All,
Here are DA's requirements for a string interface
O Interface must be compatible with almost any string
storage implementation that the user prefers
O Allow the string implementation to be either contiguous
or non-contiguous
O Allow simpler and faster implementation should the string be
a C string constant
O Compare two strings for equivalence
O Copy one string replacing the contents of another string
O Convert a string to all of the primitive numeric types
(the string implementation knows best how to implement this and I don't
want to reinvent the wheel if the string is non-contiguous)
(subordinate properties need to modify this conversion)
O Convert all of the primitive numeric types to a string
Here is DA's string interface wish list
O String positioning interface (StreamPosition interface) so that useful
editing, conversion, manipulation libraries might be implemented above the
string interface
For what its worth, attached is the interface DA currently uses for
accessing strings.
As mentioned before, if we agree that we will use only UTF-8 for wide
characters then I am very willing to change getChar and putChar in
StringSegment to transfer blocks of characters in order to improve
efficiency.
Furthermore, I completely agree with Andrew's comment that every string
storage implementation should not need to be an iterator. The problem for DA
is that the string must be an atomic type for proper use in templates.
Therefore DA can't have two interfaces for a string. Perhaps the proper
compromise will be of the following.
Option 1
O change StringSegment to not derive from
StreamPosition/StreamWrite/StreamRead
O change StringSegment to include factory method for instance of
StreamPosition/StreamWrite/StreamRead?
Option 2
Alternatively, Andrew's concern might be addressed w/o adding a factory
method (I am concerned about memory management overhead). The alternative
would be to *not* include an iterator in the string storage implementation,
but instead the user might create a temporary stack object satisfying the
StringSegment/StreamPosition/StreamWrite/StreamRead interface for the
duration of the call to DA. This temporary object would not contain the
database's string object, but would instead contain a reference to the DB's
string object, and of course an iterator for the DB's string object.
struct StreamPosition {
public:
// returns the number of elements in the stream
virtual size_t length () const = 0;
// get current position
virtual size_t position () const = 0;
// set the current stream position
virtual void movePosition ( size_t newPosition ) = 0;
// returns the number of immediately viewable
// elements after the current position.
virtual size_t viewable () = 0;
// remove all elements from current position to the
// end of the stream
virtual void prune () = 0;
// flush cached output entries
virtual void flush () = 0;
struct StreamWrite {
public:
typedef PropertyCatalog < PropertyViewer > catalog_t;
virtual void write (
const double &, const catalog_t & = catalog_t::voidCatalog ) = 0;
const int &, const catalog_t & = catalog_t::voidCatalog ) = 0;
const long &, const catalog_t & = catalog_t::voidCatalog ) = 0;
const unsigned &, const catalog_t & = catalog_t::voidCatalog ) = 0;
const unsigned long &, const catalog_t & = catalog_t::voidCatalog )
= 0;
const epicsTime &, const catalog_t & = catalog_t::voidCatalog ) = 0;
const struct StringSegment &, const catalog_t & =
struct StreamRead {
public:
virtual void read (
double &, const catalog_t & = catalog_t::voidCatalog ) const = 0;
virtual void read (
int &, const catalog_t & = catalog_t::voidCatalog ) const = 0;
virtual void read (
long &, const catalog_t & = catalog_t::voidCatalog ) const = 0;
virtual void read (
unsigned &, const catalog_t & = catalog_t::voidCatalog ) const = 0;
virtual void read (
unsigned long &, const catalog_t & = catalog_t::voidCatalog ) const
= 0;
virtual void read (
epicsTime &, const catalog_t & = catalog_t::voidCatalog ) const = 0;
virtual void read (
struct StringSegment &, const catalog_t & = catalog_t::voidCatalog )
const = 0;
struct StringSegment :
public StreamPosition,
public StreamRead,
public StreamWrite
virtual int getChar () const = 0; // returns 0 when end of string is
reached
virtual void putChar ( int ) = 0;
virtual StringDiff compare ( const StringSegment & ) const = 0;
Jeff
__________________________________________________________
Jeffrey O. Hill Mail [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA Fax 505 665 5107
RE: ICE and TIPC Jeff Hill
Re: String Interfaces Andrew Johnson
<2005>
2025
2026
Re: V4 CA example timeStamp, sevr, status, data Marty Kraimer
core meeting / presentation during EPICS meeting Matthias Clausen
<2005>
2025
2026
