length strings that does not require the reallocation and copying of data as the string is extended. This would use a fixed allocation size block, and chain these blocks together as needed to make up the complete storage for the string.
I understand why a network layer will _receive_
the data in pieces, but that's a problem of the
network layer.
All communications layers that I have seen so
far hide that detail from me.
With the proper environment variable configuration,
even CA V3 hands me the complete dbr_ctrl_double
for huge arrays,
so why obfuscate the V4 data access in order to
support non-contiguous data?
Any API that is designed to support segmented data can also support contiguous data with no changes. An API that requires contiguous data cannot be used with segmented data without copying all the data segments into a contiguous buffer first, thus requiring extra memory and reducing performance.
Eric Norum has an R3.14 IOC with very limited RAM that uses a waveform record to allow its flash eprom to be reprogrammed, but his memory requirements are such that he can only fit one waveform buffer in memory. If we require another copy of the data this IOC would probably not be able to fit in memory.
Since we're designing the APIs and they will hide all of the details from user code, why would we make them less flexible?
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: ICE and TIPC Kay-Uwe Kasemir
ICE and TIPC Marty Kraimer
Re: ICE and TIPC Ralph Lange
Prev: Re: ICE and TIPC Kay-Uwe Kasemir
Next: Re: ICE and TIPC Kay-Uwe Kasemir
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
