2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: data access structures, strings
To: [email protected]
Date: Wed, 28 Sep 2005 08:06:48 -0500
Jeff Hill wrote:
Please pardon an internal debate converted to a mail message :-)
Use 'assign' instead of 'operator =',
'isEqual' instead of 'operator ==',
Shouldn't this also apply to dataAccess? {Or should I say :-) }
PropertyCatalog currently has "operator =" and "operator ==".
O Do they meet the conventional wisdom test? That is, is their purpose
roughly equivalent to the purpose of these operators with primitive types? I
Originally I thought yes, but I have thought about this further and its
probably more accurate to call 'operator =' "extract what's in the LHS from
the RHS", and what 'operator ==' does "return true if everything in the LHS
is equivalent in the RHS".
Should  == (or equals) always guarantee that it is an equivalence relation?
That is
1) reflexive =>  x==x is always true
2) symetric  => if x==y then y==x
3) transitive => if x==y and y==z then x==z
Java states that if a class overrides equals it should gurantee that its implementation is an equivalence relation.
I suspect similar advice appears somewhere for C++.
dataAccess == does not appear to be  symetric
If containers are implemented for
struct A { int x; int y} and struct B {int x; int y; int z}
Then won't the following happen if A.x=B.x and A.y=B.y?
A==B is true but B==A is false
Marty
RE: data access structures, strings Jeff Hill
Re: data access structures, strings Benjamin Franksen
Prev: Re: data access structures, strings Kay-Uwe Kasemir
Next: Re: ICALEPCS 2005: EPICS workshop: EPICS V4 Runtime Database Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: data access structures, strings Jeff Hill
Next: RE: data access structures, strings Jeff Hill
