2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: loosely coupled event systems
To: <[email protected]>
Date: Mon, 17 Oct 2005 15:24:35 -0600
Another important benefit of the data access approach is that the property
set that is posted with the event by a service is loosely coupled with the
property set that is requested when a client subscribes for an event. The
client's set need only be a subset of the service's set. We can do this
because the purpose of the property (parameter) passed with the event is
known to the communication system. That is not the case with IDL based
systems like CORBA and ICE. This loose coupling is an important enabler for
a tool based approach. For example, LANSCE devices might include the "beam
flavor" property in the value change event, but MEDM isn't required to be
recompiled to conform to that interface. MEDM might however include a
configuration for an ASCII event filter in the future - something like how
color rules work today. At LANSCE that ASCII filter might select updates
only specifying a particular beam flavor.
Jeff
__________________________________________________________
Jeffrey O. Hill               Mail         [email protected]
LANL MS H820                  Voice        505 665 1831
Los Alamos NM 87545 USA       Fax          505 665 5107
Prev: Re: ICALEPCS and EPICS iocCore V4 Claude Saunders
Next: Re: ICALEPCS and EPICS iocCore V4 Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: FW: Ice GPL based Licensing Jeff Hill
