Subject: |
[Fwd: Re: ICALEPCS 2005: EPICS workshop: EPICS V4 Runtime Database] |
Marty Kraimer <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 29 Sep 2005 10:34:47 -0500 |
--- Begin Message ---
Wow. That was fast.
Let's see....
Here's some things that I found on a first sweep - mostly minor
misspellings and other small formal suggestions:
- Title:
- While OpenOffice looks good, my PowerPoint screws up font
sizes. Could be my installation.
- Slide 2:
- incoherent capitalization of heading and major points
- line 6: Arrays - plural?
- Slide 3:
- line 4: "8 bit byte" -> redundant (a byte is defined to
contain 8 bit)
- line 4: spelling (converrsion -> conversion)
- line 6: remove trailing dot
- line 9: better: Multidimensional arrays may be restricted
- line 11: remove trailing colon
- Slide 4:
- Left column: spacing (before "link" keyword)
- Right column: PowerPoint screws up fonts
- Slide 5:
- Left column: spacing (line 5, after "field" keyword)
- line 17: spelling (an -> a)
- Slide 6:
- Left column: spacing (line 7, after comma)
- Right column: spacing (line 4, after first comma)
- Slide 7:
- Major points: first uses plural, the others singular
- Major points: spacing (first two link types have a space within
their name, the other two don't)
- Left column: spacing (line 5, missing space after dash)
both major points use the wrong dash (too short, compare with slide 8)
- Slide 9:
- line 4: spelling (positionL -> position:)
- line 10: verb form (singular) does not match subject (plural)
- Slide 10:
- Heading: capitalization
- line 3: capitalization (the field in V3 is called FLNK)
- line 7: spacing (before "link" keyword)
- Slide 11
- line 1: better: "incA, incB and getSample"
- lines 5-7: spacing around equal signs
- line 6/12: Logical: line 12 says incB processed in parallel
with incA, while parallel has been set to "false" in line 6.
- Slide 12:
- line 7: spacing (too much space before "so")
- line 13: Logical: one of the record processing states is
mentioned without that whole new feature (the record processing state
machine) being mentioned or shown before
- Slide 14:
- Slide 16:
- Line 4: "DatabaseCommon"? That term has not been explained. Do
you eventually mean "RecordCommon"?
- Lines 6-8: remove trailing dots
- Line 10: remove trailing dot
- Slide 17:
- Line 3: spelling (insignificent -> insignificant)
- Line 6: Capitalization (Record/Device Support)
- Line 6: spelling (strorage -> storage)
- Line 8: Capitalization (Record/Device Support)
- Line 9: spacing (remove space between "data" and "base")
- Line 13: add comma after "Access"
- Line 14: Capitalization (Record/Device Support)
- Line 14: remove trailing dot
- Slide 18:
- Line 3: Capitalization (Context -> context)
- Line 7: Capitalization (Device Support)
- lines 10, 13: remove trailing dots
What I still find missing is a slide or two about the record processing
state machine. And maybe a pointer to the wiki pages that have all the
details.
Great stuff!
Ralph
Marty Kraimer wrote:
I am
attaching a power point presentation for the EPICS workshop at
ICALEPCS.
Marty
--- End Message ---
o line 6/12: Logical: line 12 says
incB processed in
parallel with incA, while parallel has been set to "false"
in line 6.
This is correct. incA has parallel true which means it is OK to start
something else. In this case it neans incB.
incB has paralley false which means dont do anthing else until incB
completes.
Hm. I understand the mechanism, but I find the syntax, semantics or
terms not very comprehensive, if not even misleading.
Your semantics slide says:
Parallel – If yes then this link can be processed in parallel with
other links
But looking at your example:
void collectSample={
processLink=[3] {
{pvname = “incA”; parallel=true; wait=true},
{pvname = “incB”; parallel=false; wait=true},
{pvname = “getSample”; parallel=false; wait=true}
I can see that incB has parallel set to false, but will indeed be
processed in parallel (with incA).
In other words, using this syntax setting parallel to false will stop
the next link from being processed in parallel, not this link.
I fear users will keep making mistakes forever because they don't
remember if setting parallel changes this or the next link's behaviour.
What about changing the syntax a bit, so that your example reads:
processLink=[3] {
{pvname = “incA”; wait=no},
{pvname = “incB”; wait=completion},
{pvname = “getSample”; wait=completion}
I would find this a lot more obvious - does it collide with the
use of the wait keyword in non-process links? Not necessarily, I think.
Well, one could even go one step further and include some functionality
of the seq record by allowing numbers:
processLink=[3] {
{pvname = “incB”; wait=2.5},
which would fire off incA, incB, and then getSample after waiting
for 2.5 seconds, regardless of incB's process state, finally wait for
getSample to complete.
What do you think?
Ralph
--- End Message ---
o line 6/12: Logical: line 12 says incB processed in
in line 6.
completes.
other links
processLink=[3] {
I agree that parallel is confusing.
the /next/ link from being processed in parallel, not this link. I
processLink=[3] {
See below. The "slight" syntax change does require some changes
I would find this a lot more obvious - does it collide with the use of
functionality of the seq record by allowing numbers:
processLink=[3] {
This would lead to MAJOR problems. What is the type for wait? But see below
which would fire off incA, incB, and then getSample after waiting for
What do you think?
http://www.aps.anl.gov/epics/wiki/index.php/V4_DB_RecordCommon
defines MonitorLink, InputLink, OutputLink, ProcessLink.
Lets just look at ProcessLink since InputLink and OutputLink are similar
since they all have a field parallel
struct(ProcessLink) {
field(pvname,string) { link}
field(parallel,bool)
field(wait,bool)
Perhaps this should be changed to
menu(LinkWait) {
choice(linkWaitNo,"no")
choice(linkWaitYes,"yes")
choice(linkWaitBlock,"block")
field(wait,menu(LinkWait))
field(timeout,double64)
Then
processLink=[3] {
{pvname = “incA”; wait=yes,timeout=2.5},
{pvname = “incB”; wait=block,timeout=2.5},
{pvname = “getSample”; wait=block,timeout=5.0}
Thoughts?
Marty
--- End Message ---
- Re: [Fwd: Re: ICALEPCS 2005: EPICS workshop: EPICS V4 Runtime Database] Kay-Uwe Kasemir
Re: strings Kay-Uwe Kasemir
Re: ICALEPCS 2005: EPICS workshop: EPICS V4 Runtime Database Ralph Lange
<2005>
2025
2026
meeting on Thursday Matthias Clausen
<2005>
2025
2026
