2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Client Interface
To: EPICS Core Talk <[email protected]>
Date: Fri, 02 Sep 2005 17:18:47 -0400
Hi:
On Aug 11, 2005, at 15:08, Jeff Hill wrote:
I had a look at your proposal....
I've been busy but finally got around to try data access,
based on the Aug. 23 snapshot. The result is on
http://www.aps.anl.gov/epics/wiki/index.php/V4_Data_Interface
I think that we can succinctly boil this down to two options. Should this be
iterator based (..) or callback based (the DA approach).
YES! I'm convinced that many find
    EpicsProperty *p = pc->findProperty("value");
    double d;
    p->getDouble(d);
easier to understand than handing control over
to a 'viewer' class
    Viewer v;
    pc->find(pi_value, v);
OK, data access visited the viewer's
reveal(pi_value, <native type>),
but now I have to hack around to get
the data deposited in a place that's accessible
from the line after 'find' where I want to
use the data.
Maybe dataAccess needs to include a set of these:
doubleViewer : public propertyViewer
public:
   double d;
void reveal ( const propertyId &id, const double &v, const propertyCatalog &x)
   { d = v; }
void reveal ( const propertyId &, const int &i, const propertyCatalog &x)
   { d = v; }
Now I could write
    doubleViewer dv;
    pc->find(pi_value, dv);
    cout "Value is " << dv.d
2) ....Let's look at storing the data in an application specific proprietary
structure.
    viewer.reveal ( propValue, ar_mutable, & MyContainer::value );
    viewer.reveal ( propUnits, ar_mutable, & MyContainer::units );
    viewer.reveal ( propPoint, ar_immutable, & MyContainer::point );
Consider what the user has to do with Kay's revised approach:
    properties[0] = new EpicsDoubleProperty("value", &value);
    properties[1] = new EpicsStringProperty("units", &units);
properties[2] = new EpicsStructureProperty("point", 2, point_properties);
They look very similar in terms of ease of use to me.
Yes, very similar. Except when I actually try it with data access,
I run into 3 issues:
- the published version doesn't understand ar_mutable/ar_immutable,
  so I have twice the code for now
- don't know how to interface with stringSegment,
  so I had to skip the units.
- in order to reveal my struct point, it needs to be rewritten
  to derive from propertyCatalog.
Does DataAccess interface structured user data 'as is'?
I only get that to work for scalars.
Sub-structures need to re-packaged as propertyCatalog-derived
classes.
O My perception is that callback is more efficient. With the iterator and abstract data descriptor approach I have to play the animal, vegetable, or mineral game with the data. I have to ask the property what is your type,..
Almost. As the end user of the API, I _may_ ask, if I care,
for example if I'm a generic dumper that wants to dump any data type.
More often I simply say: getDouble().
If my property happens to be an
EpicsDoubleProperty, I get the double.
The other EpicsXXProperty classes have this default conversion:
    bool getDouble(double &d)
        int i;
        if (!getInt(i))  return false;
        d = i;
        return true;
There is no 'switch(type)'.
Furthermore, the authors of MEDM, probe, or the gateway will probably use a common library (I think that Ralph is already in the preliminary design phase) for inflating storage for a set of properties that are unknown at
compile time.
Yes, I think such a library is needed to make dataAccess usable.
-Kay
RE: Channel Access Client Interface Jeff Hill
Prev: RE: Current copy of data access? Jeff Hill
Next: R3.14.8 Release timetable Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Access Client Interface Benjamin Franksen
Next: RE: Channel Access Client Interface Jeff Hill
